28896
28896
    WIHA(威汉)
    六角形,十字,Pozidriv®,开槽型,方形,Torq-Set®,Torx®,Tri-Wing® 钻头组
28896 数据手册
iTorque 52 Piece Bit Set 9-45in/lbs iTorque 9-45 In/lbs (1.0-6.0 Nm) Digital Handle & Slotted 4.5, 5.5, 6.5, 8.0mm & Phillips #0, 1, 2, 3 & Pozidriv #0, 1, 2, 3 & Hex Inch 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16" & Hex Metric 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm & Torx T6, T7, T8, SKU: 28896 Details Handle: Handle Range 9-45 Inch/lbs. (SKU 28889) The intellegent torque tool, Made in Germany For applications where recommended torque settings are important. EN ISO 6789, BS EN 26789, ASME B107.14M Includes Certificate of Calibration Torque can be conveniently set directly via push button integrated in handle. Ergonomic plastic/metal compound handle of quality, robust materials. Handle sizes proportioned to optimize torque setting. Distinctly audible and perceptible click signal when set toque is reached. Compatible with all Wiha torque blades Click Control - integrated counter records all applications. Calibration alert following 5,000 applications (normative reference value/resettable) Large digital display for simple stepless setting of torque value. Units can be simply switched - Nm ↔in.lbs / cNm ↔in.oz. ±6% Accuracy Blade: (SKU: 28581) Wiha special chrome-vanadium-molybdenum tool steel Through hardened for best wear resistance Bit Holder fits all commonly 1/4" Drive Bits Corrosion Protected (Not For Use in Wiha Insulated Torque Control Handles) Bits: Slotted 4.5, 5.5, 6.5, 8.0mm Phillips #0, #1, #2, #3 Torx® T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Hex Inch 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16" Hex Metric 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm PoziDriv #0, #1, #2, #3, #4 Torq Set #4, #5, #6, #8 Square #1, #2, #3 Triwing #0, #1, #2, #3, #4 Stored in a high quality Metal Box
28896 价格&库存
很抱歉,暂时无法提供与“28896”相匹配的价格&库存,您可以联系我们找货
