120-FEP-311/03
120-FEP-311/03
    WECO(威克德诺)
    P=5mm
    接线端子 间距:5.00mm 自由悬挂
120-FEP-311/03 数据手册
TECHNICAL DATA SHEET 120-FEP-311 Plug connector Screwless connection, Push-In GENERAL INFORMATION 5 mm 2 - 24 120-ME-211, 120-ME-221 Pitch No. of poles Usable with TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Rated Impulse Voltage Rated Insulation Voltage Rated Current solid / stranded / AWG 0,2 - 4,0 mm² / 0,2 - 4,0 mm² / 24 - 12 AWG 2,5 mm² / 14 AWG max. 10 mm 4 kV 250 V acc. EN 61984 12 A MATERIAL APPROVALS Current [A] Voltage [V] Group AWG 16 300 B, D 30-12 [Nm] Moulding Insulating Group Temperature Range Terminal body Spring PA V0, housing black, pusher orange I -40°C up to 130°C copper alloy, tin-plated Steel OPTIONS / ACCESSORIES • Coding elements CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 120-FEP-311/02 120-FEP-311/03 120-FEP-311/04 120-FEP-311/05 120-FEP-311/06 120-FEP-311/07 120-FEP-311/08 120-FEP-311/09 120-FEP-311/10 120-FEP-311/11 120-FEP-311/12 Article number 10.808.932 10.808.933 10.808.934 10.808.935 10.808.936 10.808.937 10.808.938 10.808.939 10.808.940 10.808.941 10.808.942 Length (L) 10 mm 15 mm 20 mm 25 mm 30 mm 35 mm 40 mm 45 mm 50 mm 55 mm 60 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 250 250 250 100 further number of poles on request 02.22 A3.25
120-FEP-311/03 价格&库存
很抱歉,暂时无法提供与“120-FEP-311/03”相匹配的价格&库存,您可以联系我们找货
120-FEP-311/03
    • 1+22.82040
    • 250+9.10440
    • 500+8.80200
    • 1000+8.65080
