121-M-221/04
121-M-221/04
    WECO(威克德诺)
    插件,P=5.08mm
    接线端子 1x4P 间距:5.08mm 排数:1 每排Pin数:4
121-M-221/04 数据手册
TECHNICAL DATA SHEET 121-M-121/-221 Pin strip Plug-in direction vertical to PCB GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 5,08 mm 2 - 12 all plug connectors of series 121 Ordering information: ..-M-121: without side walls ..-M-221: with side walls 121-M-121 TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB III 3 250 V 4 kV III 2 320 V 4 kV II 2 630 V 4 kV 121-M-221 250 V acc. to EN 60998-1 12 A ø 1,4 mm MATERIAL APPROVALS Current [A] Voltage [V] Group 15 10 300 300 B D 15 10 300 300 B D, E AWG [Nm] Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C 1,0 x 1,0 mm; tin plated brass OPTIONS / ACCESSORIES • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-5,08 Pitch of 10,16 mm for larger clearance and creepage distances Other solder pin lengths on request Coding elements 120-K Connectors equipped with coding elements on request CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 121-M-121/02 121-M-121/03 121-M-121/04 121-M-121/05 121-M-121/06 121-M-121/07 121-M-121/08 121-M-121/09 121-M-121/10 121-M-121/11 121-M-121/12 Article number Item Article number 20.806.102 20.806.103 20.806.104 20.806.105 20.806.106 20.806.107 20.806.108 20.806.109 20.806.110 20.806.111 20.806.112 121-M-221/02 121-M-221/03 121-M-221/04 121-M-221/05 121-M-221/06 121-M-221/07 121-M-221/08 121-M-221/09 121-M-221/10 121-M-221/11 121-M-221/12 20.806.126 20.806.127 20.806.128 20.806.129 20.806.130 20.806.131 20.806.132 20.806.133 20.806.134 20.806.135 20.806.136 Length (L) 10,16 mm 15,24 mm 20,32 mm 25,40 mm 30,48 mm 35,56 mm 40,64 mm 45,72 mm 50,80 mm 55,88 mm 60,96 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 200 200 100 100 100 50 50 50 50 50 50 further number of poles on request 05.20
121-M-221/04 价格&库存
很抱歉,暂时无法提供与“121-M-221/04”相匹配的价格&库存,您可以联系我们找货
121-M-221/04
    • 1+5.63760
    • 10+4.56840
    • 30+4.03920
    • 100+3.51000
    库存:94
