LP6C-38-B-M-R
LP6C-38-B-M-R
    WAKEFIELD-VETTE
    直插式连接器 用于 液体快速连接
LP6C-38-B-M-R 数据手册
Liquid Cooling- Connectors LP6C Series Wakefield- Vette’s LP6C Series quick disconnect couplings provide ultra-reliable, dripless connections and disconnections that protect valuable electronics. Designed specifically for liquid cooling applications, LP6C utilizes patent-pending valve technology that eliminates drips and can withstand long-term use. Specifications: PRESSURE: • Vacuum to 120 psi, 8.3 bar TEMPERATURE: • 0°F to 240°F (-17°C to 115°C) MAXIMUM FLOW AT DISCONNECT: • 4.0 gal/min, 15.1L/min MATERIALS: • Main housing components: Chrome-plated brass • Valves and thumb latch: Polysulfone • Valve spring (wetted): Stainless steel • External spring: Stainless steel • Seals: EPDM COLOR: • Chrome with Cool Blue or Warm Red TUBING SIZES: • 3/8" to 1/2" ID, 9.5mm to 12.7mm ID LUBRICANTS: • Krytox® PFPE SPILLAGE: • 0.05 cc per disconnect rated at 0 psi • 0.125 cc per disconnect rated at 120 psi INCLUSION: • 0.42 cc per connect WARNING: Pressure, temperature, chemicals, and operating environment can affect the performance of couplings. It is the customer’s responsibility to test the suitability of WakefieldVette’s products in their own application conditions FEATURES & BENEFITS • Non-spill design- Disconnect under pressure with no spills • Redundant sealing when connectedExtra protection from leaks • Color-coding- Instant visual difference in cooling lines • Friction-free valve- Valving system designed for extended periods in connected state • Ruggedness- Able to withstand longterm, repeated use • Rotation allows movement- Eliminates tube kinking Performance: www.wakefield-vette.com Liquid Cooling- Connectors LP6C Series Coupling Bodies- Chrome Plated Brass: WKV Vette Part Number Description Series Tubing/Thread ID (inches) Height (Inches) Length (Inches) Connector Type Body Type Color LP6C-38-B-F-B Liquid Connector 3/8 HB Valved In-Line Body - Blue LP6C 0.38 1.185 2.73 In Line Hose Barb Female Blue LP6C-38-B-F-R Liquid Connector 3/8 HB Valved In-Line Body - Red LP6C 0.38 1.185 2.73 In Line Hose Barb Female Red LP6C-50-B-F-B Liquid Connector 1/2 HB Valved In-Line Body - Blue LP6C 0.5 1.185 2.73 In Line Hose Barb Female Blue LP6C-50-B-F-R Liquid Connector 1/2 HB Valved In-Line Body - Red LP6C 0.5 1.185 2.73 In Line Hose Barb Female Red LP6C-38-SAE-F-B Liquid Connector 3/8 SAE Valved In-Line Body - Blue LP6C 0.38 1.185 2.48 In Line Thread Port SAE Female Blue 2.48 In Line Thread Port SAE Female Red 2.5 In Line Thread Port SAE Female Blue Female Red LP6C-38-SAE-F-R Liquid Connector 3/8 SAE Valved In-Line Body - Red LP6C LP6C-50-SAE-F-B Liquid Connector 1/2 SAE Valved In-Line Body - Blue LP6C 0.38 0.5 1.185 1.185 0.5 1.185 2.5 In Line Thread Port SAE Tubing/Thread ID (inches) Height (Inches) Length (Inches) Connector Type Body Type Color LP6C-38-B-M-B Liquid Connector 3/8 HB Valved In-Line Insert - Blue LP6C 0.38 0.93 2.47 In Line Hose Barb Male Blue LP6C-38-B-M-R Liquid Connector 3/8 HB Valved In-Line Insert - Red LP6C 0.38 0.93 2.47 In Line Hose Barb Male Red LP6C-50-B-M-B Liquid Connector 1/2 HB Valved In-Line Insert - Blue LP6C 0.5 0.93 2.47 In Line Hose Barb Male Blue LP6C-50-B-M-R Liquid Connector 1/2 HB Valved In-Line Insert - Red LP6C 0.5 0.93 2.47 In Line Hose Barb Male Red LP6C-38-SAE-M-B Liquid Connector 3/8 SAE Valved In-Line Insert - Blue LP6C 0.38 1.025 2.3 In Line Thread Port SAE Male Blue LP6C-38-SAE-M-R Liquid Connector 3/8 SAE Valved In-Line Insert - Red LP6C 0.38 1.025 2.3 In Line Thread Port SAE Male Red LP6C-50-SAE-M-B Liquid Connector 1/2 SAE Valved In-Line Insert - Blue LP6C 0.5 1.025 2.3 In Line Thread Port SAE Male Blue LP6C-50-SAE-M-R Liquid Connector 1/2 SAE Valved In-Line Insert - Red LP6C 0.5 1.025 2.3 In Line Thread Port SAE Male Red LP6C-50-SAE-F-R Liquid Connector 1/2 SAE Valved In-Line Body - Red LP6C Coupling Inserts- Chrome Plated Brass: WKV Vette Part Number Description Series www.wakefield-vette.com
LP6C-38-B-M-R 价格&库存
很抱歉,暂时无法提供与“LP6C-38-B-M-R”相匹配的价格&库存,您可以联系我们找货
