RFTIP2506T10A8Q1C
RFTIP2506T10A8Q1C
    WALSIN(华新科)
    SMD9
    射频双工器 三工器 500MHz ~ 960MHz / 3.3GHz ~ 5.925GHz 9-SMD,无引线
RFTIP2506T10A8Q1C 数据手册
Approval sheet MULTILAYER CERAMIC TRIPLEXER RFTIP Series – 2520(1008)- RoHS Compliance Halogens Free Product 500~960 MHz/ 1427~2690 MHz/ 3300~5925 MHz Working Frequency P/N: RFTIP2506T10A8Q1C *Contents in this sheet are subject to change without prior notice. Page 1 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet FEATURES 1. Miniature footprint: 2.5 X 2.0 X 0.65 mm 2. Low Insertion Loss 3. High Rejection Rate 4. LTCC process 3 APPLICATIONS 1. LTE 500~960MHz / 1427~2690MHz / 3300~5925MHz working Frequency CONSTRUCTION TOP View P7 P8 P1 P6 P9 P2 PIN Connection PIN Connection P1 High Band Port P6 GND P2 GND P7 ANT Port P3 Middle Band Port P8 GND P4 GND P9 GND P5 Low Band Port P5 P4 P3 DIMENSIONS Figure Symbol Dimension (mm) L 2.50 ± 0.15 W 2.00 ± 0.15 T 0.65 max. A 0.30 ± 0.10 B 0.40 ± 0.10 C 0.55 ± 0.10 D 0.40 ± 0.10 E 0.90 ± 0.10 F 0.30 ± 0.10 TOP view Side view Bottom view Side view Page 2 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet ELECTRICAL CHARACTERISTICS Specification RFTIP2506T10A8Q1C Frequency range Insertion Loss (at 25℃) Insertion Loss (at -40~+85℃) Attenuation 500~960 MHz 3300~5925 MHz 1.00 dB max. @1427~1511 MHz 1.45 dB max. @3300~3400 MHz 0.54 dB max. @500~798 MHz 0.85 dB max. @1710~1880 MHz 0.95 dB max. @3400~3600 MHz 0.60 dB max. @815~894 MHz 0.85 dB max. @1880~1920 MHz 0.80 dB max. @3600~3800 MHz 0.63 dB max. @880~915 MHz 0.85 dB max. @1930~2200 MHz 0.70 dB max. @3800~4200 MHz 0.65 dB max. @915~960 MHz 0.85 dB max. @2300~2400 MHz 0.70 dB max. @4400~5000 MHz 1.00 dB max. @2496~2690 MHz 0.80 dB max. @5150~5925 MHz 1.10 dB max. @1427~1511 MHz 1.55 dB max. @3300~3400 MHz 0.64 dB max. @500~798 MHz 0.95 dB max. @1710~1880 MHz 1.05 dB max. @3400~3600 MHz 0.70 dB max. @815~894 MHz 0.90 dB max. @1880~1920 MHz 0.90 dB max. @3600~3800 MHz 0.73 dB max. @880~915 MHz 0.95 dB max. @1930~2200 MHz 0.80 dB max. @3800~4200 MHz 0.75 dB max. @915~960 MHz 0.95 dB max. @2300~2400 MHz 0.80 dB max. @4400~5000 MHz 1.10 dB max. @2496~2690 MHz 0.90 dB max. @5150~5925 MHz 12.0 dB min. @1427~2690 MHz 18.0 dB min. @ 500~960 MHz 24.0 dB min. @3300~3400 MHz 9.0 dB min. @3300~3400 MHz 27.0 dB min. @3400~3800 MHz 20.0 dB min. @3400~3800 MHz 30.0 dB min. @3800~4200 MHz 20.0 dB min. @3800~4200 MHz 30.0 dB min. @4400~5000 MHz 24.0 dB min. @4400~5000 MHz 30.0 dB min. @5150~5925 MHz 21.0 dB min. @5150~5925 MHz 20.0 dB min. @ 500~960 MHz 11.0 dB min. @1427~2690 MHz 14.0 dB min. @10300~11850 MHz 17.0 dB min. @ 500~960 MHz 14.0 dB min. @ 1427~2690 MHz 14.0 dB min. @ 3300~5925 MHz Isolation (Middle to Low Band) 20.0 dB min. @ 500~960 MHz 30.0 dB min. @ 1427~2690 MHz 30.0 dB min. @ 3300~5925 MHz Isolation (High to Low Band) 30.0 dB min. @ 500~ 960 MHz 14.0 dB min. @ 1427~2690 MHz 11.0 dB min. @ 3300~5925 MHz Isolation (Middle to High Band) VSWR 1427~2690 MHz 2.0 max. 2.0 max. Impedance 50 Ω Power Capacity 2.0 W max. 2.0 max. Moisture sensitivity LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) levels Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Page 3 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet TYPICAL ELECTRICAL PERFORMANCE LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 4 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150C, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under *Immersion time:101 sec the operational temperature range within -40 ~ heat JIS C 0050-5.4 Solder:Sn3Ag0.5Cu for lead-free 85°C. Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 Customer’s specification. *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: 5N (LGA terminal series);5N(≦0603); 10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 ~ shall be maintained for 51 sec. 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 5 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 6 of 8 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF Walsin RF device TIP 2506 T 10A8Q1C Product Code Dimension code Application Specification TIP : Per 2 digits of Length, Width, Thickness : T: Design code TRIPLEXER e.g. : 2506 = 500~960 MHz / 1427~2690 MHz / 3300~5925 MHz Length 2.5 mm, Width 2.0 mm, Thickness 0.65 mm Minimum Ordering Quantity: 2000 pcs per reel. PACKAGING Plastic Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 7 of 8 Ao 2.27 ± 0.10 Bo 2.74 ± 0.10 E 1.75 ± 0.10 F 3.50 ± 0.05 ΦD 1.55 ± 0.05 T 1.18 ± 0.10 W 8.00 ± 0.10 Po 4.00 ± 0.10 P1 4.00 ± 0.10 P2 2.00 ± 0.05 ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:2000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 8 of 8 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFTIP2506T10A8Q1C_V02 Mar. 2020
RFTIP2506T10A8Q1C 价格&库存
很抱歉,暂时无法提供与“RFTIP2506T10A8Q1C”相匹配的价格&库存,您可以联系我们找货
RFTIP2506T10A8Q1C
  • 1+4.499821+0.58477
  • 10+3.8615510+0.50182
  • 25+3.6402825+0.47307
  • 100+3.33019100+0.43277
  • 250+3.14332250+0.40849
  • 500+3.01097500+0.39129
  • 1000+2.886201000+0.37507
库存:1145
RFTIP2506T10A8Q1C
  • 2000+2.968972000+0.38583
  • 4000+2.850144000+0.37039
  • 6000+2.783776000+0.36176
  • 10000+2.7033610000+0.35131
  • 14000+2.6522814000+0.34467
  • 20000+2.5997020000+0.33784
库存:1145
