TECHNICAL DATA SHEET
120-M-221-SMD
Pin strip for SMD
Plug-in direction vertical to PCB, with side walls
GENERAL INFORMATION
Pitch
No. of poles
Usable with
5 mm
2 - 12
all plug connectors of series 120
PCB LAYOUT
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
III
3
160 V
2,5 kV
Rated Insulation Voltage
Rated Current
Soldering process
III
2
160 V
2,5 kV
130 V acc. to EN 60998-1
12 A
Reflow solder
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
APPROVALS
Current [A]
Voltage [V]
Group
15
10
300
300
B
D
15
10
300
300
B
D, E
Solder paste thickness:
0,15 - 0,2 mm
Solder pad diameter: ø
2,8 mm
II
2
250 V
2,5 kV
AWG
[Nm]
Solder pin
PA HT, black, V-0
CTI ≥ 600
I
-40°C up to 120°C; reflow solder temperature
peak max. 255°C acc. to DIN EN 61760-1
ø 1,1 mm (plug-in area); tin plated brass
OPTIONS / ACCESSORIES
• Consecutive numbering
• Special marking according to drawing
• Self-adhesive marking strip BST-5,00 [1]
[1] To be fitted after reflow soldering process
CONFIGURATIONS
Poles Item
2
3
4
5
6
2
3
4
5
6
120-M-221-SMD/02
120-M-221-SMD/03
120-M-221-SMD/04
120-M-221-SMD/05
120-M-221-SMD/06
120-M-221-SMD/02-T&R
120-M-221-SMD/03-T&R
120-M-221-SMD/04-T&R
120-M-221-SMD/05-T&R
120-M-221-SMD/06-T&R
Article number
40.806.352
40.806.353
40.806.354
40.806.355
40.806.356
40.806.352.A00
40.806.353.A00
40.806.354.A00
40.806.355.A00
40.806.356.A00
Length (L)
12,00 mm
17,00 mm
22,00 mm
27,00 mm
32,00 mm
12,00 mm
17,00 mm
22,00 mm
27,00 mm
32,00 mm
Packaging
PU
Box
Box
Box
Box
Box
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
200
200
100
100
100
225
225
225
225
225
Tape
Width
Tape
Height
32 mm
32 mm
56 mm
56 mm
56 mm
17,4 mm
17,4 mm
17,4 mm
17,4 mm
17,4 mm
further number of poles on request
01.20
很抱歉,暂时无法提供与“120-M-221-SMD/06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+21.71880
- 200+8.67240
- 500+8.38080
- 1000+8.24040
