RFBPF1606K358Q1C
RFBPF1606K358Q1C
    WALSIN(华新科)
    6.1375GHz 中心 频率 带通 RF 滤波器 (射频) 1.975GHz 带宽 0.9dB 0603(1608 公制),3 PC 板
RFBPF1606K358Q1C 数据手册
Preliminary Product Information LTCC Multi Layer Ceramic Band Pass Filter- 1608 (0603) size – RFBPF1606K358Q1C FEATURES  Miniature footprint: 1.6 X 0.8 X 0.6 mm  Loss Insertion Loss  High Rejection Rate  LTCC process 3 APPLICATIONS  5150 ~ 7125 MHz working frequency ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 5150 ~ 7125 MHz Insertion Loss 0.9 dB typ. at +25C Attenuation 45 dB typ. @ 100 – 960 MHz 43 dB typ. @ 1160 – 1250 MHz 41 dB typ. @ 1420 – 1610 MHz 41 dB typ. @ 1690 – 2200 MHz 41 dB typ. @ 2300 – 2370 MHz 42 dB typ. @ 2400 – 2490 MHz 42 dB typ. @ 2490 – 2690 MHz 48 dB typ. @ 3300 – 3800 MHz 25 dB typ. @ 3800 – 4200 MHz 42 dB typ. @ 9600 – 9800 MHz 45 dB typ. @ 10300 – 11850 MHz 34 dB typ. @ 11850 – 14250 MHz 24 dB typ. @ 15450 – 21750 MHz VSWR 2.0 Impedance 50 Ω Power Capacity 2W max. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) HBM ESD Pass 1KV on all pins (Base on AEC-Q200-002) MM ESD Pass 200V (Base on EIA/JESD22-A115) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 C Storage Temperature Range: -40 ~ +85 C Storage Condition before Soldering (Included packaging material) Taping Quantity : 4000pcs per 7” reel Storage Temperature Range: +5 ~ +40 C Humidity: 30 to 70% relative humidity Page 1 of 3 PI_RFBPF1606K358Q1C _V01 May. 2020 Preliminary Product Information CONSTRUCTION Figure PIN Connection 1 Input 2 GND 3 Output Symbol Dimension (mm) L 1.60 ± 0.10 W 0.80 ± 0.10 T 0.60 ± 0.10 A 0.55 ± 0.10 B 0.60 ± 0.10 C 0.25 ± 0.10 D 0.23 ± 0.10 E 0.40 ± 0.10 F 0.12 ± 0.10 G 0.125 ± 0.10 Top view P1 P2 P3 DIMENSIONS Figure Top view Side view Side view Bottom view Page 2 of 3 PI_RFBPF1606K358Q1C _V01 May. 2020 Preliminary Product Information LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. CONTACT INFORMATION For more information, please contact with Walsin Technology Corporation. Tel : 886-3-475-8711 Fax : 886-3-475-5197 E mail : info@passivecomponent.com Web Site : http://www.passivecomponent.com Specification subject to change without prior notice. Page 3 of 3 PI_RFBPF1606K358Q1C _V01 May. 2020
RFBPF1606K358Q1C 价格&库存
很抱歉,暂时无法提供与“RFBPF1606K358Q1C”相匹配的价格&库存,您可以联系我们找货
