RFDSB121013RU0T
RFDSB121013RU0T
    WALSIN(华新科)
    6GHz 频率 平衡 RF 滤波器 (射频) 带宽
RFDSB121013RU0T 数据手册
Approval sheet RFDSB Series – 1210(0504)- RoHS Compliance MULTILAYER CERAMIC DIFFERENTIAL SIGNAL BALANCER P/N: RFDSB121013RU0T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet FEATURES 3  Miniature footprint: 1.25 X 1.00 X 0.83 mm , Non-Magnetic LTCC product applying delay line technology  Novel common mode removal by combination of absorption and time domain dispersing reflection.  High attenuation for common mode noise over wide frequency range  Low insertion loss and strong balance capability for high-speed differential signal. APPLICATIONS 1. USB 3.1 GEN.2, Type C (10 Gb/s) 2. PCI Express Gen.4 (16 Gb/s) CONSTRUCTION Figure PIN Connection 1 IN/OUT 2 IN/OUT 3 GND 4 OUT/ IN 5 OUT/ IN 6 GND Top view DIMENSIONS Figure Top view Symbol Dimension (mm) L 1.25 ± 0.10 W 1.00 ± 0.10 T 0.83 ± 0.10 A 0.30 ± 0.10 B 0.25 ± 0.10 C 0.20 ± 0.10 D 0.275 ± 0.10 E 0.20 ± 0.10 F 0.30 ± 0.10 G 0.55 ± 0.10 Side view Side view Bottom view Page 2 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range DC~12,000 MHz Sdd21 -1.0 dB or more @ 5,000 MHz Differential mode Sdd21 -2.0 dB or more @ 8,000 MHz Common mode Scc21 -15.0 dB or less @ 2,400 MHz Insulation resistance 100 MΩ min. (DC 50 V) DC resistance 2Ω max. pin1-pin5 and pin2-pin4 Delay time 130 ps typ. Impedance 95±10 Ω Temperature coefficient Delay time : +200 ppm typ. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity -10 -20 -30 0 5 10 15 Frequency [GHz] tr/tf= 20 ps/20 ps FR4 2 inch TX DSB Output Waveform 10 Gb/s, 30 ps Skew 16 Gb/s, 20 ps Skew 20 Vp Vn RX 150 100 50 0 -50 -100 -150 25.0 Vp 10 Gb/s, Without DSB Vn Vp & Vn [%] Vp & Vn [%] Sdd21 25.5 26.0 26.5 27.0 150 100 50 0 -50 -100 -150 25.0 10 Gb/s, With DSB 25.5 Time [ns] 150 100 50 0 -50 -100 -150 25.0 26.0 26.5 27.0 Time [ns] 16 Gb/s, Without DSB Vp Vn 150 100 50 0 -50 -100 -150 27.0 25.0 16 Gb/s, With DSB Vp & Vn [%] Scc21 0 Vp & Vn [%] Magnitude [dB] Frequency Characteristics TYPICAL ELECTRICAL PERFORMANCE Balance Capability for 10 G & 16 Gb/s Signal (PRBS Simulation) 25.5 26.0 26.5 Time [ns] 25.5 26.0 26.5 27.0 Time [ns] SOLDER LAND PATTERN Figure Unit : mm Page 3 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet Mechanical Test Test item Solderability Ref. JIS C 0050-4.6 Test condition / Test method *Ethanol solution of rosin, 25(wt)% *Pre-Heating:150C, 60sec Specification At least 95% of a surface of each terminal electrode must be covered by fresh solder. *Solder bath temperature:245  3C *Immersion time:3  1 sec *Solder:Sn3Ag0.5Cu for lead-free Resistance to soldering heat *Ethanol solution of rosin, 25(wt)% Ref. JIS C 0050-5.4 *Preheating temperature:150℃. 60sec Meet Table 1. Table 1 Appearance *Solder temperature:2705C No damaged Electrical specification *Immersion time:101 sec Differential *Solder:Sn3Ag0.5Cu for lead-free Drop Ref. JIS C 0044 mode characteristics room temperature for 4 to 48 hrs Electrical specification Common *Height:1m mode shall satisfy the descriptions in electrical characteristics. or steel. I.R. *The number of times : 3 times Ref. JIS C 0040 descriptions in electrical Measurement to be made after keeping at *Test Surface:Rigid surface of concrete Vibration shall satisfy the DC *Frequency:10Hz~55Hz~10Hz(1min) 100MΩ min. 2Ω max. pin1-pin5 and Resistance *Total amplitude:1.5mm pin2-pin4 Change *Test time:A period of 2 hours in each of 3 mutually perpendicular directions. Bending Strength Ref. JIS C 0051- 7.4.1 The middle part of substrate shall be Meet Table 2. pressurized by means of the pressurizing Table 2 rod at a rate of about 0.5 mm/s per Appearance second until the deflection becomes 1mm No damaged 2Ω max. pin1- and then pressure shall be maintained for DC Resistance pin5 and pin2- 30 sec. Change pin4 Adhesive Strength *Pressurizing force: No remarkable damage or removal of the of Termination 5N(≦0603);10N(>0603) termination. JIS C 0051- 7.4.3 *Test time:10±1 sec Page 4 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet Environmental Performance Test item Temperature cycle Ref. JIS C 0025 Test condition / Test method 1. 30(+3,-0) min at -40C(+0C,-3C) 2. within 3 minutes at ordinary temp. 3. 30(+3,-0) minutes at +85C(+3C,-0C) 4. within 3 minutes at ordinary temp. Specification Meet Table 1. Total 100 cycles Measurement to be made after keeping at room temperature for 4 to 48 hours Humidity Ref. JIS C 0022 *Humidity:90% to 95% R.H. *Temperature:402C *Time:1000hrs (+48/-0 hrs.) Measurement to be made after keeping at room temperature for 4 to 48 hours Heat life Ref. JIS C5101-10 4.15 *Temperature:85C2C *Test Voltage:5V *Time:1000hrs (+48/-0 hrs.) Measurement to be made after keeping at room temperature for 4 to 48 hours Cold Resistance Ref. JIS C 0020 *Temperature:-40C2C *Time:1000hrs (+48/-0 hrs.) Measurement to be made after keeping at room temperature for 4 to 48 hours Page 5 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF DSB 1210 13R U 0 T Walsin Product Code Dimension code Delay time Application Specification Packing RF device DSB: Per 2 digits of Length, Width. 130 ps USB 3.1 Design Code T : Reeled Differential Signal Balancer e.g. : 1210= Length 12 mm, Width 10 mm, Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index A0 B0 ΦD T W Dimension(mm) 1.20±0.10 1.40±0.10 1.50±0.10 0.90±0.10 8.00±0.10 Index E F P0 P1 P2 Dimension(mm) 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 Page 6 of 7 ASC_RFDSB121013RU0T_V01 Mar. 2018 Approval sheet Reel dimensions C Index Dimension (mm) A Φ178.0 B Φ60.0 A B C Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.         Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFDSB121013RU0T_V01 Mar. 2018
RFDSB121013RU0T 价格&库存
很抱歉,暂时无法提供与“RFDSB121013RU0T”相匹配的价格&库存,您可以联系我们找货
