RFLPF1608060F1T
RFLPF1608060F1T
    WALSIN(华新科)
    1.6815GHz 中心 频率 低通 RF 滤波器 (射频) 2.017GHz 带宽 0.5dB 0603(1608 公制),3 PC 板
RFLPF1608060F1T 数据手册
Approval sheet RFLPF Series – 1608(0603)- RoHS Compliance MULTILAYER CERAMIC LOW PASS FILTER Halogens Free Product 673~2690 MHz Working Frequency P/N: RFLPF1608060F1T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFLPF1608060F1T_V01 Dec. 2018 Approval sheet FEATURES 3 1. Miniature footprint: 1.6 X 0.8 X 0.65 mm 2. Low Insertion loss 3. High attenuation on harmonic suppressed 4. LTCC process APPLICATIONS 1. 673~2690 MHz Working Frequency CONSTRUCTION Top view P1 P2 PIN Definition P1 I/O Port P2 GND P3 I/O Port P3 DIMENSIONS Figure Page 2 of 7 ASC_RFLPF1608060F1T_V01 Symbol Dimension (mm) L 1.60 ± 0.10 W 0.80 ± 0.10 T 0.65 max. A 0.60 ± 0.10 B 0.25 ± 0.10 C 0.25 ± 0.10 D 0.40 ± 0.10 E 0.10 ± 0.05 F 0.10 ± 0.05 Dec. 2018 Approval sheet ELECTRICAL CHARACTERISTICS RFLPF1608060F1T Specification Frequency range 673 ~ 2690 MHz 0.5 dB max. at +25°C Insertion Loss 0.7 dB max. at -40°C ~ +85°C 35 dB min. @ 4950~ 6000 MHz 35 dB min. @ 6000~ 7500 MHz Attenuation 35 dB min. @ 7500~ 8100 MHz 35 dB min. @ 8100~ 10500 MHz 27 dB min. @ 10500~ 12500 MHz VSWR 2.0 max. Impedance 50 Ω Power Capacity 2W max Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_RFLPF1608060F1T_V01 Dec. 2018 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under heat JIS C 0050-5.4 *Immersion time:101 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. Customer’s specification. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: No remarkable damage or removal of the 5N ( LGA terminal series) ; 5N(≦0603); termination. 10N(>0603) *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_RFLPF1608060F1T_V01 Dec. 2018 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_RFLPF1608060F1T_V01 Dec. 2018 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF LPF Walsin Product Code Dimension code RF device LPF : Per 2 digits of Length, Width, Thickness : Low Pass Filter 160806 0 e.g. : Unit of dimension F 1 T Application Specification Packing F : 673 ~ 2690 MHz Design code T : Reeled 0 : 0.1 mm 1 : 1.0 mm 160806 = Length 16, Width 08, Thickness 06 Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Paper Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 6 of 7 Ao Bo D T W 0.975 0.10 1.76 0.10 1.55 + 0.05 0.75 0.10 8.0  0.10 E F Po P1 P2 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 ASC_RFLPF1608060F1T_V01 Dec. 2018 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity: 4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFLPF1608060F1T_V01 Dec. 2018
RFLPF1608060F1T 价格&库存
很抱歉,暂时无法提供与“RFLPF1608060F1T”相匹配的价格&库存,您可以联系我们找货
