DB0550505H1A-2T0
DB0550505H1A-2T0
    WAKEFIELD-VETTE
    风扇 鼓风机 5VDC 矩形/圆形 - 55mm 长 x 50mm 高 滚珠 1.3 CFM(0.036m³/min) 2 位置矩形连接器
DB0550505H1A-2T0 数据手册
SLIM-LINE BLOWERS Wakefield-Vette’s unique slim and powerful DC blowers are perfect for ultra-thin cooling applications, where cooling is a must. The Slim-Line blower features an ultra-thin blade design resulting in excellent performance & sound quality. Wakefield-Vette Revision A SLIM-LINE BLOWERS The Slim-Line Blower three-phase motor design provides exceptional balancing characteristics and low power consumption. Designed for tablets, notebooks, automotive, gaming monitors, all in one PC’s, or any other low-profile application, these powerful, ultra-thin, direct-diverting blowers can be as thin as 3.2mm Options: • IP-55 water protection rating • Pulse width modulation control (PWM) • Frequency generator output (FG signal/tach) • Custom sizes and performances Features & Benefits: • Sizes include: • Ultra Thin- as low as 3mm up to 10mm • Various Footprints • Custom sizes available Upon Request • Operating temperature- -10°C to +70°C • Long life- Rated 50,000 hours @ 40 °C • Fluid Bearing (AFB) • Three-phase motor • Optimized blade design • Ultra-quiet (as low as 21db) • Suitable for automotive applications WKV PN Fan Size (mm) DB1703 DB2003 DB03003 DB03004 DB03010 DB05505 DB05905 DB06304 DB06205 DB08904 DB08705 DB08706 17*17*3.2 20*20*3.2 30*30*3.2 30*30*4.0 30*30*10 55*50*5.25 59.3*55.6*5.6 63*63*4 61.8*57.3*5.6 89.1*83.8*4.7 87*74.5*5 87*74.5*5.5 Description ULTRA THIN DC BLOWER 17X17X3.2MM 3V .204CFM ULTRA THIN DC BLOWER 20X20X3.2MM 3V .34CFM ULTRA THIN DC BLOWER 30X30X3.2MM 5V .69CFM PWM ULTRA THIN DC BLOWER 30X30X4MM 5V .76CFM ULTRA THIN DC BLOWER 30X30X10MM 5V 1.09CFM ULTRA THIN DC BLOWER 55X55X5.25MM 5V 1.27CFM ULTRA THIN DC BLOWER 59.3X55.6X5.6MM 5V 3.25CFM ULTRA THIN DC BLOWER 63X63X4MM 5V 2.15CFM ULTRA THIN DC BLOWER 61.8X57.3X5.6MM 5V 2.68CFM ULTRA THIN DC BLOWER 89.1X83.8X4.7MM 5V 3.91CFM ULTRA THIN DC BLOWER 87X74.5X5MM 5V 4.63CFM ULTRA THIN DC BLOWER 87X74.5X5.52MM 12V 5.70CFM Wakefield-Vette Optimized Blade Design Voltage Air Flow Static Pressure (VDC) (CFM) (mm) 3 0.20 3.78 3 0.34 4.66 5 0.70 8.37 5 0.76 8.80 5 1.09 5.61 5 1.27 3.79 5 3.25 17.08 5 2.15 12.84 5 2.68 19.90 5 3.91 11.40 5 4.63 14.52 5 5.70 15.87 Page 2 Noise 26.6dB(A) 26.9dB(A) 34.1dB(A) 31.3dB(A) 28dB(A) 21.2dB(A) 41.1dB(A) 35.4dB(A) 42.8dB(A) 38.5dB(A) 40.9dB(A) 41.85dB(A) Power (Watts) 0.12 0.24 0.50 0.50 1.10 0.70 1.90 1.75 1.90 1.50 2.25 2.25 RPM Termination 12000 3 Wire, No Connector 11000 3 Wire, No Connector 9500 4 Wire, PWM No Connector 9500 2 Wire, No Connector 7000 2 Wire, No Connector 3100 2 Wire, No Connector 6700 4 Wire, PWM No Connector 5700 4 Wire, PWM No Connector 7400 4 Wire, PWM No Connector 3400 4 Wire, PWM No Connector 4500 4 Wire, PWM No Connector 4600 4 Wire, PWM No Connector Revision A SLIM-LINE BLOWERS Tach/PWM Configurations • 3 – Tach • B – PWM + Tach Wakefield-Vette Page 3 Revision A SLIM-LINE BLOWERS DB1703 Fan Size Voltage Air Flow Static Pressure Power Weight Description Noise RPM Termination (mm) (VDC) (CFM) (mm) (Watts) (g) DB170303H1A-3T0 17*17*3.2 ULTRA THIN DC BLOWER 17X17X3.2MM 3V .204CFM 3 0.20 3.78 26.6dB(A) 0.12 12000 3 Wire, No Connector 1.5 WKV PN Wakefield-Vette Page 4 Revision A SLIM-LINE BLOWERS DB2003 Fan Size Voltage Air Flow Static Pressure Power Weight Description Noise RPM Termination (mm) (VDC) (CFM) (mm) (Watts) (g) DB200303H1A-3T0 20*20*3.2 ULTRA THIN DC BLOWER 20X20X3.2MM 3V .34CFM 3 0.34 4.66 26.9dB(A) 0.24 11000 3 Wire, No Connector 1.5 WKV PN Wakefield-Vette Page 5 Revision A SLIM-LINE BLOWERS DB03003 Fan Size Voltage Air Flow Static Pressure Power Weight Description Noise RPM Termination (Watts) (g) (mm) (VDC) (CFM) (mm) DB0300305H1A-BT0 30*30*3.2 ULTRA THIN DC BLOWER 30X30X3.2MM 5V .69CFM PWM 5 0.70 8.37 34.1dB(A) 0.5 9500 4 Wire, PWM No Connector 5.1 WKV PN Wakefield-Vette Page 6 Revision A SLIM-LINE BLOWERS DB03004 Fan Size Voltage Air Flow Static Pressure Power Weight Description Noise RPM Termination (mm) (VDC) (CFM) (mm) (Watts) (g) DB0300405H1A-2T0 30*30*4.0 ULTRA THIN DC BLOWER 30X30X4MM 5V .76CFM 5 0.76 8.80 31.3dB(A) 0.5 9500 2 Wire, No Connector 5 WKV PN Wakefield-Vette Page 7 Revision A SLIM-LINE BLOWERS DB03010 Fan Size (mm) DB0301005H1A-2T0 30*30*10 WKV PN Wakefield-Vette Description ULTRA THIN DC BLOWER 30X30X10MM 5V 1.09CFM Voltage Air Flow Static Pressure Power Noise RPM (VDC) (CFM) (mm) (Watts) 5 1.09 5.61 28dB(A) 1.1 7000 Page 8 Termination 2 Wire, No Connector Weight (g) 8.4 Revision A SLIM-LINE BLOWERS DB05505 Fan Size (mm) DB0550505H1A-2T0 55*50*5.25 WKV PN Wakefield-Vette Description ULTRA THIN DC BLOWER 55X55X5.25MM 5V 1.27CFM Voltage Air Flow Static Pressure Power Noise RPM (VDC) (CFM) (mm) (Watts) 5 1.27 3.79 21.2dB(A) 0.7 3100 Page 9 Termination 2 Wire, No Connector Weight (g) 17 Revision A SLIM-LINE BLOWERS DB05905 WKV PN Fan Size (mm) Description DB0590505H1A-BT0 59.3*55.6*5.6 ULTRA THIN DC BLOWER 59.3X55.6X5.6MM 5V 3.25CFM Wakefield-Vette Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (VDC) (CFM) (mm) (Watts) (g) 5 3.25 17.08 41.1dB(A) 1.9 6700 4 Wire, PWM No Connector 20 Page 10 Revision A SLIM-LINE BLOWERS DB06304 Fan Size (mm) DB0630405H1A-BT0 63*63*4 WKV PN Wakefield-Vette Description ULTRA THIN DC BLOWER 63X63X4MM 5V 2.15CFM Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (Watts) (g) (VDC) (CFM) (mm) 5 2.15 12.84 35.4dB(A) 1.75 5700 4 Wire, PWM No Connector 26 Page 11 Revision A SLIM-LINE BLOWERS DB06205 WKV PN Fan Size (mm) Description DB0620505H1A-BT0 61.8*57.3*5.6 ULTRA THIN DC BLOWER 61.8X57.3X5.6MM 5V 2.68CFM Wakefield-Vette Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (VDC) (CFM) (mm) (Watts) (g) 5 2.68 19.90 42.8dB(A) 1.9 7400 4 Wire, PWM No Connector 17 Page 12 Revision A SLIM-LINE BLOWERS DB08904 WKV PN Fan Size (mm) Description DB0890405H1A-BT0 89.1*83.8*4.7 ULTRA THIN DC BLOWER 89.1X83.8X4.7MM 5V 3.91CFM Wakefield-Vette Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (VDC) (CFM) (mm) (Watts) (g) 5 3.91 11.40 38.5dB(A) 1.5 3400 4 Wire, PWM No Connector 38 Page 13 Revision A SLIM-LINE BLOWERS DB08705 Fan Size (mm) DB0870505H1A-BT0 87*74.5*5 WKV PN Wakefield-Vette Description ULTRA THIN DC BLOWER 87X74.5X5MM 5V 4.63CFM Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (VDC) (CFM) (mm) (Watts) (g) 5 4.63 14.52 40.9dB(A) 2.25 4500 4 Wire, PWM No Connector 41 Page 14 Revision A SLIM-LINE BLOWERS DB08706 Fan Size (mm) DB0870605H1A-BT0 87*74.5*5.5 WKV PN Wakefield-Vette Description ULTRA THIN DC BLOWER 87X74.5X5.52MM 12V 5.70CFM Voltage Air Flow Static Pressure Power Weight Noise RPM Termination (VDC) (CFM) (mm) (Watts) (g) 5 5.70 15.87 41.85dB(A) 2.25 4600 4 Wire, PWM No Connector 46 Page 15 Revision A
DB0550505H1A-2T0 价格&库存
很抱歉,暂时无法提供与“DB0550505H1A-2T0”相匹配的价格&库存,您可以联系我们找货
