Approval sheet
Dipole ANTENNA
433MHz Working Frequency
Halogens Free Product
P/N: RFDPA131000SBUB802
Customer:
Customer ‘s Part No.:
Approval No.:
Issue Date:
*Contents in this sheet are subject to change without prior notice.
Page 1 of 11
RFDPA131000SBUB802_V01
Feb. 2017
Approval sheet
Version
V01
Page 2 of 11
Date
2017
Feb.
Description
New Release
Author
SHLEE
Feb. 2017
Approval sheet
ELECTRICAL CHARACTERISTICS
Item
Specification
Frequency Range
433 MHz(note-1)
Impedance
50 Ohm Nominal
VSWR
2 Max.
Radiation
Omni-directional
Gain(peak)
1.3dBi
Polarization
Admitted Power
Linear Vertical
1W
*note-1: Electrical characteristics will depend on customer’s final application.
MATERIAL TABLE
Items
Description
Cable
RG178(Brown)
Antenna Cover
ABS(Black)
Antenna Base
PC+PBT(Black)
Connector
Reverse SMA Plug(Black)
PCB
FR4
Sponge
Black
ORDERING RULE
RF
DPA
Type Code
Product
Code
1310
Dipole
Dimension
(Unit: mm)
00
S
Cable
Connector
Length (unit:
Brand
cm)
B
U
B
Type of Connector
Application
Project
status
A: N
C:MCX
D:IPEX III
Per 2 digits of
length, width
Walsin RF
Device
DPA:
Dipole
e.g.: 1510
Antenna
Length
150.8mm,
Width 10mm
2 digits for
E: IPEX IV
F: IPEX A13 A: Reverse Female
B: Reverse Male
cable length
H: Hirose
F: Female
I: IPEX
M: Male
e.g.: 00
M: MMCX
N: None
None Cable
S: SMA
T: TNC
U:MURATA
8
02
Wire
Project
Diameter
0: 0GHz
3: 3GHz
6: 6GHz
0:None
A: 2.4GHz ISM band
B: GSM 900/1800
1:∅ 0.81
G: GPS band
B: MP
T:Durin
g Test
L: 2.4/5.2/5.8 GHz
X: Pile Run 7:∅ 1.37
tri-band
N: NFC
T: LTE band
W: WCDMA band
8:RG178
dual band
3:∅ 1.13
6:RG316
01~99
series
number
N: None
Page 3 of 11
Feb. 2017
Approval sheet
DIMENSIONS
Page 4 of 11
Feb. 2017
Approval sheet
Test Report
■EXPERIMENTAL SETUP
Page 5 of 11
Feb. 2017
Approval sheet
Page 6 of 11
Feb. 2017
Approval sheet
■ELECTRICAL CHARACTERISTICS
VSWR
Page 7 of 11
Feb. 2017
Approval sheet
■Antenna and Peak Gain
433MHz
Page 8 of 11
Feb. 2017
Approval sheet
■RADIATION PATTERN
433 MHz
Phi=0.00deg
Gain . dB
Page 9 of 11
Feb. 2017
Approval sheet
Phi=90.00deg
Gain . dB
Page 10 of 11
Feb. 2017
Approval sheet
Theta=90.00deg
Gain . dB
Page 11 of 11
Feb. 2017
很抱歉,暂时无法提供与“RFDPA131000SBUB802”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+84.719941+11.00958
- 10+65.8983710+8.56366
- 25+61.2026025+7.95344
- 100+56.04037100+7.28259
- 250+53.57934250+6.96278
- 600+51.75201600+6.72531
- 1200+50.592281200+6.57460
