RFPCA202210IMMB301
RFPCA202210IMMB301
    WALSIN(华新科)
    5.5GHz LTE PCB 印制线 RF 天线 3.8GHz ~ 7.2GHz 5.54dBi IPEX 胶合剂
RFPCA202210IMMB301 数据手册
Approval sheet PCB ANTENNA 3800~7200MHz Working Frequency Halogens Free Product P/N: RFPCA202210IMMB301 Customer: Customer ‘s Part No.: Approval No.: Issue Date: *Contents in this sheet are subject to change without prior notice. Page 1 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet Version V01 Page 2 of 18 Date 2019 Mar. Description New Release RFPCA202210IMMB301_V01 Author HWCHAN Mar. 2019 Approval sheet ELECTRICAL CHARACTERISTICS Item Specification Frequency Range 3800 ~7200 MHz (note-1) Return Loss -10.0 dB(Max) VSWR 2.0 (Max) Radiation Omni-directional Gain(peak) 5.54 dBi Impedance 50 Ohm Nominal Polarization Admitted Power Linear Vertical 1W Operation Temperature -20℃ ~ +65℃ *note-1: Electrical characteristics will depend on customer’s final application. MATERIAL TABLE Items Description PCB FR4(Single Layer);T=0.4mm;黑漆 Double Tape 3M9888T Cable ψ1.13 Coaxial Cable(Black) Connector IPEX Compatible(Gold) ORDERING RULE RF PCA Type Code Product Code 2022 PCB Dimension (Unit: mm) 10 I Cable Connector Length (unit: Brand cm) M M B Type of Connector Application Project status C:MCX 0: 0GHz 3: 3GHz 6: 6GHz D:IPEX III A: 2.4GHz ISM band E: IPEX IV B: GSM 900/1800 A: N Walsin RF Device Per 2 digits of 2 digits for length, width cable length PCA: PCB e.g.: 2022 e.g.: Antenna Length Cable 20.0mm, Width length:10.0 22.0mm cm F: IPEX A13 A: Reverse Female B: Reverse Male H: Hirose F: Female I: IPEX M: Male M: MMCX N: None S: SMA T: TNC U:MURATA N: None Page 3 of 18 RFPCA202210IMMB301_V01 dual band G: GPS band L: 2.4/5.2/5.8 GHz tri-band M:LTE+Sub 6G +5G N: NFC T: LTE band W: WCDMA band 3 01 Wire Project Diameter 0:None 1:∅ 0.81 B: MP T:Dur ing Test 3:∅ 1.13 X: Pile Run 6:RG316 01~99 7:∅ 1.37 series 8:RG178 9:∅ 1.37 Low Loss number Mar. 2019 Approval sheet DIMENSIONS Page 4 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet Test Report ■EXPERIMENTAL SETUP Page 5 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet ■ELECTRICAL CHARACTERISTICS VSWR Page 6 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet ■Antenna Efficiency and Peak Gain 3800~4200MHz Page 7 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet 5150~5850MHz Page 8 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet 6000~7200MHz Page 9 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet ■RADIATION PATTERN 3800~4200MHz X-Z Plane Phi=0.00deg Gain . dB Page 10 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 11 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 12 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet 5150~5850MHz X-Z Plane Phi=0.00deg Gain . dB Page 13 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 14 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 15 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet 6000~7200MHz X-Z Plane Phi=0.00deg Gain . dB Page 16 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet Y-Z Plane Phi=90.00deg Gain . dB Page 17 of 18 RFPCA202210IMMB301_V01 Mar. 2019 Approval sheet X-Y Plane Theta=90.00deg Gain . dB Page 18 of 18 RFPCA202210IMMB301_V01 Mar. 2019
RFPCA202210IMMB301 价格&库存
很抱歉,暂时无法提供与“RFPCA202210IMMB301”相匹配的价格&库存,您可以联系我们找货
RFPCA202210IMMB301
  • 1000+22.877021000+2.86139
