110-FEP-111/03
110-FEP-111/03
    WECO(威克德诺)
    P=3.5mm
    接线端子 间距:3.50mm 自由悬挂
110-FEP-111/03 数据手册
TECHNICAL DATA SHEET 110-FEP-111 Plug connector Screwless connection, Push-In GENERAL INFORMATION 3,5 mm 2 - 24 110-ME-111, 110-ME-121 Pitch No. of poles Usable with TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Rated Impulse Voltage Rated Insulation Voltage Rated Current solid / stranded / AWG 0,2 - 2,5 mm² / 0,2 - 2,5 mm² / 24 - 14 AWG 1,5 mm² / 16 AWG max. 10 mm 2,5 kV 160 V acc. EN 61984 8A MATERIAL APPROVALS Current [A] Voltage [V] Group AWG 11 300 B, D 30-14 [Nm] Moulding Insulating Group Temperature Range Terminal body Spring PA V0, housing black, pusher orange I -40°C up to 130°C copper alloy, tin-plated Steel CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 110-FEP-111/02 110-FEP-111/03 110-FEP-111/04 110-FEP-111/05 110-FEP-111/06 110-FEP-111/07 110-FEP-111/08 110-FEP-111/09 110-FEP-111/10 110-FEP-111/11 110-FEP-111/12 Article number 10.842.552 10.842.553 10.842.554 10.842.555 10.842.556 10.842.557 10.842.558 10.842.559 10.842.560 10.842.561 10.842.562 Length (L) 7,8 mm 11,3 mm 14,8 mm 18,3 mm 21,8 mm 25,3 mm 28,8 mm 32,3 mm 35,8 mm 39,3 mm 42,8 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 250 250 250 250 further number of poles on request 02.22 A3.25
110-FEP-111/03 价格&库存
很抱歉,暂时无法提供与“110-FEP-111/03”相匹配的价格&库存,您可以联系我们找货
