RFDPA191300SMBB801
RFDPA191300SMBB801
    WALSIN(华新科)
    RF ANT 840-868MHZ SMA DIPOLE
RFDPA191300SMBB801 数据手册
Approval sheet Dipole ANTENNA 840~868 MHz Working Frequency Halogens Free Product P/N: RFDPA191300SMBB801 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet Version V01 V02 Page 2 of 11 Date 2016 May. 2016 May. Description Author New Release SHLEE 變更 PCB SHLEE RFDPA191300SMBB801_V02 May. 2016 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 840 ~ 868 GHz (Note-1) Gain 1.51 dBi Return Loss -10dB(Max) VSWR 2 max. Polarization Linear Radiation Pattern Omni-directional Impedance 50 *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Items Description Cable RG178(Brown) Antenna Down Base PC+PBT(Black) Antenna Up Base PC(Black) Rivet POM(Black) Antenna Cover TPEE(Black) PCB FR4 Heat Shrink Tube CB-HFT(Black) SMA Plug Black ORDERING RULE RF DPA Product Code Type Code 1913 00 S Dipole Cable Connector Dimension Length (unit: Brand (Unit: mm) cm) M Type of Connector Walsin RF Device DPA: Dipole Antenna 01 Application Project A: 2.4GHz D:IPEX III ISM band E: IPEX IV U:MURATA N: None Page 3 of 11 8 Wire Diameter C:MCX A: Reverse Female F: IPEX A13 B: cable length Reverse H: Hirose e.g.: 1713 Male I: IPEX Length e.g.: 00 F: Female M: MMCX 172mm, None Cable M: Male S: SMA Width 13mm N: None T: TNC length, width 2 digits for B Project status 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: N Per 2 digits of B B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFDPA191300SMBB801_V02 May. 2016 Approval sheet DIMENSIONS Page 4 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet Test Report ■ Experimental Setup Page 5 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet ■ELECTRICAL CHARACTERISTICS Return Loss Page 6 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet ■Antenna Efficiency & Peak Gain Page 7 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet ■RADIATION PATTERN 840~868 MHz Phi=0.00deg Gain . dB Page 8 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet Phi=90.00deg Gain . dB Page 9 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet Theta=90.00deg Gain . dB Page 10 of 11 RFDPA191300SMBB801_V02 May. 2016 Approval sheet PACKAGE Page 11 of 11 RFDPA191300SMBB801_V02 May. 2016
RFDPA191300SMBB801 价格&库存
很抱歉,暂时无法提供与“RFDPA191300SMBB801”相匹配的价格&库存,您可以联系我们找货
