32480
32480
    WIHA(威汉)
    SPEEDE ELECT SLIMLINE BLADE SET
32480 数据手册
E-SCREWDRIVER speedE® ELECTRIC 0.4 Nm 0.4-8 Nm • Protects your material Electric fastening with a protective function to prevent damage to materials (max. 0.4 Nm = 3.5 in/lbs.) • Increases your control Fixing by hand with full sensitivity • Increases your efficiency Electronic ratchet for rapid fastening without any re-gripping • Increases your efficiency 100% compatible with the Wiha slimLine blade system • Maximum freedom of choice Open system with a rechargeable standard battery • Offers you full protection slimLine blades tested at 10,000 V AC & approved for 1,000 V AC E-SCREWDRIVER speedE® ELECTRIC Patent Pending SlimLine Blades up to 33% narrower insulation diameter then standard insulated tools Handle special fiber glass reinforced material for maximum strength, durability & drop performance LED Light glows after releasing the switch, blinks when battery is low Blade Holder designed to hold Insulated SlimLine Blades Ring Switch turn the ring clockwise or counter clockwise to determine loosening or tightening of the screw Lithium Battery rechargeable with integrated and overload protection Axial bearing to prevent gear & motor from being damaged during tightening & dropping Miniature freewheeling clutch to transmit manual torque
32480 价格&库存
很抱歉,暂时无法提供与“32480”相匹配的价格&库存,您可以联系我们找货
