RFDPA870945IMBB301
RFDPA870945IMBB301
    WALSIN(华新科)
    RF ANT 2.4GHZ 450MM IPEX DIPOLE
RFDPA870945IMBB301 数据手册
Approval sheet Dipole ANTENNA 802.11 b/g/n Series 2.4 GHz Single Band Working Frequency Halogens Free Product P/N: RFDPA870945IMBB301 Customer: Module Name: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 12 RFDPA870945IMBB301_V01 May. 2016 Approval sheet Version V01 Page 2 of 12 Date 2016 May. Description New Release RFDPA870945IMBB301_V01 Author SHLEE May. 2016 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 2.4 ~ 2.5 GHz (Note-1) Gain 1.16 dBi Return Loss -10dB(Max) VSWR 1.9 max. Polarization Linear Radiation Pattern Omni-directional Impedance 50 *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Cable Items Description Coaxial Cable ψ1.13(Gray) Antenna Cover TPEE Antenna Down Base PC/PBT Antenna UP Base PC Connector IPEX Compatible Color Black PCB FR4 ORDERING RULE RF DPA Product Code Type Code Walsin RF Device DPA: Dipole Antenna Page 3 of 12 8709 45 I Dipole Cable Connector Dimension Length (unit: Brand (Unit: mm) cm) A: N C:MCX D:IPEX III Per 2 digits of E: IPEX IV 2 digits for length, width cable length F: IPEX A13 H: Hirose e.g.: 8709 I: IPEX e.g.: 45 Length M: MMCX Cable 87mm, Width Length:45cm S: SMA 9.4mm T: TNC U:MURATA N: None M B B 3 01 Type of Connector Application Project status Wire Diameter Project A: Reverse Female B: Reverse Male F: Female M: Male N: None 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: 2.4GHz ISM band B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz tri-band N: NFC T:LTE band W: WCDMA band RFDPA870945IMBB301_V01 0:None 1:∅0.81 3:∅1.13 6:RG316 7:∅1.37 8:RG178 01~99 series number May. 2016 Approval sheet DIMENSIONS Page 4 of 12 RFDPA870945IMBB301_V01 May. 2016
RFDPA870945IMBB301 价格&库存
很抱歉,暂时无法提供与“RFDPA870945IMBB301”相匹配的价格&库存,您可以联系我们找货
