201878
201878
    WATTEROTT
    BME680-BREAKOUT (HUMIDITY. PRESS
201878 数据手册
  BME680-Breakout (humidity, pressure, temperature & air quality sensor) Item number: 201878 The BME680 is one of the newest Bosch Sensortec environmental sensor for humidity, pressure, temperature and indoor air quality sensor with digital I2C/TWI and SPI interface. On the breakout you can find a voltage regulator and level translator, so you can use the board on 3V to 5V systems. Category: Environment The BME680 is one of the newest Bosch Sensortec environmental sensor for humidity, pressure, temperature and indoor air quality sensor with digital I2C/TWI and SPI interface. On the breakout you can find a voltage regulator and level translator, so you can use the board on 3V to 5V systems. Features of the BME680: Humidity sensor Response time (t63%) 8s Accuracy tolerance ± 3 % relative humidity Hysteresis = 1,5 % relative humidity Pressure sensor Pressure range 300 ? 1100 hPa (equiv. to +9000?-500 m above/below sea level) Relative accuracy ±0.12 hPa, equiv. to ±1 m (950 ? 1050hPa @25°C) Absolute accuracy typ. ±1 hPa (950 ...1050 hPa, 0 ...+40 °C) Temperature Sensor Operating range Operational -40°C - +85°C Full accuracy 0°C - +65°C Gas Sensor Response time (t33-63%) 1s Indoor air quality (IAQ) index outpu        https://shop.watterott.com/BME680‐Breakout‐humidity‐pressure‐temperature‐air‐quality‐sensor/4‐18‐19
201878 价格&库存
很抱歉,暂时无法提供与“201878”相匹配的价格&库存,您可以联系我们找货
