201880
201880
    WATTEROTT
    - CAM-M8Q GNSS(Beidou,Galileo,GLONASS,GPS,QZSS) 评估板
201880 数据手册
  CAM-M8Q-Breakout Multi GNSS Module (GPS, QZSS, GLONASS, BeiDou, Galileo) Item number: 201880 Category: Start This is a breakout board with the u-blox CAM-M8Q Multi GNSS Module for GPS, QZSS, GLONASS, BeiDou and Galileo data. On the breakout you find the u-blox CAM-M8Q module, a CR1225 battery holder for the backup battery and two u.Fl connectors. The u.Fl connectors are connected to the antenna in- and output of the CAM-M8Q. It has a easy to use UART, SPI and DDC (I2C) interface, so you can use it in different applications. All pins are brought out as 2,54mm pitch pin header. Features:             Concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou) Miniature size and weight with low power consumption Embedded, omnidirectional and wideband antenna Industry leading ?167 dBm navigation sensitivity Optional external antenna Receiver: 72-Kanel u-blox M8 engine Updaterate: Single GNSS - up to 18Hz, Dual GNSS up to 10Hz Power supply: 2,7 - 3,6V 30mA Continuous / 10mA Power Save Mode 1Hz @ 3V Interfaces: UART, SPI, DDC (I2C) Timepulse output: 0,25Hz - 10MHz Protocols : NMEA, UBX binary, RTCM           https://shop.watterott.com/CAM‐M8Q‐Breakout‐Multi‐GNSS‐Module‐GPS‐QZSS‐GLONASS‐BeiDou‐Galileo/4‐18‐19
201880 价格&库存
很抱歉,暂时无法提供与“201880”相匹配的价格&库存,您可以联系我们找货
