RFMTA080217NNUB002
RFMTA080217NNUB002
    WALSIN(华新科)
    315MHz 螺旋形 RF 天线 焊接 表面贴装型
RFMTA080217NNUB002 数据手册
Approval sheet Metal ANTENNA 315 MHz Working Frequency Halogens Free Product P/N: RFMTA080217NNUB002 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 4 RFMTA080217NNUB002_V02 Aug. 2016 Approval sheet Version V01 V02 Page 2 of 4 Date 2016 Jun. 2016 Aug. Description Author New Release SHLEE Change the winding direction SHLEE RFMTA080217NNUB002_V02 Aug. 2016 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Working Frequency Range 315 MHz Return Loss -10dB(Max) VSWR 2 max. Polarization Linear Radiation Pattern - Impedance 50 MATERIAL TABLE Items Description Phosphor Bronze ∅1.27mm Antenna Material ORDERING RULE RF MTA Product Code Type Code 0802 17 N Dipole Turns (unit: Connector Dimension cm) Brand (Unit: mm) N U B 0 02 Type of Connector Application Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5 GHz 6: 6GHz A: N Per 2 digits of Walsin RF Device MTA: Metal Antenna OD,Pitch 2 digits for Turns C:MCX A: 2.4GHz D:IPEX III ISM band E: IPEX IV e.g.:0401 e.g.:19 OD ∅4.8mm, Turns 19.75 Pitch1.15mm S: SMA T: TNC U:MURATA N: None Page 3 of 4 A: Reverse Female F: IPEX A13 B: Reverse H: Hirose Male I: IPEX F: Female M: MMCX M: Male N: None B: GSM 900/1800 B: MP dual band T:During G: GPS band Test L: 2.4/5.2/5.8 X: Pile Run GHz 0:None 1:∅0.81 3:∅1.13 01~99 series 6:RG316 7:∅1.37 number 8:RG178 tri-band N: NFC T:LTE band W: WCDMA band RFMTA080217NNUB002_V02 Aug. 2016 Approval sheet DIMENSIONS Page 4 of 4 RFMTA080217NNUB002_V02 Aug. 2016
RFMTA080217NNUB002 价格&库存
很抱歉,暂时无法提供与“RFMTA080217NNUB002”相匹配的价格&库存,您可以联系我们找货
RFMTA080217NNUB002
  • 1+31.500571+4.09358
