120-M-227-SMD
Pin strip for SMD
Plug-in direction vertical to PCB, with solder flanges
General Information
Pitch
5 mm
No. of poles
2 - 22
Usable with
all plug connectors of series 120
Technical Data
Overvoltage Category
IIII
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
III
II
3
2
2
160 V
160 V
250 V
2,5 kV
2,5 kV
2,5 kV
Rated Insulation Voltage
130 V acc. to EN 60998-1
Rated Current
12 A
Soldering process
Reflow solder
Material
PCB Layout
Solder paste thickness: 0,15 - 0,2 mm
120-M-227-SMD is a pin strip with a pitch of 5 mm for surface mount technology
and suitable for all plugs of the plug connector system of series of 120 and
available in lengths from 2 to 22 poles.
The solder retention devices (SMT anchors) on either side of the terminal housing
provide an exceptionally high retention force for the terminal block to the PCB.
The most significant benefit of this design is the protection it provides to the solder
joints against stresses encountered in field-installations. The product eliminates
completely CTE mismatch (Coefficient of thermal expansion) and provide total
coplanarity by the position adapting pins.
For the automatic assembling process, all pin strip versions are packed Tape on
Reel and are equipped with high temperature resistant pick caps, which can
comfortably be removed after the soldering process.
Plug-In direction vertical to PCB and wire entrance parallel to PCB when plugged
with 120-D-111, 120-D-121
Plug-In direction and wire entrance vertical to PCB when plugged with 120-A-111.
Moulding
PA HT, grey, V-0
Comparative Tracking Index
CTI 250
Insulating Group
IIIa
Temperature Range
-40°C up to 105°C; reflow solder temperature
(Peak) max. 250°C (15-30 s)
Solder pin
ø 1,1 mm (plug-in area); tin plated brass
Approvals
Current [A]
Voltage [V]
Group
15
10
300
300
B
D
15
10
300
300
B
D, E
AWG
[Nm]
Options / Accessories
• Consecutive numbering
• Special marking according to drawing
• Self-adhesive marking strip BST-5,00 [1]
• Special packaging on request: Tape-on-Reel - Tray - Bar magazine
[1] To be fitted after reflow soldering process
Part Numbers
No. of
poles
120-M-227-SMD
2
27.498.104
5
50.494.001
further number of poles on request
Length
PU
10,00
25,00
100
100
WECO | www.wecogroup.com
04.13
Tape-on-Reel Product
很抱歉,暂时无法提供与“120-M-227-SMD/04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+35.19720
- 250+14.05080
- 500+13.57560
- 1000+13.34880
