121-M-211/02
121-M-211/02
    WECO(威克德诺)
    弯插,P=5.08mm
    接线端子 1x2P 间距:5.08mm 排数:1 每排Pin数:2
121-M-211/02 数据手册
TECHNICAL DATA SHEET 121-M-111/-211 Pin strip Plug-in direction parallel to PCB GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 121-M-111 5,08 mm 2 - 12 all plug connectors of series 121 Ordering information: ..-M-111: without side walls ..-M-211: with side walls TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB 121-M-211 III 3 250 V 4 kV III 2 320 V 4 kV II 2 630 V 4 kV 250 V acc. to EN 60998-1 12 A ø 1,4 mm APPROVALS MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin PA, grey, V-0 CTI • 600 I -40°C up to 100°C 1,0 x 1,0 mm; tin plated brass OPTIONS / ACCESSORIES Current [A] Voltage [V] Group 15 10 300 300 B D 15 10 300 300 B D, E AWG [Nm] • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-5,08 Pitch of 10,16 mm for larger clearance and creepage distances Other solder pin lengths on request Coding elements 120-K Connectors equipped with coding elements on request CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 121-M-111/02 121-M-111/03 121-M-111/04 121-M-111/05 121-M-111/06 121-M-111/07 121-M-111/08 121-M-111/09 121-M-111/10 121-M-111/11 121-M-111/12 Article number Item Article number 10.806.102 10.806.103 10.806.104 10.806.105 10.806.106 10.806.107 10.806.108 10.806.109 10.806.110 10.806.111 10.806.112 121-M-211/02 121-M-211/03 121-M-211/04 121-M-211/05 121-M-211/06 121-M-211/07 121-M-211/08 121-M-211/09 121-M-211/10 121-M-211/11 121-M-211/12 10.806.126 10.806.127 10.806.128 10.806.129 10.806.130 10.806.131 10.806.132 10.806.133 10.806.134 10.806.135 10.806.136 Length (L) 10,16 mm 15,24 mm 20,32 mm 25,40 mm 30,48 mm 35,56 mm 40,64 mm 45,72 mm 50,80 mm 55,88 mm 60,96 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 200 200 100 100 100 50 50 50 50 50 50 further number of poles on request 02.21 A3.24
121-M-211/02 价格&库存
很抱歉,暂时无法提供与“121-M-211/02”相匹配的价格&库存,您可以联系我们找货
121-M-211/02
  • 1+5.73480
  • 10+4.67640
  • 30+4.14720
库存:189
