47
www.wihatools.com • USA | www.wihatools.ca • CANADA
SYSTEM 4 Micro Bit Handle Storage Set
68 Pc. SYS 4 Master Tech ESD Micro Bit Set
Item No. Description
Case Pack
75977 Interchange Bit Set
3
Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm
Phillips: #000, 00, 0, 1, 2
TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20
Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32”
Hex Metrc: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
Nut Drv In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32”
Nut Drv MM: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm
Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6
100mm Bit Extension, Magnetic 1/4” to 4mm Adapter
ESD Safe SYSTEM 4 Precision Handle &
ESD Fine Round Point Tweezers 3cSA
75983 Micro Bit Set
Hex: .050, 1/16, 5/64, 3/32, 7/64, 1/8”
Case Pack
3
27 Pc. SYSTEM 4 Interchangeable Bit Set
40 Pc. SYSTEM 4 Interchangeable Bit Set
Case Pack
75991 Interchangeable Bit Set
3
Slt: 1.5, 2.0, 3.0, 4.0mm & Ph: #000, 00, 0, 1
TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15
Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32”
100mm Bit Extension & Standard Precision Handle
Case Pack
75996 Interchangeable Bit Set
3
Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32,
Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
100mm Bit Extension & ESD Safe Precision Handle
10 Piece Slotted Micro Bit Set
Case Pack
75984 Micro Bit Set
3
Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5(2), 3.0, 3.5, 4.0mm
8 Piece Hex Metric Micro Bit Set
Case Pack
75978 Micro Bit Set
3
Hex Metric: 0.7, 0.9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
26 Pc. SYSTEM 4 Interchangeable Bit Set
Case Pack
75992 Interchangeable Bit Set
3
Slotted: 1.5, 2.0, 3.0, 4.0mm & Ph: #000, 00, 0, 1
Case Pack
75999 Interchangeable Bit Set
3
Hex Metric: .71, .89, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
75985 Micro Bit Set
Case Pack
3
28 Pc. ESD Safe Micro Bit & Tweezer Set
Case Pack
75993
ESD Safe Precision Set
3
Slotted: 0.8, 1.5, 2.0, 2.5, 3.0, 3.5mm
Phillips: #000, #00, #0, #1
Tweezers: 5SA ESD, 7aSA ESD, 2ASA ESD,
AASA ESD, OOSA ESD
ESD Micro Bit Precision Handle,
100mm Bit Holder & 1/4” to 4mm Adapter
39 Piece Mini Micro Bit Set In Metal Box
Case Pack
75980 Mini Micro Bit Set
3
Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm
100mm Bit Extension & 4.0mm to 1/4” Adapter
10 Piece Phillips & Pentalobe Micro Bit Set
Case Pack
75986 Micro Bit Set
3
Case Pack
75981 Micro Bit Set
3
Slotted: 1.2, 1.5, 2.0 Phillips: #000, 00, 0
10 Piece Slotted & Phillips Micro Bit Set
75987 Micro Bit Set
Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm
Case Pack
3
Case Pack
75994 Interchangeable Bit Set
3
1/4” Square Drive TORX® Sockets
Item No.
76106
76107
76109
76111
76113
76117
76119
76121
76123
76129
76131
Description
T6 x 38mm
T7 x 38mm
T8 x 38mm
T9 x 38mm
T10 x 38mm
T15 x 38mm
T20 x 38mm
T25 x 38mm
T27 x 38mm
T30 x 38mm
T40 x 38mm
Case Pack
3
3
3
3
3
3
3
3
3
3
3
3/8” Square Drive Security Hex Metric Sockets
Item No.
76132
76133
76134
76135
76136
76137
76138
Description
2.0 X 42MM
2.5 x 42mm
3.0 x 42mm
4.0 x 42mm
5.0 x 42mm
6.0 x 42mm
8.0 x 42mm
Case Pack
3
3
3
3
3
3
3
3/8” Square Drive Security Hex Inch Sockets
10 Piece Hex Inch Micro Bit Set
10 Piece TORX Micro Bit Set
Case Pack
75982 Micro Bit Set
3
Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64,
1/8, 9/64, 5/32”
Case Pack
75988 Micro Bit Set
3
Case Pack
75995 Interchangeable Bit Set
3
Slotted: 1.5, 2.0, 2.5, 3.0mm
Item No.
76164
76165
76166
76167
76168
76169
76170
76171
76172
Description
5/64 x 42mm
3/32 x 42mm
7/64 x 42mm
1/8 x 42mm
9/64 x 42mm
5/32 x 42mm
3/16 x 42mm
7/32 x 42mm
1/4 x 42mm
Case Pack
3
3
3
3
3
3
3
3
3
