RFDPA161500SMMB801
RFDPA161500SMMB801
    WALSIN(华新科)
    788.5MHz,2.2GHz,3.75GHz,6.15GHz LTE 鞭状,倾斜 RF 天线 617MHz ~ 960MHz,1.71GHz ~ 2.69GHz,3.3GHz ~ 4.2GHz,5....
RFDPA161500SMMB801 数据手册
Approval sheet Dipole ANTENNA 617~960/1710~2690/3300~4200/5150~7150MHz Working Frequency Halogens Free Product P/N: RFDPA161500SMMB801 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Version V01 Page 2 of 22 Date 2019 Feb. Description New Release RFDPA161500SMMB801_V01 Author HWCHAN Feb. 2019 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 617 ~960 / 1710 ~ 2690 /3300 ~4200 / 5150 ~7150 MHz (note-1) Return Loss -6.0 dB(Max)( @ 617 ~960 / 1710 ~ 2690 MHz) -6.0 dB(Max)( @ 3300 ~4200 / 5150 ~7150 MHz) 3.0 (Max)( @ 617 ~960 / 1710 ~ 2690 MHz) 3.0 (Max)( @ 3300 ~4200 / 5150 ~7150 MHz) Omni-directional VSWR Radiation Gain(peak) Impedance 0.93 dBi( @ 617 ~960 MHz) 2.71 dBi( @1710 ~ 2690 MHz) 3.66 dBi(@ 3300 ~4200 MHz) 4.37 dBi(@5150 ~7150 MHz) 50 Ohm Nominal Polarization Admitted Power Linear Vertical 1W Operation Temperature -20℃ ~ +65℃ *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description Antenna Cover ABS(White) Antenna Up Base ABS (White) Antenna Down Base PC (White) Rivet POM (White) PCB FR4(Single Layer);T=0.8mm(Black) 泡棉單面膠 EVA+單面 3M9888T Cable RG178 Cable;Brown Connector SMA PLUG(White) ORDERING RULE RF DPA Type Code Product Code 1615 Dipole Dimension (Unit: mm) 00 S Cable Connector Length (unit: Brand cm) M M B Type of Connector Application Project status C:MCX 0: 0GHz 3: 3GHz 6: 6GHz D:IPEX III A: 2.4GHz ISM band E: IPEX IV B: GSM 900/1800 A: N Per 2 digits of length, width Walsin RF Device DPA: Dipole e.g.: 1615 Antenna Length 169.9mm, Width 13.0mm 2 digits for F: IPEX A13 A: Reverse Female B: Reverse Male cable length H: Hirose F: Female I: IPEX M: Male e.g.: M: MMCX N: None Non Cable S: SMA T: TNC U:MURATA N: None Page 3 of 22 RFDPA161500SMMB801_V01 dual band G: GPS band L: 2.4/5.2/5.8 GHz tri-band M:LTE+Sub 6G +5G N: NFC T: LTE band W: WCDMA band 8 01 Wire Project Diameter 0:None 1:∅ 0.81 B: MP T:Dur ing Test 3:∅ 1.13 X: Pile Run 6:RG316 01~99 7:∅ 1.37 series 8:RG178 9:∅ 1.37 Low Loss number Feb. 2019 Approval sheet DIMENSIONS Page 4 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Test Report ■EXPERIMENTAL SETUP Page 5 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet ■ELECTRICAL CHARACTERISTICS VSWR 0 Degree 90 Degree Page 6 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet ■Antenna Efficiency and Peak Gain 617~960MHz Page 7 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 1710~2690MHz Page 8 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 3300~4200MHz Page 9 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 5150~7150MHz Page 10 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet ■RADIATION PATTERN 617~960MHz X-Z Plane Phi=0.00deg Gain . dB Page 11 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 12 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 13 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 1710~2690MHz X-Z Plane Phi=0.00deg Gain . dB Page 14 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 15 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 16 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 3300~4200MHz X-Z Plane Phi=0.00deg Gain . dB Page 17 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 18 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 19 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet 5150~7150MHz X-Z Plane Phi=0.00deg Gain . dB Page 20 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 21 of 22 RFDPA161500SMMB801_V01 Feb. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 22 of 22 RFDPA161500SMMB801_V01 Feb. 2019
RFDPA161500SMMB801 价格&库存
很抱歉,暂时无法提供与“RFDPA161500SMMB801”相匹配的价格&库存,您可以联系我们找货
