RFBPF20123G7W2T
RFBPF20123G7W2T
    WALSIN(华新科)
    3.75GHz Center 频率 带通 RF 滤波器 (射频) 900MHz 带宽 2dB 0805(2012 公制),3 PC 板
RFBPF20123G7W2T 数据手册
Approval sheet RFBPF Series – 2012(0805)- RoHS Compliance MULTILAYER CERAMIC BAND PASS FILTER Halogens Free Product 3300 ~ 4200 MHz Working Frequency P/N: RFBPF20123G7W2T *Contents in this sheet are subject to change without prior notice. Page 1 of 8 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet FEATURES 1. Miniature footprint: 2.0 X 1.25 X 0.7 mm 2. Low Insertion loss 3. High Rejection Rate 4. LTCC process 3 APPLICATIONS 1. 3300 ~ 4200 MHz working frequency CONSTRUCTION Top view P1 P2 PIN Connection 1 Input 2 GND 3 Output P3 DIMENSIONS Figure Symbol Dimension (mm) L 2.00 ± 0.15 W 1.25 ± 0.10 T 0.70 max. A 0.95 ± 0.10 B 0.275 ± 0.10 C 0.25 ± 0.05 D 0.60 ± 0.10 E 0.175 ± 0.10 F 0.15 ± 0.10 Top view Bottom view Side view Page 2 of 8 Side view ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet ELECTRICAL CHARACTERISTICS RFBPF20123G7W2T Specification Frequency Range 3300 ~ 4200 MHz 2.0 dB max. @ 3300~4200 MHz Insertion Loss (at +25 C) 2.0 dB max. @ 3300~3800 MHz 1.5 dB max. @ 3400~3800 MHz 2.25 dB max. @ 3300~3500 MHz 2.25 dB max. @ 3500~4200 MHz Insertion Loss (at -40 ~ +85 C) 2.25 dB max. @ 3300~3800 MHz 2.25 dB max. @ 3400~3800 MHz 36 dB min. @ 450~2200 MHz 38 dB min. @ 2300~2483 MHz 33 dB min. @ 2496~2690 MHz Attenuation 25 dB min. @ 5150~5850 MHz 25 dB min. @ 6600~8400 MHz 15 dB min. @ 9900~12600 MHz 15 dB min. @ 13200~16800 MHz VSWR 2.1 max. Characteristics impedance 50 Ω Power Capacity 2W max. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart Page 3 of 8 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 4 of 8 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet RELIABILITY TEST Test item Test condition / Test method Solderability *Solder bath temperature:235  5C JIS C 0050-4.6 *Immersion time:2  0.5 sec JESD22-B102D Solder:Sn3Ag0.5Cu for lead-free Resistance to soldering heat *Preheating temperature:120~150C, JIS C 0050-5.4 1 minute. *Solder temperature:2705C *Immersion time:101 sec Solder:Sn3Ag0.5Cu for lead-free Measurement to be made after keeping at room temperature for 242 hrs Specification At least 95% of a surface of each terminal electrode must be covered by fresh solder. No mechanical damage. Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Loss of metallization on the edges of each electrode shall not exceed 25%. Drop Test *Height:75 cm No mechanical damage. JIS C 0044 *Test Surface:Rigid surface of concrete or steel. *Times:6 surfaces for each units;2 times for each side. Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Vibration *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. JIS C 0040 *Total amplitude:1.5mm Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Customer’s specification. *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) Adhesive Strength *Pressurizing force: of Termination 5N (LGA terminal series);5N(≦0603); 10N(>0603) JIS C 0051- 7.4.3 No remarkable damage or removal of the termination. *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be pressurized by means of the pressurizing rod at a rate of about 1 mm/s per second until the deflection becomes 1mm/s and then pressure shall be maintained for 51 sec. No mechanical damage. Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 5 of 8 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet Temperature cycle 1. 303 minutes at -40C3C, No mechanical damage. JIS C 0025 2. 10~15 minutes at room temperature, 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Total 100 continuous cycles Measurement to be made after keeping at room temperature for 242 hrs High temperature *Temperature:85C2C No mechanical damage. JIS C 0021 *Test duration:1000+24/-0 hours Measurement to be made after keeping at room temperature for 242 hrs Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity *Humidity:90% to 95% R.H. No mechanical damage. (steady conditions) *Temperature:402C JIS C 0022 *Time:1000+24/-0 hrs. Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs Page 6 of 8 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF BPF 2012 Walsin Product Code Dimension code RF device BPF : Per 2 digits of Length, Width, Band Pass Filter 3G7 W Central Frequency 2 T Application Specification Packing W: Wi-Max Design code T:Reeled 3G7 : 3.7 GHz e.g. : 2012= Length 2.0 mm, Width 1.2 mm, Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 7 of 8 ΦD Ao 1.40 ± 0.10 Bo 2.25 ± 0.10 1.55 ± 0.05 T 0.75 ± 0.10 W 8.00 ± 0.10 E 1.75± 0.10 F 3.50 ± 0.05 Po 4.00 ± 0.10 P1 4.00 ± 0.10 P2 2.00 ± 0.05 ASC_RFBPF20123G7W2T_V01 Dec. 2019 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 8 of 8 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFBPF20123G7W2T_V01 Dec. 2019
RFBPF20123G7W2T 价格&库存
很抱歉,暂时无法提供与“RFBPF20123G7W2T”相匹配的价格&库存,您可以联系我们找货
