RFDPA131015IMBB301
RFDPA131015IMBB301
    WALSIN(华新科)
    RF ANT 863-928MHZ IPEX DIPOLE
RFDPA131015IMBB301 数据手册
Approval sheet Dipole ANTENNA 863~928 MHz Working Frequency Halogens Free Product P/N: RFDPA131015IMBB301 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet Version V01 Page 2 of 11 Date 2015 Dec. Description New Release RFDPA131015IMBB301_V01 Author SHLEE Dec. 2015 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 863 ~ 928 MHz (Note-1) Gain 0.90 dBi Return Loss -10 dB (Max) VSWR 2 max. Polarization Linear Radiation Pattern Omni-directional Impedance 50 *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Antenna Cover Items Description ABS,Black Antenna Base PC+PBT,Black Cable Coaxial Cableψ1.13,Black PCB FR4 Connector IPEX Compatible ORDERING RULE RF Type Code DPA Product Code 1310 15 I Dipole Cable Length Connector Dimension (unit: cm) Brand (Unit: mm) M of length, width Walsin RF Device DPA: Dipole e.g.: 1713 Antenna Length 172mm, Width ∅13.0mm 2 digits for cable length e.g.:10 Cable C:MCX A: 2.4GHz D:IPEX III ISM band E: IPEX IV T: TNC U:MURATA N: None Page 3 of 11 A: Reverse Female F: IPEX A13 B: Reverse H: Hirose Male I: IPEX F: Female M: MMCX Length:10.5cm S: SMA B 3 01 Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: N Per 2 digits B Type of Application Connector M: Male N: None B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet DIMENSIONS Page 4 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet Test Report ■Experimental Setup Page 5 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet ■ELECTRICAL CHARACTERISTICS Return Loss Page 6 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet ■Antenna and Peak Gain Page 7 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet ■RADIATION PATTERN X-Z Plane Phi=0.00deg Gain . dB Page 8 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 9 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 10 of 11 RFDPA131015IMBB301_V01 Dec. 2015 Approval sheet Package Page 11 of 11 RFDPA131015IMBB301_V01 Dec. 2015
RFDPA131015IMBB301 价格&库存
很抱歉,暂时无法提供与“RFDPA131015IMBB301”相匹配的价格&库存,您可以联系我们找货
RFDPA131015IMBB301
  • 1+84.780211+11.00293
RFDPA131015IMBB301
    • 1+19.82880
    • 200+7.67880
    • 600+7.40880
    • 1200+7.27920
