TEC-30-36-71
TEC-30-36-71
    WAKEFIELD-VETTE
    PELTIER TEC 30X30X3.8MM 6.0A
TEC-30-36-71 数据手册
Thermoelectric Cooler Performance Specifications TEC Series Wakefield-Vette’s Peltier, thermoelectric coolers can meet the requirement of higher current and large cooling. It is often applied to experimental, scientific and biomedical instruments, laboratory equipment, industry and electrical equipment and consumables. The ambient temperature can arrive 100C, long-term working temperature is recommended to be below 90C. Features: • All products are RoHS and REACH compliant, SGS ISO9001 verified • Thermoelectric module material are UL certification • Standard Wire is 150mm • Thermoelectric module moisture protection standard is sealed by white RTV silicone, but also support select other moisture protection style, Such as translucent silicone, black epoxy. • Thermoelectric module flatness tolerance support select 0.2mm, 0.13mm, 0.1mm. WKV Part Number Description Current Q max (W) V max (V) @ ∆T max (°C) @ max (A) @ 27°C 27°C 27°C # of Couples Outline (L/W/) Height (mm) TEC-30-40-127 PELTIER TEC 30X30 4MM 2.5A 2.5 21.4 15.4 68 127 30x30 4 TEC-30-32-127 PELTIER TEC 30X30 3.2MM 3.9A 3.9 33.4 15.4 68 127 30x30 3.2 TEC-40-39-127 PELTIER TEC 40X40 4.7MM 3.9A 3.9 33.4 15.4 68 127 40x40 3.9 TEC-40-33-127 PELTIER TEC 40X40 3.3MM 8.5A 8.5 72 15.4 68 127 40x40 3.3 TEC-30-36-127 PELTIER TEC 30X30 3.6MM 3.0A 3.0 25.7 15.4 68 127 30x30 3.6 TEC-30-39-71 PELTIER TEC 30X30 4.7MM 3.9A 3.9 18.7 8.6 68 71 30x30 3.9 TEC-30-36-71 PELTIER TEC 30X30 3.8MM 6.0A 6.0 28.7 8.6 68 71 30x30 3.6 TEC-40-36-127 PELTIER TEC 40X40 3.8MM 6.0A 6.0 51.4 15.4 68 127 40x40 3.6 TEC-20-33-31 PELTIER TEC 20X20 3.3MM 8.5A 8.5 16.8 3.75 68 31 20x20 3.3 TEC-30-33-71 PELTIER TEC 30X30 3.3MM 8.5A 8.5 72 15.4 68 71 30x30 3.3 Thermoelectric Cooler Performance Specifications TEC-40-39-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-40-39-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-32-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-32-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-40-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-40-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-40-33-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-40-33-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-36-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-36-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-39-71 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-39-71 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-36-71 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-36-71 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-40-36-127 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-40-36-127 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-20-33-31 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-20-33-31 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2 Thermoelectric Cooler Performance Specifications TEC-30-33-71 Wakefield-Vette reserves the right to change these specifications without notice 1/2 Thermoelectric Cooler Performance Specifications TEC-30-33-71 Operation Tips: • Maximum Operating Temperature: 90oC • Do not exceed Imax or Vmax when operating module • Please consult Wakefield-Vette for moisture and corrosion protection options as well as specific application inquiries Wakefield-Vette reserves the right to change these specifications without notice 2/2
TEC-30-36-71 价格&库存
很抱歉,暂时无法提供与“TEC-30-36-71”相匹配的价格&库存,您可以联系我们找货
TEC-30-36-71
    TEC-30-36-71
      库存:36
