KFDIP2004L197B1U
KFDIP2004L197B1U
    WALSIN(华新科)
    射频双工器 双工器 2.4GHz ~ 2.5GHz / 4.9GHz ~ 5.95GHz 0805(2012 公制),6 PC 板
KFDIP2004L197B1U 数据手册
Approval sheet KFDIP Series – 2012(0805)- RoHS Compliance MULTILAYER CERAMIC DIPLEXER Halogens Free Product 2.4 GHz & 5 GHz ISM Band RF Application P/N: KFDIP2004L197B1U *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet FEATURES 3 1. Miniature footprint: 2.0 X 1.25 X 0.4 mm . 2. LTCC Process 3. Low Profile Thickness 4. Low Insertion Loss 5. High Rejection 6. RoHS Compliance 7. Halogens Free Product APPLICATIONS 1. 2400 ~ 2500 MHz and 4900 ~ 5950 MHz working frequency CONSTRUCTION Top view P6 P5 P1 P2 P4 1 PIN Connection PIN Connection 1 GND 4 Higher Freq. Port 2 Common(ANT) Port 5 GND 3 GND 6 Lower Freq. Port P3 DIMENSIONS Figure Top view Page 2 of 7 Bottom view Symbol Dimension (mm) L 2.00 ± 0.15 W 1.25 ± 0.15 T 0.40 ± 0.10 A 0.20 ± 0.15 B 0.30 ± 0.15 C 0.35 ± 0.15 D 0.65 ± 0.15 E 0.20 ± 0.15 Side view ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet ELECTRICAL CHARACTERISTICS KFDIP2004L197B1U Specification Frequency range Insertion Loss 2400 ~ 2500 MHz 0.6 dB max. (0.45 dB typ.) 4900 ~ 5950 MHz 1.0 dB max. (0.82 dB typ.) 20 dB min. (29.1 dB typ.) @ 824 ~ 915 MHz Attenuation 15 dB min. (17.7 dB typ.) @ 3600 MHz 18 dB min. (22.1 dB typ.) @ 1800 ~ 2500 MHz 25 dB min. (25.3 dB typ.) @ 4800 ~ 5000 MHz 14 dB min. (21.6 dB typ.) @ 3000 ~ 3900 MHz 20 dB min. (32.8 dB typ.) @ 7200 ~ 7500 MHz 20 dB min. (27.7 dB typ.) @ 9800 ~ 11900 MHz 20 dB min. (29.5 dB typ.) @ 14700 ~ 17850 MHz 20 dB min. (22.4 dB typ.) @ DC ~ 2500 MHz 20 dB min. (26.6 dB typ.) @ 4900 ~ 5950 MHz Return Loss 10 dB min. (12.6 dB typ.) Moisture sensitivity levels LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Isolation Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart SOLDER LAND PATTERN Figure Unit: mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260  5C (Resistance to *Leaching immersion time:30  0.5 sec dissolution of Loss of metallization on the edges of each electrode shall not exceed 25%. Solder : SN63A metallization) IEC 60068-2-58 Resistance to soldering *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under heat JIS C 0050-5.4 *Immersion time:101 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. Customer’s specification. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 Bending test JIS C 0051- 7.4.1 *Pressurizing force: 5N(≦0603);10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE KF Walsin RF device DIP 20 04 Product Code Dimension code DIP : Diplexer e.g. : Dimension code Per 2 digits of Length, Width,: 04= Thickness 04 L 197B1U Application Specification L : Design code 2.4GHz/5GHz 20 = Length 20, Width 12, Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 6 of 7 Ao Bo D T W 1.40  0.10 2.25  0.10 1.55  0.05 0.75  0.10 8.0  0.10 E F Po P1 P2 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 ASC_KFDIP2004L197B1U_V03 Nov. 2017 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_KFDIP2004L197B1U_V03 Nov. 2017
KFDIP2004L197B1U 价格&库存
很抱歉,暂时无法提供与“KFDIP2004L197B1U”相匹配的价格&库存,您可以联系我们找货
