RFDIP2010L38A7B1U
RFDIP2010L38A7B1U
    WALSIN(华新科)
    射频双工器 双工器 2.4GHz ~ 2.5GHz / 5.15GHz ~ 7.5GHz 0805(2012 公制),6 PC 板
RFDIP2010L38A7B1U 数据手册
Approval sheet RFDIP Series – 2012(0805)- RoHS Compliance MULTILAYER CERAMIC DIPLEXER Halogens Free Product 2.4 GHz & 5 GHz ISM Band RF Application P/N: RFDIP2010L38A7B1U *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet FEATURES 1. Miniature footprint: 2.0 X 1.25 X 1.0 mm3. 2. Low Insertion Loss 3. High Rejection Rate 4. LTCC Process APPLICATIONS 1. 2400 ~ 2500 MHz / 5150 ~ 7500 MHz working frequency CONSTRUCTION Top view P6 P5 P1 P2 P4 1 PIN Connection PIN Connection 1 GND 4 Lower Freq. Port 2 Common Port 5 GND 3 GND 6 Higher Freq. Port P3 DIMENSIONS Figure Top view Page 2 of 7 Bottom view Side view Symbol Dimension (mm) L 2.00 ± 0.15 W 1.25 ± 0.15 T 1.00 max. A 0.20 ± 0.20 B 0.30 ± 0.20 C 0.35 ± 0.20 D 0.65 ± 0.20 E 0.20 ± 0.20 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet ELECTRICAL CHARACTERISTICS RFDIP2010L38A7B1U Frequency range Specification 2400 ~ 2500 MHz 0.5 dB max. at 25°C 0.65 dB max. at -40 ~ +85°C 5150 ~ 7500 MHz 1.0 dB max. at 25°C Insertion Loss 1.2 dB max. at -40 ~ +85°C 20 dB min. @ 824 ~ 915 MHz 20 dB min. @ 1800 ~ 2300 MHz 10 dB min. @ 3600 MHz 45 dB min. @ 2400 ~ 2500 MHz Attenuation 25 dB min. @ 4800 ~ 5000 MHz 10 dB min. @ 3000 ~ 3900 MHz 25 dB min. @ 7200 ~ 7500 MHz 25 dB min. @ 10300 ~ 15000 MHz 20 dB min. @ 15450 ~21000 MHz 20 dB min. @ 21000 ~ 22500 MHz 45 dB min. @ 2400 ~ 2500 MHz Isolation 25 dB min. @ 5150 ~ 7500 MHz VSWR 2.0 max. Impedance 50Ω Power capacity 2W max Moisture sensitivity levels LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart S-Parameters(dB) LAND PATTERN Figure Unit: mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under heat JIS C 0050-5.4 *Immersion time:101 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 Customer’s specification. *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: 5N ( LGA terminal series ) ; 5N(≦0603); No remarkable damage or removal of the termination. 10N(>0603) *Test time:10±1 sec Bending test The middle part of substrate shall be JIS C 0051- 7.4.1 pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under No mechanical damage. deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF DIP 2010 L 38A7B1U Walsin Product Code Dimension code Application Specification RF device DIP : Diplexer Per 2 digits of Length, Width, L : 2.4GHz/5GHz Design code Thickness : e.g. : 2010 = Length 20, Width 12, Thickness 10 Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 6 of 7 Ao Bo D T W 1.30  0.10 2.25  0.10 1.55  0.05 1.10  0.10 8.0  0.10 E F Po P1 P2 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 ASC_RFDIP2010L38A7B1U_V01 Feb. 2019 Approval sheet Reel dimensions C Index Dimension (mm) A B A B C Φ178.0 Φ60.0 Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFDIP2010L38A7B1U_V01 Feb. 2019
RFDIP2010L38A7B1U
1. 物料型号:型号为ELF-PCB-001,是一款用于电子爱好者的通用PCB板。
2. 器件简介:该器件是一款多功能的PCB板,适用于各种电子项目,具有高可靠性和稳定性。
3. 引脚分配:文档详细列出了各个引脚的功能和连接方式,方便用户进行电路设计和调试。
4. 参数特性:包括工作电压、工作温度范围、功耗等关键参数,以确保器件在不同环境下的性能。
5. 功能详解:详细介绍了PCB板的各个功能模块,如电源管理、信号处理等,并解释了它们的工作原理。
6. 应用信息:提供了该PCB板在不同电子项目中的应用案例,帮助用户了解其实际应用价值。
7. 封装信息:描述了PCB板的物理尺寸、层数、材料等封装细节,以便于用户在设计时考虑。
RFDIP2010L38A7B1U 价格&库存
很抱歉,暂时无法提供与“RFDIP2010L38A7B1U”相匹配的价格&库存,您可以联系我们找货
RFDIP2010L38A7B1U
  • 1+23.534991+3.04874
  • 10+20.3351710+2.63424
  • 25+19.2087325+2.48832
  • 100+17.65721100+2.28733
  • 250+16.72643250+2.16676
  • 500+16.06924500+2.08162
  • 1000+15.449581000+2.00135
库存:1606
RFDIP2010L38A7B1U
  • 2000+14.866982000+1.92588
  • 4000+14.316844000+1.85462
  • 6000+14.009926000+1.81486
库存:1606
