20190001
20190001
    WATTEROTT
    BMP388 - 压力 评估板 - 传感器
20190001 数据手册
  BMP388-Breakout (Pressure & Temperature Sensor) Item number: 20190001 Category: Humidity The BMP388 is one of the newest Bosch pressure and temperature sensor with digital I2C and SPI interface. On the breakout you can find a voltage regulator and level translator, so you can use the board on 3V to 5,5V systems. Features: Pressure sensor Pressure range 300 ? 1100 hPa (equiv. to +9000?-500 m above/below sea level) Relative accuracy ±8 Pa, equiv. to ±0.66 m (900 ? 1100hPa @25-40°C) Absolute accuracy typ. ±50 Pa (300 ...1100 hPa, -20 ...+65 °C) Temperatur Sensor Operating range Operational -40°C - +85°C / Full accuracy 0°C - +65°C Digital interfaces I²C (up to 3.4 MHz) / SPI (3 and 4 wire, up to 10 MHz) Current consumption 3.4µA @ 1 Hz sampling rat                       https://shop.watterott.com/BMP388‐Breakout‐Pressure‐Temperature‐Sensor/4‐18‐19
20190001 价格&库存
很抱歉,暂时无法提供与“20190001”相匹配的价格&库存,您可以联系我们找货
