SLIM-LINE BLOWERS
Wakefield-Vette’s unique slim and powerful DC blowers are perfect for ultra-thin
cooling applications, where cooling is a must. The Slim-Line blower features an ultra-thin
blade design resulting in excellent performance & sound quality.
Wakefield-Vette
Revision A
SLIM-LINE BLOWERS
The Slim-Line Blower three-phase motor design provides exceptional balancing characteristics and
low power consumption. Designed for tablets, notebooks, automotive, gaming monitors, all in one
PC’s, or any other low-profile application, these powerful, ultra-thin, direct-diverting blowers can
be as thin as 3.2mm
Options:
IP-55 water protection rating
Pulse width modulation control (PWM)
Frequency generator output (FG signal/tach)
Custom sizes and performances
Features & Benefits:
Sizes include:
Ultra Thin- as low as 3mm up to 10mm
Various Footprints
Custom sizes available Upon Request
Operating temperature- -10°C to +70°C
Long life- Rated 50,000 hours @ 40 °C
Fluid Bearing (AFB)
Three-phase motor
Optimized blade design
Ultra-quiet (as low as 21db)
Suitable for automotive applications
WKV PN
Fan Size (mm)
DB1703
DB2003
DB03003
DB03004
DB03010
DB05505
DB05905
DB06304
DB06205
DB08904
DB08705
DB08706
17*17*3.2
20*20*3.2
30*30*3.2
30*30*4.0
30*30*10
55*50*5.25
59.3*55.6*5.6
63*63*4
61.8*57.3*5.6
89.1*83.8*4.7
87*74.5*5
87*74.5*5.5
Description
ULTRA THIN DC BLOWER 17X17X3.2MM 3V .204CFM
ULTRA THIN DC BLOWER 20X20X3.2MM 3V .34CFM
ULTRA THIN DC BLOWER 30X30X3.2MM 5V .69CFM PWM
ULTRA THIN DC BLOWER 30X30X4MM 5V .76CFM
ULTRA THIN DC BLOWER 30X30X10MM 5V 1.09CFM
ULTRA THIN DC BLOWER 55X55X5.25MM 5V 1.27CFM
ULTRA THIN DC BLOWER 59.3X55.6X5.6MM 5V 3.25CFM
ULTRA THIN DC BLOWER 63X63X4MM 5V 2.15CFM
ULTRA THIN DC BLOWER 61.8X57.3X5.6MM 5V 2.68CFM
ULTRA THIN DC BLOWER 89.1X83.8X4.7MM 5V 3.91CFM
ULTRA THIN DC BLOWER 87X74.5X5MM 5V 4.63CFM
ULTRA THIN DC BLOWER 87X74.5X5.52MM 12V 5.70CFM
Wakefield-Vette
Optimized Blade Design
Voltage Air Flow Static Pressure
(VDC)
(CFM)
(mm)
3
0.20
3.78
3
0.34
4.66
5
0.70
8.37
5
0.76
8.80
5
1.09
5.61
5
1.27
3.79
5
3.25
17.08
5
2.15
12.84
5
2.68
19.90
5
3.91
11.40
5
4.63
14.52
5
5.70
15.87
Page 2
Noise
26.6dB(A)
26.9dB(A)
34.1dB(A)
31.3dB(A)
28dB(A)
21.2dB(A)
41.1dB(A)
35.4dB(A)
42.8dB(A)
38.5dB(A)
40.9dB(A)
41.85dB(A)
Power
(Watts)
0.12
0.24
0.50
0.50
1.10
0.70
1.90
1.75
1.90
1.50
2.25
2.25
RPM
Termination
12000 3 Wire, No Connector
11000 3 Wire, No Connector
9500 4 Wire, PWM No Connector
9500 2 Wire, No Connector
7000 2 Wire, No Connector
3100 2 Wire, No Connector
6700 4 Wire, PWM No Connector
5700 4 Wire, PWM No Connector
7400 4 Wire, PWM No Connector
3400 4 Wire, PWM No Connector
4500 4 Wire, PWM No Connector
4600 4 Wire, PWM No Connector
Revision A
SLIM-LINE BLOWERS
Tach/PWM Configurations
• 3 – Tach
• B – PWM + Tach
Wakefield-Vette
Page 3
Revision A
SLIM-LINE BLOWERS
DB1703
Fan Size
Power
Weight
Description
Noise
RPM
Termination
(mm)
(VDC) (CFM)
(mm)
(Watts)
(g)
DB170303H1A-3T0 17*17*3.2 ULTRA THIN DC BLOWER 17X17X3.2MM 3V .204CFM
3
0.20
3.78
26.6dB(A) 0.12 12000 3 Wire, No Connector 1.5
WKV PN
Wakefield-Vette
Page 4
Revision A
SLIM-LINE BLOWERS
DB2003
Fan Size
Power
Weight
Description
Noise
RPM
Termination
(mm)
(VDC) (CFM)
(mm)
(Watts)
(g)
DB200303H1A-3T0 20*20*3.2 ULTRA THIN DC BLOWER 20X20X3.2MM 3V .34CFM
3
0.34
4.66
26.9dB(A) 0.24 11000 3 Wire, No Connector 1.5
WKV PN
Wakefield-Vette
Page 5
Revision A
SLIM-LINE BLOWERS
DB03003
Fan Size
Power
Weight
Description
Noise
RPM
Termination
(Watts)
(g)
(mm)
(VDC) (CFM)
(mm)
DB0300305H1A-BT0 30*30*3.2 ULTRA THIN DC BLOWER 30X30X3.2MM 5V .69CFM PWM
5
0.70
8.37
34.1dB(A) 0.5 9500 4 Wire, PWM No Connector 5.1
WKV PN
Wakefield-Vette
Page 6
Revision A
SLIM-LINE BLOWERS
DB03004
Fan Size
Power
Weight
Description
Noise
RPM
Termination
(mm)
(VDC) (CFM)
(mm)
(Watts)
(g)
DB0300405H1A-2T0 30*30*4.0 ULTRA THIN DC BLOWER 30X30X4MM 5V .76CFM
5
0.76
8.80
31.3dB(A) 0.5 9500 2 Wire, No Connector 5
WKV PN
Wakefield-Vette
Page 7
Revision A
SLIM-LINE BLOWERS
DB03010
Fan Size
(mm)
DB0301005H1A-2T0 30*30*10
WKV PN
Wakefield-Vette
Description
Power
Noise
RPM
(VDC) (CFM)
(mm)
(Watts)
5
1.09
5.61
28dB(A) 1.1 7000
Page 8
Termination
Weight
(g)
8.4
Revision A
SLIM-LINE BLOWERS
DB05505
Fan Size
(mm)
DB0550505H1A-2T0 55*50*5.25
WKV PN
Wakefield-Vette
Description
Power
Noise
RPM
(VDC) (CFM)
(mm)
(Watts)
5
1.27
3.79
21.2dB(A) 0.7 3100
Page 9
Termination
Weight
(g)
17
Revision A
SLIM-LINE BLOWERS
DB05905
WKV PN
Fan Size (mm)
Description
DB0590505H1A-BT0 59.3*55.6*5.6 ULTRA THIN DC BLOWER 59.3X55.6X5.6MM 5V 3.25CFM
Wakefield-Vette
Power
Weight
Noise
RPM
Termination
(VDC) (CFM)
(mm)
(Watts)
(g)
5
3.25
17.08
41.1dB(A) 1.9 6700 4 Wire, PWM No Connector 20
Page 10
Revision A
SLIM-LINE BLOWERS
DB06304
Fan Size
(mm)
DB0630405H1A-BT0 63*63*4
WKV PN
Wakefield-Vette
Description
Power
Weight
Noise
RPM
Termination
(Watts)
(g)
(VDC) (CFM)
(mm)
5
2.15
12.84
35.4dB(A) 1.75 5700 4 Wire, PWM No Connector 26
Page 11
Revision A
SLIM-LINE BLOWERS
DB06205
WKV PN
Fan Size (mm)
Description
DB0620505H1A-BT0 61.8*57.3*5.6 ULTRA THIN DC BLOWER 61.8X57.3X5.6MM 5V 2.68CFM
Wakefield-Vette
Power
Weight
Noise
RPM
Termination
(VDC) (CFM)
(mm)
(Watts)
(g)
5
2.68
19.90
42.8dB(A) 1.9 7400 4 Wire, PWM No Connector 17
Page 12
Revision A
SLIM-LINE BLOWERS
DB08904
WKV PN
Fan Size (mm)
Description
DB0890405H1A-BT0 89.1*83.8*4.7 ULTRA THIN DC BLOWER 89.1X83.8X4.7MM 5V 3.91CFM
Wakefield-Vette
Power
Weight
Noise
RPM
Termination
(VDC) (CFM)
(mm)
(Watts)
(g)
5
3.91
11.40
38.5dB(A) 1.5 3400 4 Wire, PWM No Connector 38
Page 13
Revision A
SLIM-LINE BLOWERS
DB08705
Fan Size
(mm)
DB0870505H1A-BT0 87*74.5*5
WKV PN
Wakefield-Vette
Description
Power
Weight
Noise
RPM
Termination
(VDC) (CFM)
(mm)
(Watts)
(g)
5
4.63
14.52
40.9dB(A) 2.25 4500 4 Wire, PWM No Connector 41
Page 14
Revision A
SLIM-LINE BLOWERS
DB08706
Fan Size
(mm)
DB0870605H1A-BT0 87*74.5*5.5
WKV PN
Wakefield-Vette
Description
Power
Weight
Noise
RPM
Termination
(VDC) (CFM)
(mm)
(Watts)
(g)
5
5.70
15.87
41.85dB(A) 2.25 4600 4 Wire, PWM No Connector
46
Page 15
Revision A
很抱歉,暂时无法提供与“DB0870505H1A-BT0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+111.616262000+14.43290
