RFBPF16081G9DET
RFBPF16081G9DET
    WALSIN(华新科)
    1.915GHz Center 频率 带通 RF 滤波器 (射频) 220MHz 带宽 1.8dB 0603(1608 公制),4 PC 板
RFBPF16081G9DET 数据手册
Approval sheet RFBPF Series – 1608(0603)- RoHS Compliance MULTILAYER CERAMIC Band PASS FILTER Halogens Free Product 1805 ~ 2025 MHz Working Frequency P/N:RFBPF16081G9DET *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet FEATURES 3 1. Miniature footprint: 1.6 X 0.8 X 0.70 mm . 2. Low Insertion loss 3. High attenuation on harmonic suppressed 4. LTCC process APPLICATIONS 1. 1805 ~ 2025 MHz working frequency. CONSTRUCTION Top view P4 P3 P1 P2 PIN Connection 1 Input port 2 GND 3 Output port 4 GND DIMENSIONS Figure Symbol Dimension (mm) L 1.60 ± 0.10 W 0.80 ± 0.10 T 0.70 max. A 0.55 ± 0.10 B 0.60 ± 0.10 C 0.25 ± 0.10 D 0.23 ± 0.10 E 0.40 ± 0.10 F 0.12 ± 0.10 G 0.125 ± 0.10 H 0.21 ± 0.10 Top view Side view Side view Bottom view Page 2 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet ELECTRICAL CHARACTERISTICS RFBPF16081G9DET Specification Frequency Range 1805 ~ 2025 MHz Insertion Loss 1.8 dB max. at +25C 2.0 dB max. at -40C ~ +85C 25 dB min. @ 700 ~ 950 MHz 15 dB min. @ 950 ~ 1050 MHz Attenuation 23 dB min. @ 2400 ~ 2500 MHz 30 dB min. @ 5150 ~ 5850 MHz VSWR 2.0 max. Impedance 50 Ω Power Capacity 2W max. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operation Temperature Range: -40C ~ +85C Storage Temperature Range: -40C ~ +85C Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150C, heat JIS C 0050-5.4 No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under *Immersion time:101 sec the operational temperature range within -40 Solder:Sn3Ag0.5Cu for lead-free ~ 85°C. Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 Customer’s specification. *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: No remarkable damage or removal of the 5N ( LGA terminal series );5N(≦0603); termination. 10N(>0603) *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF BPF 1608 1G9 Walsin Product Code Dimension code RF device BPF : Per 2 digits of Length, Width: Band Pass Filter Central Frequency 1G9 :1.9 GHz D E T Application Specification Packing D :GSM900 / DCS1800 Design Code T : Reeled e.g. : 1608 = Length 16, Width 08 Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Paper Tape specifications (unit :mm) Index Ao Bo D T W Dimension (mm) 0.975 0.10 1.76 0.10 1.55 + 0.05 0.75 0.10 8.0  0.10 Index E F Po P1 P2 Dimension (mm) 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 Page 6 of 7 ASC_ RFBPF16081G9DET_V01 May. 2019 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_ RFBPF16081G9DET_V01 May. 2019
RFBPF16081G9DET 价格&库存
很抱歉,暂时无法提供与“RFBPF16081G9DET”相匹配的价格&库存,您可以联系我们找货
RFBPF16081G9DET
  • 1+2.654981+0.34347
  • 10+2.1775210+0.28170
  • 25+2.0045125+0.25932
  • 50+1.8839750+0.24372
  • 100+1.77156100+0.22918
  • 250+1.63324250+0.21129
  • 500+1.53621500+0.19874
  • 1000+1.445031000+0.18694
库存:3721
