RFPCA080500NNFB001
RFPCA080500NNFB001
    WALSIN(华新科)
    13.56MHz 线圈式电感器 RF 天线 PCB 表面贴装型
RFPCA080500NNFB001 数据手册
Approval sheet PCB ANTENNA 13.56 MHz Working Frequency Halogens Free Product P/N: RFPCA080500NNFB001 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 4 RFPCA080500NNFB001_V01 Feb.2020 Approval sheet Version V01 Page 2 of 4 Date 2020 Feb. Description New Release RFPCA080500NNFB001_V01 Author SHLEE Feb.2020 Approval sheet MATERIAL TABLE Items Description PCB FR4 T=0.4 mm(黑漆板) FM11NT020 0402N101J500CTNA 2 Max Antenna NFC Chip Matching CAP PCB Molding ORDERING RULE RF PCA 0805 00 N PCB Cable Product Connector Type Code Dimension Length Code Brand (Unit: mm) (unit: cm) A: N C:MCX D:IPEX III Per 2 digits 2 digits for E: IPEX IV of length, cable F: IPEX A13 width length Walsin RF PCB H: Hirose Device Antenna I: IPEX e.g.: 0805 e.g.: 00 M: MMCX Length 8mm None Width 5.5mm Cable S: SMA T: TNC U:MURATA N: None Page 3 of 4 N F B 0 01 Type of Connector Application Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5GHz 6: 6GHz A: 2.4GHz ISM A: Reverse Female band B: Reverse Male B: GSM 900/1800 F: Female dual band M: Male G: GPS band N: None L: 2.4/5.2/5.8 GHz tri-band N: NFC T: LTE band W: WCDMA band RFPCA080500NNFB001_V01 B: MP T:During Test X: Pile Run 0:None 1:∅ 0.81 2:∅ 1.32 3:∅ 1.13 4:Low Loss ∅ 1.13 5:∅ 0.5 6:RG316 7: ∅ 1.37 8:RG178 01~99 series number 9:Low Loss ∅ 1.37 Feb.2020 Approval sheet Dimensions Page 4 of 4 RFPCA080500NNFB001_V01 Feb.2020
RFPCA080500NNFB001 价格&库存
很抱歉,暂时无法提供与“RFPCA080500NNFB001”相匹配的价格&库存,您可以联系我们找货
RFPCA080500NNFB001
  • 1+25.935131+3.32646
  • 10+19.4732910+2.49766
  • 25+17.8662325+2.29154
  • 100+16.09926100+2.06491
  • 250+15.25765250+1.95696
  • 500+14.93703500+1.91584
库存:2920
