RFDPA131000SMRB801
RFDPA131000SMRB801
    WALSIN(华新科)
    895.5MHz 鞭状,倾斜 RF 天线 863MHz ~ 928MHz 3.01dBi SMA 公头 连接器安装
RFDPA131000SMRB801 数据手册
Approval sheet Dipole ANTENNA 863~928MHz Working Frequency Halogens Free Product P/N: RFDPA131000SMRB801 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet Version V01 Page 2 of 10 Date 2017 Jan. Description New Release RFDPA131000SMRB801_V01 Author SHLEE Jan.2017 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 863MHz~928 MHz(note-1) Impedance 50 Ohm Nominal VSWR 2.5Max. Radiation Omni-directional Gain(peak) 3.01 dBi Polarization Admitted Power Linear Vertical 1W *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description Cable RG178(Brown) Antenna Cover ABS(Black) Antenna Base PC+PBT(Black) Connector Standrad SMA Plug(Black) PCB FR4 Color Ring PP(White) Sponge Black ORDERING RULE RF DPA Type Code Product Code 1310 Dipole Dimension (Unit: mm) 00 S Cable Connector Length (unit: Brand cm) M R B Type of Connector Application Project status A: N D:IPEX III 0: 0GHz 3: 3GHz 6: 6GHz E: IPEX IV A: 2.4GHz ISM band C:MCX Per 2 digits of length, width Walsin RF Device DPA: Dipole e.g.: 1510 Antenna Length 150.8mm, Width 10mm 2 digits for F: IPEX A13 A: Reverse Female B: Reverse Male cable length H: Hirose F: Female I: IPEX M: Male e.g.: 00 M: MMCX N: None None Cable S: SMA T: TNC U:MURATA B: GSM 900/1800 8 Wire Project Diameter 0:None 1:∅ 0.81 G: GPS band B: MP T:Durin g Test L: 2.4/5.2/5.8 GHz X: Pile Run 7:∅ 1.37 tri-band N: NFC T: LTE band W: WCDMA band 8:RG178 dual band 01 3:∅ 1.13 6:RG316 01~99 series number N: None Page 3 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet DIMENSIONS Page 4 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet Test Report ■EXPERIMENTAL SETUP Page 5 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet ■ELECTRICAL CHARACTERISTICS Return Loss Page 6 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet ■Antenna and Peak Gain Page 7 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet ■RADIATION PATTERN 863~928 MHz Phi=0.00deg Gain . dB Page 8 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet Phi=90.00deg Gain . dB Page 9 of 10 RFDPA131000SMRB801_V01 Jan.2017 Approval sheet Theta=90.00deg Gain . dB Page 10 of 10 RFDPA131000SMRB801_V01 Jan.2017
RFDPA131000SMRB801 价格&库存
很抱歉,暂时无法提供与“RFDPA131000SMRB801”相匹配的价格&库存,您可以联系我们找货
RFDPA131000SMRB801
    • 1+19.82880
    • 200+7.67880
    • 600+7.40880
    • 1200+7.27920
    RFDPA131000SMRB801
    • 1+84.831441+11.00958
    • 10+65.9851010+8.56366
    • 25+61.2831525+7.95344
    • 100+56.11412100+7.28259
    • 250+53.64986250+6.96278
    • 600+51.82012600+6.72531
    • 1200+50.658871200+6.57460
    库存:465
