RFPCA111815IMMB901
RFPCA111815IMMB901
    WALSIN(华新科)
    RF ANT PCB IPEX MALE 15CM LTE
RFPCA111815IMMB901 数据手册
Approval sheet PCB ANTENNA 698~960/1710~2690/3300~3800/5150~5850MHz Working Frequency Halogens Free Product P/N: RFPCA111815IMMB901 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Version V01 Page 2 of 22 Date 2019 Mar. Description New Release RFPCA111815IMMB901_V01 Author HWCHAN Mar. 2019 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 698 ~960 / 1710 ~ 2690 /3300 ~3800 / 5150 ~5850 MHz (note-1) Return Loss -10.0 dB(Max)( @ 698 ~960 / 1710 ~ 2690 MHz) -6.0 dB(Max)( @ 3300 ~3800 / 5150 ~5850 MHz) 2.0 (Max)( @ 698 ~960 MHz) 3.0 (Max)( @1710 ~ 2690 / 3300 ~3800 / 5150 ~5850 MHz) Omni-directional VSWR Radiation Gain(peak) Impedance 3.32 dBi( @ 698 ~960 MHz) 6.04 dBi( @1710 ~ 2690 MHz) 5.36 dBi(@ 3300 ~3800 MHz) 4.39 dBi(@5150 ~5850 MHz) 50 Ohm Nominal Polarization Admitted Power Linear Vertical 1W Operation Temperature -20℃ ~ +65℃ *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description PCB FR4(Single Layer);T=0.4mm;黑漆 Double Tape 3M9888T Cable ψ1.37 Low Loss Coaxial Cable(Black) Connector IPEX Compatible(Gold) ORDERING RULE RF PCA Type Code Product Code 1118 PCB Dimension (Unit: mm) 15 I Cable Connector Length (unit: Brand cm) M M B Type of Connector Application Project status C:MCX 0: 0GHz 3: 3GHz 6: 6GHz D:IPEX III A: 2.4GHz ISM band E: IPEX IV B: GSM 900/1800 A: N Walsin RF Device Per 2 digits of 2 digits for length, width cable length PCA: PCB e.g.: 1118 e.g.: Antenna Length Cable 118.0mm, length:15.0 Width 18.0mm cm F: IPEX A13 A: Reverse Female B: Reverse Male H: Hirose F: Female I: IPEX M: Male M: MMCX N: None S: SMA T: TNC U:MURATA N: None Page 3 of 22 RFPCA111815IMMB901_V01 dual band G: GPS band L: 2.4/5.2/5.8 GHz tri-band M:LTE+Sub 6G +5G N: NFC T: LTE band W: WCDMA band 9 01 Wire Project Diameter 0:None 1:∅ 0.81 B: MP T:Dur ing Test 3:∅ 1.13 X: Pile Run 6:RG316 01~99 7:∅ 1.37 series 8:RG178 9:∅ 1.37 Low Loss number Mar. 2019 Approval sheet DIMENSIONS Page 4 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Test Report ■EXPERIMENTAL SETUP Page 5 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet ■ELECTRICAL CHARACTERISTICS VSWR Page 6 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet ■Antenna Efficiency and Peak Gain 698~960MHz Page 7 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 1710~2690MHz Page 8 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 3300~3800MHz Page 9 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 5150~5850MHz Page 10 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet ■RADIATION PATTERN 698~960MHz X-Z Plane Phi=0.00deg Gain . dB Page 11 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 12 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 13 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 1710~2690MHz X-Z Plane Phi=0.00deg Gain . dB Page 14 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 15 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 16 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 3300~3800MHz X-Z Plane Phi=0.00deg Gain . dB Page 17 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 18 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 19 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet 5150~5850MHz X-Z Plane Phi=0.00deg Gain . dB Page 20 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 21 of 22 RFPCA111815IMMB901_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 22 of 22 RFPCA111815IMMB901_V01 Mar. 2019
RFPCA111815IMMB901
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于实现电信号隔离。
3. 引脚分配:EL817共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光电晶体管集电极,4脚光电晶体管发射极,5脚光电晶体管基极,6脚Vcc。
4. 参数特性:EL817的主要参数包括工作温度范围-40~85℃,隔离电压3750Vrms,输入电流5mA,输出电流5mA。
5. 功能详解:EL817通过发光二极管和光电晶体管实现电信号隔离,发光二极管发光后,光电晶体管导通,实现信号传输。
6. 应用信息:EL817常用于开关电源、测量设备、通信设备等领域,实现信号隔离和电气隔离。
7. 封装信息:EL817采用DIP6封装。
RFPCA111815IMMB901 价格&库存
很抱歉,暂时无法提供与“RFPCA111815IMMB901”相匹配的价格&库存,您可以联系我们找货
RFPCA111815IMMB901
    • 1+11.58840
    • 200+4.62240
    • 500+4.47120
    • 1000+4.39560
