971-SLR-SMD-1.1/03
971-SLR-SMD-1.1/03
    WECO(威克德诺)
    3 针位端子块 接头,公引脚,无罩 0.197"(5.00mm) 垂直 表面贴装型
971-SLR-SMD-1.1/03 数据手册
TECHNICAL DATA SHEET 971-SLR-SMD-1,1 Pin strip for SMD Plug-in area ø 1,1 mm GENERAL INFORMATION Pitch No. of poles Usable with 5 mm 2 - 12 plug connectors of series 115-F-.../..-1,1-SW; 950-FL-DS, 950-TFL-DS, 950-NAF-DS, 950-GFL-DS, 950-NLFL-DS, 950-RFL-DS PCB LAYOUT L1 = (No. of poles - 1) x pitch Solder paste thickness: 0,15 - 0,2 mm TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Soldering process III 3 160 V 2,5 kV III 2 160 V 2,5 kV II 2 320 V 2,5 kV 130 V acc. to EN 60998-1 10 A Reflow solder Solder pin APPROVALS Current [A] Voltage [V] Group 10 [1] 300 B 10 300 B MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range AWG [Nm] PA HT, black, V-0 CTI ≥ 600 I -40°C up to 120°C; reflow solder temperature peak max. 255°C acc. to DIN EN 61760-1 ø 1,1 mm (plug-in area); tin plated brass OPTIONS / ACCESSORIES • Other plug pin lengths on request • Other solder pin surfaces on request [1] Above headers with 1.0 or 1.1 mm dia. pins are rated 12A max. with manufacturer’s Cat. No. 120-W-111 terminal blocks. Above headers with 1.1 mm or 1.3 mm dia. pins are rated 12A max. with 115-F-111, 115-F-211 and 115-F-118 terminal blocks. CONFIGURATIONS Poles Item 2 3 4 5 6 2 3 4 5 6 971-SLR-SMD-1,1/02 971-SLR-SMD-1,1/03 971-SLR-SMD-1,1/04 971-SLR-SMD-1,1/05 971-SLR-SMD-1,1/06 971-SLR-SMD-1,1/02-T&R 971-SLR-SMD-1,1/03-T&R 971-SLR-SMD-1,1/04-T&R 971-SLR-SMD-1,1/05-T&R 971-SLR-SMD-1,1/06-T&R Article number 12.893.822 13.893.822 14.893.822 15.893.822 16.893.822 12.893.822.A00 13.893.822.A00 14.893.822.A00 15.893.822.A00 16.893.822.A00 Length (L) 9,50 mm 14,50 mm 19,50 mm 24,50 mm 29,50 mm 9,50 mm 14,50 mm 19,50 mm 24,50 mm 29,50 mm Packaging Box Box Box Box Box Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel PU 1000 500 500 250 250 500 500 500 500 500 Tape Width Tape Height 32 mm 32 mm 56 mm 56 mm 56 mm 15,9 mm 15,9 mm 15,9 mm 15,9 mm 15,9 mm further number of poles on request 02.20
971-SLR-SMD-1.1/03 价格&库存
很抱歉,暂时无法提供与“971-SLR-SMD-1.1/03”相匹配的价格&库存,您可以联系我们找货
