RFMTA010504NNRB002
RFMTA010504NNRB002
    WALSIN(华新科)
    RF ANT 863-928MHZ METAL
RFMTA010504NNRB002 数据手册
Approval sheet Metal ANTENNA 863~928 MHz Working Frequency Halogens Free Product P/N: RFMTA010504NNRB002 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 4 RFMTA010504NNRB002 _V01 May.2017 Approval sheet Version V01 Page 2 of 4 Date 2017 May. Description New Release RFMTA010504NNRB002 _V01 Author PIPI May.2017 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 863~928 MHz (Note-1) Impedance 50 Ohm Nominal VSWR Return Loss 863~872MHz: 1.5 (MAX) 907~928MHz: 2.0 (MAX) -10 dB (Max) Radiation Omni-directional Peak Gain 863~872MHz: 1.64dBi 907~928MHz: 2.05 dBi Polarization Linear Vertical Admitted Power 1W Weight 0.46g ±1% *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Items Description Phosphor Bronze Ø0.8 Antenna ORDERING RULE RF MTA Product Code Type Code 0105 04 N Metal Cable Connector Dimension Length (unit: Brand (Unit: mm) cm) Per 2 digits of length, width Walsin RF Device MTA: Metal Antenna e.g.:3512 Length 35.00mm, Width 12.80mm 2 digits for cable length e.g.:04 Cable Length: 2.85cm R B 0 02 Application Project status Wire Diameter Project A: N 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz C:MCX A: 2.4GHz D:IPEX III E: IPEX IV ISM band A: Reverse Female F: IPEX A13 B: Reverse H: Hirose Male I: IPEX F: Female M: MMCX S: SMA T: TNC U:MURATA N: None Page 3 of 4 N Type of Connector M: Male N: None B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFMTA010504NNRB002 _V01 May.2017 Approval sheet DIMENSIONS Page 4 of 4 RFMTA010504NNRB002 _V01 May.2017
RFMTA010504NNRB002 价格&库存
很抱歉,暂时无法提供与“RFMTA010504NNRB002”相匹配的价格&库存,您可以联系我们找货
