890-834/011-000
890-834/011-000
    WAGO(万可电子)
    PLUG FOR PCBS ANGLED 4-POLE, WHI
890-834/011-000 数据手册
Data sheet | Item number: 890-834/011-000 Plug for PCBs; angled; 4-pole; Cod. A; white www.wago.com/890-834/011-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 Item description Male connector/plug WINSTA® MINI rated current 16 A Permanently secure installations through distinctive connection technology: The WINSTA® MINI male connector/plug. Our large selection of pluggable PCB connectors with different insertion directions and operating variants offers you the perfect solution for your application at any time. For greater protection in electrical installations, the pcb connector is equipped with mechanical protection against mismating. The WINSTA® MINI pcb connector with A coding in black or white is normally used for general mains applications in power distribution. WINSTA® MINI satisfies the demand for miniaturisation. Our smallest pluggable connection system is primarily suited for lights, for instance, since as a result of LED technology; due to complex systems, these offer much less space for the connection technology. Push-in CAGE CLAMP® spring pressure connection technology – pluggable installation instead of laborious screw connections! WINSTA® is the pluggable connection system that is perfectly tailored to the strict requirements of electrical installation. It allows fast, secure and, above all, error-free installation of components and cables. Now you can also cut installation costs without compromising safety and quality: The WINSTA® MINI pcb connector with marking reduces the need for servicing and prevents unnecessary downtime. effective protection against mismating compact design for conductors with a cross-section up to 1.5 mm² with A coding for a great number of applications quick replacement of defective units during ongoing operation Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 Data Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 16 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Hinweis für den amerikanischen Markt Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL certificate in select applications with currents below 5 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 12 A Connection data Total number of potentials 4 Number of levels 1 Ground function preceding ground contact Pole No. 4 Physical data Pin spacing 4.4 mm / 0.173 inch Width 19.2 mm / 0.756 inch Height 15.7 mm / 0.618 inch Height from the surface 12.2 mm / 0.48 inch Depth 28.4 mm / 1.118 inch Solder pin length 3.5 mm Solder pin dimensions 1 x 0.8 mm Drilled hole diameter with tolerance 1.3 (+0.1) mm Mechanical data Application General mains applications Coding A Marking N ⏚ 2/L 1/L' Potentialkennzeichnung N ⏚ 2/L 1/L' Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 Potentialkennzeichnung N ⏚ 2/L 1/L' Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Design angled Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Mating direction to the PCB 0  ° Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). PCB contact PCB Contact THT Solder pin arrangement 2 in-line solder pins/pole Number of solder pins per potential 2 Material data Color white Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.078 MJ Weight 4.2 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data PU (SPU) 50 Stück Packaging type box Country of origin PL GTIN 4050821695783 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. IEC 61535 NL-64352 CCA DEKRA Certification B.V. EN 61535 71-11299 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping Steel Vessel Rules 19HG1869855PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register EN 61535 08/20047 (E2) UL-Approvals Logo Approval Additional Approval Text cURus UL 1977 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name E45171 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.890-124 Socket; with strain relief housing; 4-pole; Cod. A; 1,50 mm²; white www.wago.com/890-124 Item no.890-224 Socket; 4-pole; Cod. A; 1,50 mm²; white www.wago.com/890-224 Item no.891-8994/006-102 pre-assembled interconnecting cable; Eca; Socket/plug; 4-pole; Cod. A; H05VV-F 4G 1.5 mm²; 1 m; 1,50 mm²; white www.wago.com/891-8994 /006-102 Item no.891-8994/106-102 pre-assembled connecting cable; Eca; Socket/open-ended; 4-pole; Cod. A; H05VV-F 4G 1.5 mm²; 1 m; 1,50 mm²; white www.wago.com/891-8994 /106-102 Downloads CAD/CAE-Data CAD data 2D/3D Models 890-834/011-000 URL Download URL Download PCB Design Symbol and Footprint 890-834/011-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/7 Data sheet | Item number: 890-834/011-000 www.wago.com/890-834/011-000 PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 890-834/011-000 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 890-834/011-000 Plug for PCBs; angled; 4-pole; Cod. A; white Installation Notes Product family WINSTA® MINI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/7
890-834/011-000 价格&库存
很抱歉,暂时无法提供与“890-834/011-000”相匹配的价格&库存,您可以联系我们找货
