Approval sheet
RFBLN 1005 Series – RoHS Compliance
MULTILAYER CERAMIC BALUN TRANSFORMER
Halogens Free Product
5GHz WLAN Band RF Application
P/N: RFBLN1005040K5T
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RFBLN1005040K5T_V02
Mar.2019
Approval sheet
FEATURES
3
1.
Miniature footprint: 1.0 X 0.5X 0.4 mm
2.
3.
4.
Low Insertion Loss
Low in-band amplitude and phase imbalance enhances system performance
LTCC process
APPLICATIONS
1.
5GHz WLAN Band RF applications
CONSTRUCTION
Top view
P4
P1
P3
PIN
Connection
PIN
Connection
1
Unbalanced port
3
Balanced port
2
Balanced port
4
GND
P2
DIMENSIONS
Figure
Symbol
Dimension (mm)
L
1.00 ± 0.10
W
0.50 ± 0.10
T
0.40 ± 0.10
A
0.10±0.10
B
0.30 ± 0.10
C
0.20 ±0.10
D
0.50 ±0.10
E
0.125±0.10
Top view
Bottom view
Side view
Side view
Page 2 of 7
Mar.2019
Approval sheet
ELECTRICAL CHARACTERISTICS
RFBLN1005040K5T
Specification
Frequency Range
4900~5950 MHz
0.55 dB max. at +25℃
Insertion Loss
0.75 dB max. at -40~ +85℃
Phase Difference
180° ± 10°
Amplitude Difference
2.5 dB max.
VSWR
2.0 max.
Unbalanced Impedance
50Ω
Balanced Impedance
100Ω
Moisture sensitivity levels
LEVEL 1 (Refer to : IPC/JEDEC J-STD-020)
Operating & Storage Condition (Component)
Operation Temperature Range: -40 ~ +85 ℃
Storage Temperature Range: -40 ~ +85 ℃
Storage Condition before Soldering (Included packaging material)
Storage Temperature Range: +5 ~ +40 ℃
Humidity: 30 to 70% relative humidity
TYPICAL ELECTRICAL PERFORMANCE
LAND PATTERN
Figure
unit: mm
Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness.
Page 3 of 7
Mar.2019
Approval sheet
RELIABILITY TEST
Test condition / Test method
Test item
Solderability
*Solder bath temperature:235 5C
Specification
At least 95% of a surface of each terminal
JIS C 0050-4.6
*Immersion time:2 0.5 sec
electrode must be covered by fresh solder.
JESD22-B102D
Resistance to soldering
Solder:Sn3Ag0.5Cu for lead-free
*Preheating temperature:120~150℃,
No mechanical damage.
1 minute.
Electrical specification shall satisfy the
*Solder temperature:2705C
descriptions in electrical characteristics under
heat
JIS C 0050-5.4
*Immersion time:101 sec
the operational temperature range within -40
~ 85°C.
Loss of metallization on the edges of each
Measurement to be made after keeping at
electrode shall not exceed 25%.
room temperature for 242 hrs
Drop Test
JIS C 0044
*Height:75 cm
Customer’s specification.
*Test Surface:Rigid surface of concrete or
steel.
*Times:6 surfaces for each units;2 times
for each side.
Vibration
JIS C 0040
~ 85°C.
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
mutually perpendicular directions)
~ 85°C.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Bending test
JIS C 0051- 7.4.1
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
The middle part of substrate shall be
pressurized by means of the pressurizing rod Electrical specification shall satisfy the
at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under
deflection becomes 1mm/s and then pressure the operational temperature range within -40
shall be maintained for 51 sec.
~ 85°C.
room temperature for 242 hours
Page 4 of 7
Mar.2019
Approval sheet
Temperature cycle
JIS C 0025
1.
303 minutes at -40C3C,
2.
10~15 minutes at room temperature,
3.
303 minutes at +85C3C,
4.
Total 100 continuous cycles
under the operational temperature range
within -40 ~ 85°C.
High temperature
JIS C 0021
*Temperature:85C2C
*Test duration:1000+24/-0 hours
~ 85°C.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:402C
JIS C 0022
*Time:1000+24/-0 hrs.
~ 85°C.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40C2C
~ 85°C.
Page 5 of 7
Mar.2019
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
BLN
100504
Walsin
RF
Product Code
Dimension code
RF device
BLN : BALUN
Per 2 digits of
Length, Width,
Thickness :
K
Unit of
dimension
0 : 0.1 mm
5
T
Application
Specification
Packing
K: WLAN RF
Application
Design Code
T : Reeled
1 : 1.0 mm
e.g. :
100504=
Length 10,
Width 05,
Thickness 04
Minimum Ordering Quantity: 4000 pcs per reel.
PACKAGING
Paper Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
Ao
Bo
D
T
W
0.67 0.10
1.14 0.10
1.50 + 0.10
0.42 0.10
8.0 0.30
E
F
Po
P1
P2
1.75 0.10
3.50 0.20
4.00 0.10
2.00 0.10
2.00 0.10
Mar.2019
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
A
B
A
B
C
178
60.0
13.5
Taping Quantity: 4000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection.
(2)
Storage environment condition.
Page 7 of 7
Products should be storage in the warehouse on the following conditions.
Temperature
: +5 to +40℃
Humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Mar.2019
很抱歉,暂时无法提供与“RFBLN1005040K5T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.831281+0.23669
- 10+1.6960610+0.21922
- 25+1.6358025+0.21143
- 50+1.5878950+0.20524
- 100+1.54211100+0.19932
- 250+1.48347250+0.19174
- 500+1.44039500+0.18617
- 1000+1.397931000+0.18068
- 国内价格 香港价格
- 4000+1.316934000+0.17022
- 8000+1.277308000+0.16509
- 12000+1.2545612000+0.16215
- 20000+1.2263520000+0.15851
- 28000+1.2080628000+0.15614
- 40000+1.1889140000+0.15367
