RFBPF20124G7W6T
RFBPF20124G7W6T
    WALSIN(华新科)
    4.7GHz 中心 频率 带通 RF 滤波器 (射频) 600MHz 带宽 2dB 0805(2012 公制),3 PC 板
RFBPF20124G7W6T 数据手册
Approval sheet RFBPF Series – 2012(0805)- RoHS Compliance MULTILAYER CERAMIC BAND PASS FILTER Halogens Free Product 4400 ~ 5000 MHz Working Frequency P/N: RFBPF20124G7W6T *Contents in this sheet are subject to change without prior notice. Page 1 of 8 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet FEATURES 1. Miniature footprint: 2.0 X 1.25 X 0.7 mm 2. Low Insertion loss 3. High Rejection Rate 4. LTCC process 3 APPLICATIONS 1. 4400 ~ 5000 MHz working frequency CONSTRUCTION Top view P1 P2 PIN Connection 1 Input 2 GND 3 Output P3 DIMENSIONS Figure Symbol Dimension (mm) L 2.00 ± 0.15 W 1.25 ± 0.15 T 0.70 max. A 0.95 ± 0.10 B 0.275 ± 0.10 C 0.25 ± 0.10 D 0.60 ± 0.10 E 0.175 ± 0.10 F 0.15 ± 0.10 Top view Bottom view Side view Page 2 of 8 Side view ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet ELECTRICAL CHARACTERISTICS RFBPF20124G7W6T Specification Frequency Range 4400 ~ 5000 MHz 2.00 dB max. @ 4400 ~ 4600 MHz 1.60 dB max. @ 4600 ~ 4800 MHz Insertion Loss (at 25℃) 1.80 dB max. @ 4800 ~ 5000 MHz 2.30 dB max. @ 4400 ~ 4600 MHz 1.80 dB max. @ 4600 ~ 4800 MHz Insertion Loss (at -40 ~ +85℃) 2.30 dB max. @ 4800 ~ 5000 MHz 37 dB min. @ 450 ~ 2200 MHz 37 dB min. @ 2300 ~ 2483 MHz 33 dB min. @ 2496 ~ 2690 MHz 15 dB min. @ 5490 ~ 5670 MHz 25 dB min. @ 5670 ~ 5950 MHz Attenuation 25 dB min. @ 6200 ~ 8000 MHz 25 dB min. @ 8800 ~ 10000 MHz 15 dB min. @ 13200 ~ 15000 MHz 15 dB min. @ 17600 ~ 20000 MHz VSWR 2.0 max. Characteristics impedance 50 Ω Power Capacity 2W max. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) HBM ESD Pass 1KV on all pins (Base on AEC-Q200-002) HBM ESD Pass 200V (Base on EIA/JESD22-A115) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart Page 3 of 8 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 4 of 8 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet RELIABILITY TEST Test condition / Test method Test item Specification Solderability *Solder bath temperature:235  5C At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the heat JIS C 0050-5.4 *Solder temperature:2705C descriptions in electrical characteristics under the operational temperature range within -40 *Immersion time:101 sec Solder:Sn3Ag0.5Cu for lead-free Measurement to be made after keeping at ~ 85°C. Loss of metallization on the edges of each electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. Customer’s specification. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: 5N (LGA terminal series);5N(≦0603); No remarkable damage or removal of the termination. 10N(>0603) *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 5 of 8 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Total 100 continuous cycles Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. descriptions in electrical characteristics under the operational temperature range within -40 Measurement to be made after keeping at ~ 85°C. room temperature for 242 hrs ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 6 of 8 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, This product could sustain by reflow process three times, and the temperature below 260℃. Fig 2. Infrared soldering profile ORDERING CODE RF BPF 2012 4G7 Walsin Product Code Dimension code RF device BPF : Per 2 digits of Length, Width, Band Pass Filter W Central Frequency 6 T Application Specification Packing W: Wi-Max Design code T : Reeled 4G7 : 4.7 GHz e.g. : 2012= Length 2.0 mm, Width 1.2 mm, Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 7 of 8 ΦD Ao 1.40 ± 0.10 Bo 2.25 ± 0.10 1.55 ± 0.05 T 0.75 ± 0.10 W 8.00 ± 0.10 E 1.75± 0.10 F 3.50 ± 0.05 Po 4.00 ± 0.10 P1 4.00 ± 0.10 P2 2.00 ± 0.05 ASC_RFBPF20124G7W6T_V01 May. 2020 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 8 of 8 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFBPF20124G7W6T_V01 May. 2020
RFBPF20124G7W6T 价格&库存
很抱歉,暂时无法提供与“RFBPF20124G7W6T”相匹配的价格&库存,您可以联系我们找货
RFBPF20124G7W6T
  • 2000+1.413242000+0.18258
  • 4000+1.329404000+0.17175
  • 6000+1.282696000+0.16571
  • 10000+1.2261410000+0.15841
  • 14000+1.1902714000+0.15378
  • 20000+1.1533920000+0.14901
库存:7907
RFBPF20124G7W6T
  • 1+2.819281+0.36423
  • 10+2.2596910+0.29193
  • 25+2.0824225+0.26903
  • 50+1.9583350+0.25300
  • 100+1.84161100+0.23792
  • 250+1.69845250+0.21943
  • 500+1.59734500+0.20636
  • 1000+1.502441000+0.19410
库存:7907
RFBPF20124G7W6T
    • 1+0.55145
    • 200+0.21341
    • 500+0.20596
    • 1000+0.20218
