121-FEP-311/04
121-FEP-311/04
    WECO(威克德诺)
    P=5.08mm
    接线端子 间距:5.08mm 自由悬挂
121-FEP-311/04 数据手册
TECHNICAL DATA SHEET 121-FEP-311 Plug connector Screwless connection, Push-In GENERAL INFORMATION 5,08 mm 2 - 24 121-ME-211, 121-ME-221 Pitch No. of poles Usable with TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Rated Impulse Voltage Rated Insulation Voltage Rated Current solid / stranded / AWG 0,2 - 4,0 mm² / 0,2 - 4,0 mm² / 24 - 12 AWG 2,5 mm² / 14 AWG max. 10 mm 4 kV 250 V acc. EN 61984 12 A MATERIAL APPROVALS Current [A] Voltage [V] Group AWG 16 300 B, D 30-12 [Nm] Moulding Insulating Group Temperature Range Terminal body Spring PA V0, housing black, pusher orange I -40°C up to 130°C copper alloy, tin-plated Steel OPTIONS / ACCESSORIES • Coding elements CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 121-FEP-311/02 121-FEP-311/03 121-FEP-311/04 121-FEP-311/05 121-FEP-311/06 121-FEP-311/07 121-FEP-311/08 121-FEP-311/09 121-FEP-311/10 121-FEP-311/11 121-FEP-311/12 Article number 10.808.962 10.808.963 10.808.964 10.808.965 10.808.966 10.808.967 10.808.968 10.808.969 10.808.970 10.808.971 10.808.972 Length (L) 10,16 mm 15,24 mm 20,32 mm 25,40 mm 30,48 mm 35,56 mm 40,64 mm 45,72 mm 50,80 mm 55,88 mm 60,96 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 250 250 250 100 further number of poles on request 09.20 A3.25
121-FEP-311/04 价格&库存
很抱歉,暂时无法提供与“121-FEP-311/04”相匹配的价格&库存,您可以联系我们找货
121-FEP-311/04
    • 1+29.10600
    • 250+11.62080
    • 500+11.23200
    • 1000+11.03760
