28372
28372
    WIHA(威汉)
    十字,开槽型,方形 刀头,成套刀片 7
28372 数据手册
www.wihatools.com Tools that work for you 35 Wiha Power Blade Sets 0 0 0mm!J CentroFix Cushion Grip Blade Holder Wiha-SoftFinish® impact resistant, with roll off protection. Ergonomic cushion grip handle. Quick release bit holder with magnet. Item No. 76000 Q-~++ ...... mm mm Inch mm Inch lbs. 6.0 149 5.9 34.6 1.36 .26 G 0 0 0' 0 ilij.@i 37 Pc. Power Blade Set, In Durable Belt Pack Set includes cushion grip CentroFix Blade Holder & 36 interchangeable blades. IZ!fm Canvas Belt Wallet Storage Pouch Holds 38 90mm power blades. Folding pouch. Item No. 76079 Size 7-1/8" X 6" X 2" ........ lbs. pkg. .42 1 Inch Item No. 76099 ...... lbs. 2.06 Slotted: 2.5, 3.0, 4.5, 5.5, 6.0mm Phillips: #0, 1, 2, 3 Security TORX• : T8s, T9s, T1 Os, T15s, T20s, T25s, T27s, T30s Security Hex Inch: 1/16*, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4" Pozidriv®: #1 , 2, 3 & Square: #1, 2, 3 4" Nut Setters: 1/4, 5/16, 3/8" Cushion Grip CentroFix Blade Holder • 1/16" Standard Inch Hex Only i2del¥J 9 Pc. Power Blade Nut Driver Set 30mm deep drilled Nut drivers. Use with #76000 CentroFix Blade Holder. 1OOmm OAL Item No. 76085 ...... lbs .. 96 Inch: 3/16, 7/32, 1/4, 9/32,5/16, 11/32,3/8, 7/16, 1/2" Metric ilge!:!j 12 Pc. Power Blade Nut Driver Set 30mm deep drilled Nut drivers. Use with #76000 CentroFix Blade Holder. 1OOmm OAL 0 0 0 Item No. 76086 ...... lbs. 1.22 Metric: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0 11 .0, 12.0 13.0mm G • 00 0 GO ilij.!:fl i2d•PI:I 36 Pc. Power Blade Set, In Durable 0 61 Pc. Power Blade Service Kit, In Durable Zipper Case Set includes Bit Holding Handle, MicroBit Storage Handle, 4mm to 1/4" Magnetic Adapter, 9 power blades, 46 bits & 3 nut setters. Item No. 76087 ...... lbs. 1.34 90mm Power Blades: Slotted: 4.5, 5.5, 6.0mm Phillips: #1, 2, 3 & Square: #1, 2, 3 75mm Security TORX• Bits: T1 Os, T15s, T20s, T25s, T27s, T30s MicroBits: Phillips: #000, 00, 0, 1, 2, Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32" Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm TORX• :T1 , T2, T3, T4, T5, T6, T7, T8, T9, T10 Magnetic Nut Setters: 1/4, 5/16, 3/8" 0 0 0® Belt Pack Set includes cushion grip CentroFix Blade Holder & 35 interchangeable blades. Item No. 76098 ...... lbs. 1.86 Slotted: 2.5, 3.0, 4.5, 5.5, 6.0mm Phillips: #0, 1, 2, 3 Security TORX• : T8s, T9s, T1 Os, T15s, T20s, T25s, T27s, T30s, T40s Security Hex Metric: 2.5, 3.0, 4.0, 5.0mm Pozidriv®: #1, 2, 3 & Square: #1, 2, 3 Spanner: #6, 8, 10 & Tri-Wing: #1 , 2, 3, 4 Cushion Grip CentroFix Blade Holder 0 ijg.l:iji 12 Pc. Power Blade Inch & Metric Nut Driver Set 30mm deep drilled Nut drivers. Use with #76000 CentroFix Blade Holder. 100mm OAL Item No. 76084 ...... lbs. 2.97 Inch: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2" Metric: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0, 11 .0, 12.0, 13.0mm Cushion Grip CentroFix Blade Holder 52 wihas Toll Free: (800) 494-6104 Tools that work for you Wiha SYSTEM 4 Micro Bit Sets Includes Dust Cover i#!:!•l SYSTEM 4 Master Tech Micro Bit Set, 68 Pes. Includes Wiha ESD Safe Precision Handle, 1/4" to 4mm Adapter, 100mm Bit Extension & 36 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75980 Includes The Following Bits: 10 Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm 0 Phillips: 000, 00, 0, 1, 2 0 TORX®: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 0 Penta lobe: PL1, PL2, PL3, PL4, PL5, PL6 ,.......lbs . .38 e 1#14:1 SYSTEM 4 Master Tech Micro Bit Set, 68 Pes. Includes Wiha ESD Safe Precision Handle, Micro Bit Storage Handle, 1/4" to 4mm Adapter, 1OOmm Bit Extension & 64 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75968 Includes The Following Bits: 10 Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm 0 Phillips: 000, 00, 0, 1, 2 0 TORX®: T1, T2, T3, T4, T5, T6, T7,T8, T9, T10, T15, T20 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32" 0 Pentalobe: PL 1, PL2, PL3, PL4, PL5, PL6 Nut Driver Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Nut Driver Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32" ,.......lbs.. 70 e e O 0 1#@1 SYSTEM 4 Premium ESD Safe Micro Bit Set, 28 Pes. Includes Wiha ESD Safe Precision Handle, 1/4" to 4mm Adapter, 1OOmm Bit Extension, ESD Safe Tweezers & 21 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75993 Micro Bits: I 0 Slotted: 0.8, 1.5, 2.0, 2.5, 3.0, 3.5mm 0 Phillips: 000, 00, 0, 1, 2 0 TORX®: T1, T2, T3, T4, T5, T6, T7, T8, T9, T1 0 ESD Safe Tweezers: 5SA ESD, 7aSA ESD, 2ASA ESD, AASA ESD, OOSA ESD ,.......lbs . .95 I#Qi SYSTEM 4 Master Tech Micro Bit Set, 68 Pes. Includes Wiha ESD Safe Precision Handle, Micro Bit Storage Handle, 1/4" to 4mm Adapter, 1OOmm Bit Extension & 64 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75971 Includes The Following Bits: 10 Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm 0 Phillips: 000, 00, 0, 1, 2 0 TORX®: T1 , T2, T3, T4, T5, T6, T7,T8, T9,T10, T15, T20 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32" 0 Pentalobe: PL 1, PL2, PL3, PL4, PL5, PL6 Nut Driver Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Nut Driver Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32" ,.......lbs . .96 e e O 0 1#141 SYSTEM 4 Master Tech ESD & Ratchet With Micro Bits, 65 Pieces In Storage Box. Includes Wiha precision ESD Safe handle, micro bit extension, 72 tooth 1/4" ratchet & 62 interchangeable micro bits. Item Includes the following micro bits: No. OSiotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 75965 3.0, 3.5, 4.0mm ,....... 0 Phillips: 000, 00, 0, 1 TORX®: T3, T4, T5, T6, T7, T8, lbs. 1.16 T9, T10, T15, T20 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32" Nut Drivers Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 0 Nut Drivers Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32" 0 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Magnetic 1/4" to 4mm Adapter 0 e e 0 l#f4 SYSTEM 4 Master Tech Micro Bit Set, 68 Pes. Includes Wiha ESD Safe Precision Handle, ESD Safe Tweezers, 1/4" to 4mm Adapter, 1OOmm Bit Extension & 64 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75977 Includes The Following Bits: ,....... 0 Slotted: 0.8, 1.2, 1.5, lbs. 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm 1.00 0 Phillips: 000, 00, 0, 1, 2 0 TORX®: T1 , T2, T3, T4, T5, T6,T7, T8, T9,T10,T15,T20 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32" 0 Pentalobe: PL 1, PL2, PL3, PL4, PL5, PL6 Nut Driver Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 0 Nut Driver Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32" ESD Fine Round Point Tweezers 3cSA e e O wihas 20 Toll Free: (800) 494-6104 Tools that work for you ESD Safe Adjustable TorqueControl Tools 285 ESD Safe TorqueVario-9, With Window Scale EN ISO 6798, BS EN 26789, ASME B107.14M, +1- 6% Accuracy. Ergonomic multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible & perceptible click when torque setting has been attained. With Certificate of accuracy. oiiiii'j Pkg. 1 Item No. 28522* 28524 284 Item No. 2842G I Range ........-.. Inch lbs. Increments mm lbs. 15- 80(inlaz) 2.5 ln.oz. 122-127 .33 5 - 10 .2 ln.lbs. 122-127 .34 ESD Safe TorqueVarlo-S, W.IWindow Range ........-.. Inch lbs. Increments mm lbs. 5 - 18 .5 ln.lbs. 126-131 .46 Includes Certificate 0 0 0 With Certificate of Calibration • ~ 0 0 0 • Packed in a compact durable storage box +1- 10% ~ D 28890 24 Piece TorqueVario-S ESD Safe Micro-Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, Micro Bit holder and Torque adjustment tool. Item Slotted: 1.5, 2.0, 3.0, 4.0mm No. Phillips: #00, #0, #1 28890 TORX' : T6, T7, T8, T9, T10, T15 ......, Hex Inch: .050, 1/16, 5164, 31"32, lbs. 7/64, 1/8, 9/64, 5132" 1.35 28522 - ESD Safe Handle Range 15·80 Inch/oz. 288 ESD Safe Slotted Interchangeable Blades For TorqueVario-S Slotted tip blades on narrow 5132 Hex shafts. High alloy CVM steel, hardened, satin hard chrome finish. Item 0 0 =Max. Torque ......, oiiiii'j No. mm Inch mm Nm lbs. pkg. 28805 3.0 .118 175 0.6 .07 1 28809 4.0 .157 175 2.5 .07 D 28591 24 Piece ESD Safe Adjustable TorqueVario-9 Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, Micro Bit holder and Torque adjustment tool, packed in a compact durable storage box. Item Slotted: 1.5, 2.0, 3.0, 4.0mm No. Phillips: #00, #0, #1 28591 TORX" : T6, T7, T8, T9, T10, T15 ......, Hex Inch: .050, 1/16,5164,3/32, lbs. 7/64, 1/8, 9/64, 5132" 1.57 28524 • Handle ESD Safe Range 5 - 10 Inch lbs. 28500 ESD Safe TorqueVario-S Newton Meter, With Window Scale Item Range ......, ~ No. Nm mm Inch lbs. pkg. 28500* .04 - .46 124 4.875" .35 1 • +1- 10% (This unit only) Each TorqueVarlo handle has unique aerial number and certificate of calibration With Certificate of calibration 0~ 0 0 0 • ~ D 28895 24 Piece ESD Safe Adjustable TorqueVario·S Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, Micro Bit holder and Torque adjustment tool, packed in a compact durable storage box. Item No. Slotted: 0.8, 1.2, 1.5, 2.0mm 28895 Phillips: #000, #00, #0 ........... TORX'': T1, T2, T3, T4, T5, T6 lbs. Hex Metric: 0.7, 0.9, 1.3mm 1.30 Pentalobe: PL1, PL2, PL3, PL4 28500 • Handle ESD Safe .04- .46Nm (+/-10%) 0 ~ --...--- -- ESD Safe TORX'' Interchangeable 288 Blades For TorqueVarlo·S TORX'' tip blades on narrow 5132 Hex shafts. High alloy CVM steel, hardened, hard chromed. Item Max. Torque......, 0 . . No. Size mm mm Nm lbs. pkg. 1 28825 T5 0.4 .07 175 4.0 28827 T7 175 4.0 .07 1 0.9 28828 TS 175 4.0 1.3 .07 28829 T9 2.5 .07 175 4.0 28830 T10 175 4.0 .07 3.8 - e 0 "~' 28818 ESD Safe Pentalobe Interchangeable Blades For TorqueVario·S Newton Meter Handle tip blades on narrow 5132 Hex shafts. High alloy CVM steel, hardened, hard chromed. Item No • 28818 0 Size mm PL1 175 e . . . . -. ~ lbs. .07 pkg. 1 mm 4.0 • 28882 ESD Safe Bit Holder Adapter For 1/4" Drive Bits Shaft CVM steel, hardened, corrosion protected. (Not for use In lnsulatsd handles) Item No. Size mm mm lbs. pkg. 28882 1/4 162 4.0 .09 1 e e......,- www.wihatools.com wihas Tools that work for you Wiha Insulated 1/2" Socket accessories Wiha Insulated Hacksaw Uses standard 12" blade Mfj+jM Insulated 1/2" Drive Ratchet, IEC/EN 60900 & CSA Chrome-Vanadium steel. Reversible. Item OAL OAL ....-. Inch mm Inch lbs. pkg. No. 12853 1/2" 260 10.2 1.55 1 £= 1000Volt MPfZifM Hacksaw, With Insulated Handle Insulation According to ENIIEC 60900, DIN ISO, ASTM & CSA Specification, Up To 1000 Volt. Individually Tested. Item OAL OAL ....-. No. mm Inch lbs. pkg. 19767 457mm 18.0" 1.92 1 £= 1000Volt Mf):M Insulated 1/2" Extension Bars, EN/IEC 60900 & CSA Chrome-vanadium steel. Item OAL OAL No. Inch mm Inch 1/2" 125 4.9 12858 1/2" 250 9.8 12859 Insulated Waterpump Pliers Insulated Cable Cutters For cutting solid aluminum & copper conductors MUM•M Cable Cutter, With Insulated Handle. Insulation According to EN/IEC, ASTM & CSA Specification, Up To 1000 Volt. Individually Tested. Blade alloyed tool steel. Induction hardened. Item OAL OAL Capacity ....-. No. mm Inch mm Inch lbs. pkg. 11950 500 19.6 12 1/2" 3.0 1 For cutting multi strand aluminum & copper cables ...,_ _ _ _ _ 31 .5" ....-. lbs. pkg. .45 1 .91 W.
28372 价格&库存
很抱歉,暂时无法提供与“28372”相匹配的价格&库存,您可以联系我们找货
