LP4C-38-SAE-F-B
LP4C-38-SAE-F-B
    WAKEFIELD-VETTE
    直插式连接器 用于 液体快速连接
LP4C-38-SAE-F-B 数据手册
Liquid Cooling- Connectors LP4C Series Wakefield- Vette’s LP4C Series quick disconnect couplings provide ultra-reliable, dripless connections and disconnections that protect valuable electronics. Designed specifically for liquid cooling applications, LP4C utilizes patent-pending valve technology that eliminates drips and can withstand long-term use. Specifications: PRESSURE: • Vacuum to 120 psi, 8.3 bar TEMPERATURE: • 0°F to 240°F (-17°C to 115°C) MAXIMUM FLOW AT DISCONNECT: • 3.0 gal/min, 11.3L/min MATERIALS: • Main housing components: Chrome-plated brass • Valves and thumb latch: Polysulfone • Valve spring (wetted): Stainless steel • External spring: Stainless steel • Seals: EPDM COLOR: • Chrome with Cool Blue or Warm Red TUBING SIZES: • 1/4" to 3/8" ID, 6.4mm to 9.5mm ID LUBRICANTS: • Krytox® PFPE SPILLAGE: • 0.025 cc per disconnect rated at 0 psi • 0.055 cc per disconnect rated at 120 psi INCLUSION: • 0.025 cc per connect WARNING: Pressure, temperature, chemicals, and operating environment can affect the performance of couplings. It is the customer’s responsibility to test the suitability of WakefieldVette’s products in their own application conditions FEATURES & BENEFITS • Non-spill design- Disconnect under pressure with no spills • Redundant sealing when connectedExtra protection from leaks • Color-coding- Instant visual difference in cooling lines • Friction-free valve- Valving system designed for extended periods in connected state • Ruggedness- Able to withstand longterm, repeated use • Rotation allows movement- Eliminates tube kinking Performance: www.wakefield-vette.com Liquid Cooling- Connectors LP4C Series Coupling Bodies- Chrome Plated Brass: WKV Vette Part Number LP4C-25-B-F-B LP4C-25-B-F-R LP4C-38-B-F-B LP4C-38-B-F-R LP4C-25-SAE-F-B LP4C-25-SAE-F-R LP4C-38-SAE-F-B LP4C-38-SAE-F-R Description Liquid Connector 1/4 HB Valved InLine Body - Blue Liquid Connector 1/4 HB Valved InLine Body - Red Liquid Connector 3/8 HB Valved InLine Body - Blue Liquid Connector 3/8 HB Valved InLine Body - Red Liquid Connector 1/4 SAE Valved In-Line Body - Blue Liquid Connector 1/4 SAE Valved In-Line Body - Red Liquid Connector 3/8 SAE Valved In-Line Body - Blue Liquid Connector 3/8 SAE Valved In-Line Body - Red LP4C Tubing/Thread Height Length ID (inches) (Inches) (Inches) Connector Type In Line Hose 0.25 0.98 2.49 Barb In Line Hose 0.25 0.98 2.49 Barb In Line Hose 0.38 0.98 2.49 Barb In Line Hose 0.38 0.98 2.49 Barb In Line Thread 0.25 0.98 2.29 Port SAE In Line Thread 0.25 0.98 2.29 Port SAE In Line Thread 0.38 0.98 2.29 Port SAE In Line Thread 0.38 0.98 2.29 Port SAE Series Tubing/Thread ID (inches) Height (Inches) LP4C 0.25 0.74 LP4C 0.25 0.74 LP4C 0.38 0.74 Series LP4C LP4C LP4C LP4C LP4C LP4C LP4C Body Type Color Female Blue Female Red Female Blue Female Red Female Blue Female Red Female Blue Female Red Body Type Color Male Blue Male Red Male Blue Male Red Male Blue Male Red Male Blue Male Red Coupling Inserts- Chrome Plated Brass: WKV Vette Part Number Length Connector (Inches) Type In Line Hose 2.22 Barb In Line Hose Barb 2.22 In Line Hose 2.22 Barb LP4C-38-B-M-B Description Liquid Connector 1/4 HB Valved In-Line Insert - Blue Liquid Connector 1/4 HB Valved In-Line Insert - Red Liquid Connector 3/8 HB Valved In-Line Insert - Blue LP4C-38-B-M-R Liquid Connector 3/8 HB Valved In-Line Insert - Red LP4C 0.38 0.74 2.22 LP4C-25-SAE-M-B Liquid Connector 1/4 SAE Valved In-Line Insert - Blue LP4C 0.25 0.8 2.02 LP4C-25-SAE-M-R Liquid Connector 1/4 SAE Valved In-Line Insert - Red LP4C 0.25 0.8 2.02 LP4C-38-SAE-M-B Liquid Connector 3/8 SAE Valved In-Line Insert - Blue LP4C 0.38 0.8 2.02 LP4C-38-SAE-M-R Liquid Connector 3/8 SAE Valved In-Line Insert - Red LP4C 0.38 0.8 www.wakefield-vette.com 2.02 LP4C-25-B-M-B LP4C-25-B-M-R In Line Hose Barb In Line Thread Port SAE In Line Thread Port SAE In Line Thread Port SAE In Line Thread Port SAE
LP4C-38-SAE-F-B 价格&库存
很抱歉,暂时无法提供与“LP4C-38-SAE-F-B”相匹配的价格&库存,您可以联系我们找货
