W7CF001G1XA-H40TF-01D.A6
    WINTECINDUSTRIES
    存储卡 CompactFlash® 1GB SLC
W7CF001G1XA-H40TF-01D.A6 数据手册
TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB CompactFlash Card INDUSTRIAL GRADE TM W7CFxxxA-H4 / W8CFxxxA-H4 Series INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE WITHOUT NOTICE. NOTHING IN THIS DOCUMENT SHALL BE CONTRUED AS GRANTING ANY LICENSE, EXPRESS OR IMPLIED. ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS” BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND. • Please contact your nearest Wintec representative for the latest updates or additional product information. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 1 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table of Contents Revision History ............................................................................................................................ 3 FEATURES ................................................................................................................................ 4 DESCRIPTION........................................................................................................................... 5 1.0 General Product Specification ........................................................................................... 6 2.0 Card Function Explanation ......................................................................................... 15 2.1 Attribute Access Specifications .................................................................................. 15 2.2 Task File Register Access Specifications ................................................................... 16 2.3 Configuration Register Specification ......................................................................... 18 2.4 Task File Register Specification ................................................................................. 20 2.5 ATA Command Specification .................................................................................... 25 3.0 Electrical Specification .................................................................................................. 31 3.1 General ......................................................................................................................... 31 3.2 DC Characteristics ...................................................................................................... 34 3.3 AC Characteristics ...................................................................................................... 34 3.4 Reset Characteristics (Memory Card Mode & I/O Card Mode) ................................ 45 3.5 User Notes .................................................................................................................. 46 4.0 Physical Specifications ................................................................................................. 47 4.1 Labelling and Marking................................................................................................. 48 5.0 Ordering Information ..................................................................................................... 49 Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 2 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Revision History Revision 1.00 1.01 1.02 1.03 Month September October January February Year 2009 2009 2010 2010 1.04 October 2011 1.05 1.06 1.07 March July May 2012 2012 2013 History Initial Release (Preliminary) Add firmware revision 090904 as option Add firmware revision 091110a as option Add Dual ID mode as option Update Ordering Guide Remove 128MB option Added Support for Micron Flash Updated Ordering Guide Corrected Typo’s Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 3 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB FEATURES GENERAL • Density up to 32GB • 32-bit RISC/DSP controller • Large internal SRAM provides firmware flexibility • Dual voltage support at 3.3V / 5V • Internal voltage detector • 20 Kbyte internal Boot ROM and 32 Kbyte internal SRAM • Specialized for high-reliability • RoHS 6/6 compliant RELIABILITY • > 2,000,000 Program/Erase Cycles • Industrial Wear Leveling – Includes Static Block Management • Spares & Bad Block Management • On-Board ECC capable of correcting 4 random bytes per 512 bytes sector with additional CRC for dynamic error checking • High Environmental Tolerance • 10-Year Data Retention • Unlimited Reads Wintec Type I Compact Flash (Industrial Grade H4 Series) COMPATIBILITY • Fully compliance to CompactFlash TM 3.0 and compatible to 4.1 specifications • ATA-6 standard compatible in True-IDE mode • PCMCIA specification 2.1 • Fast ATA supporting PIO mode 6, MDMA mode 4, UDMA mode 4 in True-IDE mode • Four integrated 8Kbyte Sector Buffers and 256 Byte PCMCIA Attribute Memory PERFORMANCE • True IDE Mode Capable – Host data transfer in PIO mode 6 or MDMA mode 4 up to 25 MByte/second – Host data transfer in UDMA mode 4 up to 66 MByte/second • High Performance – Two Direct Flash Access (DFA) Channels including two sector buffers support interleaving operation • Low Power Consumption: – Maximum operation current is 130 mA (32 GB) – Sleep mode current < 4 mA. (32 GB) Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 4 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB DESCRIPTION Wintec’s Compact Flash card is based on industrial leading Hyperstone F4 controller chip, which is a 32-bit RISC processor with instruction set extension optimized for Flash handling. The superior wear leveling done by the controller chip involves all physical blocks including the ones containing static data to meet the most demanding requirements from users in a data traffic intensive environment. The card contains a 50-pin connector consisting of two rows of 25 female contacts each on 50 mils (1.27mm) centers. The Industrial Grade CompactFlashTM Memory Cards are constructed with Samsung or Micron single-levelcell (SLC) NAND flash memory devices. It employs a variety of sophisticated functions, such as the Reed-Solomon error correction code which is capable of correcting up to 4 symbols in a 512 bytes sector with additional CRC for dynamic error checking. The wear-leveling methods ensure even wear of flash blocks across the entire card capacity. With background operations to track erase counts, the card prioritizes new writes to blocks with lower wear, and relocates static data to blocks with higher wear. Bad-block Management routines replace worn blocks with spare blocks reserved by the controller on card initialization. All Flash management utilities allow for maximum levels of data reliability and card endurance for prolong life cycle. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 5 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 1.0 General Product Specification For all the following specifications, values are defined at ambient temperature and nominal supply voltage unless otherwise stated. Table 1: Performance Specifications Parameter Burst Transfer Rate To/From Host Burst Transfer Rate Internally To/From Flash Sustained Sequential Read (Typical) Sustained Sequential Write (Typical) Random Read (Typical) Random Write (Typical) Table 2: Card Endurance Parameter Program/Erase Cycles Read Cycles Data Retention MTBF PIO Mode 6 25 MB/s 80 MB/s 18 MB/s 7.5 MB/s TBD TBD Performance UDMA Mode (Mode 4) 66 MB/s 80 MB/s 42 MB/s 20 MB/s 38MB/s 8MB/s Table 3: Card Data Reliability Spec > 2,000,000 Cycles Unlimited 10 Years (Min.) > 4,000,000 Hours Parameter Non-Recoverable Errors Erroneous Correction ECC Correctability Spec < 1 in 1014 Bytes Read < 1 in 1020 Bytes Read 4 Bytes/Sector Table 4: Environmental Specifications Temperature Parameters Standard Temp. Industrial Temp. Humidity Vibration Altitude Shock Acoustic Operating 0°C to 70°C -40°C to 85°C 8% to 95% (Non-Condensing) 16.3 G rms 80,000 ft. (Max.) 2,000 G (Max.) 0 db Non-Operating -55°C to 95°C -55°C to 95°C 8% to 95% (Non-Condensing) N/A Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 6 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Figure 1: Card Block Diagram NOTE: -CE1, -CE2, -OE, -WE –IORD, -IOWR, -REG, -RESET, -CSEL, -PDIAG, -DASP pins are pulled up in card. –CE1, -CE2, -OE, -WE, IORD, -IOWR, -REG pins are Schmitt trigger type input buffer. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 7 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 5: Card Pin Assignment PC Card Memory Mode Pin Signal Type GND Ground 1 D03 I/O 2 D04 I/O 3 D05 I/O 4 D06 I/O 5 D07 I/O 6 -CE1 I 7 A10 I 8 -OE I 9 A09 I 10 A08 I 11 A07 I 12 VCC Power 13 A06 I 14 A05 I 15 A04 I 16 A03 I 17 A02 I 18 A01 I 19 A00 I 20 D00 I/O 21 D01 I/O 22 D02 I/O 23 WP O 24 -CD2 O 25 -CD1 O 26 D111 I/O 27 D121 I/O 28 D131 I/O 29 D141 I/O 30 D151 I/O 31 -CE21 I 32 -VS1 O 33 -IORD I 34 -IOWR I 35 -WE I 36 RDY/BSY O 37 VCC Power 38 -CSEL I 39 -VS2 O 40 RESET I 41 -WAIT O 42 -INPACK O 43 -REG I 44 BVD2 I/O 45 BVD1 I/O 46 D081 I/O 47 D091 I/O 48 D101 I/O 49 GND Ground 50 NOTE: 1. 2. Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 PC Card I/O Mode Signal Type GND Ground D03 I/O D04 I/O D05 I/O D06 I/O D07 I/O -CE1 I A10 I -OE I A09 I A08 I A07 I VCC Power A06 I A05 I A04 I A03 I A02 I A01 I A00 I D00 I/O D01 I/O D02 I/O -IOIS16 O -CD2 O -CD1 O D111 I/O D121 I/O D131 I/O D141 I/O D151 I/O -CE21 I -VS1 O -IORD I -IOWR I -WE I IREQ O VCC Power -CSEL I -VS2 O RESET I -WAIT O -INPACK O -REG I -SPKR I/O -STSCHG I/O D081 I/O D091 I/O D101 I/O GND Ground Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 True IDE Mode Signal Type GND Ground D03 I/O D04 I/O D05 I/O D06 I/O D07 I/O -CS0 I A102 I -ATA SEL I A092 I A082 I A072 I VCC Power A062 I A052 I A042 I A032 I A02 I A01 I A00 I D00 I/O D01 I/O D02 I/O -IOCS16 O -CD2 O -CD1 O D111 I/O D121 I/O D131 I/O D141 I/O D151 I/O -CS11 I -VS1 O -IORD I -IOWR I -WE3 I INTRQ O VCC Power -CSEL I -VS2 O RESET I IORDY O DMARQ O -DMACK I -DASP I/O -PDIAG I/O D081 I/O D091 I/O D101 I/O GND Ground These signals are required only for 16-bit access and not required when installed in 8-bit systems. For lowest power dissipation, leave these signals open. Should be grounded by the host. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 8 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 3. Should be tied to VCC by the host. Table 6: Card Pin Explanation Signal Name Type Pin # A10 - A0 (PC Card Memory Mode) 8, 10, 11, 12, 14 -20 A10 - A0 (PC Card I/O Mode) Description These address lines along with the –REG signal are used to select the following: The I/O port address registers within the Compact Flash Card, the memory mapped port address registers within the card, a byte in the card’s information structure and its configuration control and status registers. This signal is the same as the PC Card Memory Mode signal. I A2 - A0 (True IDE Mode) In True IDE Mode only A [2:0] is used to select the one of eight registers in the Task File. 18, 19, 20 A10 - A3 (True IDE Mode) In True IDE Mode these remaining address lines should be grounded by the host. BVD1 (PC Card Memory Mode) This signal is asserted high as the BVD1 signal since a battery is not used with this product. -STSCHG (PC Card I/O Mode) Status Changed This signal is asserted low to alert the host to changes in the RDY/ -BSY and Write Protect states, while the I/O interface is configured. Its use is controlled by the Card Config and Status Register. I/O 46 -PDIAG (True IDE Mode) In the True IDE Mode, this input/output is the Pass Diagnostic signal in the Master/Slave handshake protocol. BVD2 (PC Card Memory Mode) This output line is always driven to a high state in Memory Mode since a battery is not required for this product. -SPKR (PC Card I/O Mode) I/O 45 This output line is always driven to a high state in I/O Mode since this product does not support the audio function. -DASP (True IDE Mode) In the True IDE Mode, this input/output is the Disk Active/Slave Present signal in the Master/Slave handshake protocol. -CD1, -CD2 (PC Card Memory Mode) These Card Detect pins are connected to ground on the Compact Flash Card. They are used by the host to determine if the card is fully inserted into its socket. -CD1, -CD2 (PC Card I/O Mode) O 25, 26 -CD1, -CD2 (True IDE Mode) This signal is the same for all modes. This signal is the same for all modes. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 9 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 6: Card Pin Explanation Cont. Signal Name Type Pin # I 7, 32 -CE1, -CE2 (PC Card Memory Mode) Card Enable -CE1, -CE2 (PC Card I/O Mode) Card Enable Description These input signals are used both to select the card and to indicate to the card whether a byte or a word operation is being performed. –CE2 always accesses the odd byte of the word. –CE1 accesses the even byte or the Odd byte of the word depending on A0 and –CE2. A multiplexing scheme based on A0, -CE1, -CE2 allows 8 bit hosts to access all data on D0 -D7. This signal is the same as the PC Card Memory Mode signal. -CS0, -CS1 (True IDE Mode) In the True IDE Mode –CS0 is the chip select for the task file registers while –CS1 is used to select the Alternate Status Register and the Device Control Register. -CSEL (PC Card Memory Mode) This signal is not used for this mode. -CSEL (PC Card I/O Mode) I 39 This signal is not used for this mode. -CSEL (True IDE Mode) This internally pulled up signal is used to configure this device as a Master or a Slave when configured in the True IDE Mode. When this pin is grounded, this device is configured as a Master. When this pin is open, this device is configured as a Slave. D15 - D00 (PC Card Memory Mode) These lines carry the Data, Commands and Status information between the host and the controller. D00 is the LSB of the Even Byte of the Word. D08 is the LSB of the Odd Byte of the Word. D15 - D00 (PC Card I/O Mode) I/O 2-6, 21, 22, 23, 27-31, 47, 48, 49 These signals are the same as the PC Card Memory Mode signal. D15 - D00 (True IDE Mode) In True IDE Mode all Task File operations occur in byte mode on the low order bus D00 -D07 while all data transfers are 16 bits using D00 -D15. GND (PC Card Memory Mode) Ground. GND (PC Card I/O Mode) - 1, 50 GND (True IDE Mode) This signal is the same for all modes. This signal is the same for all modes. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 10 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB -INPACK (PC Card Memory Mode) This signal is not used in this mode. -INPACK (PC Card I/O Mode) Input Acknowledge The Input Acknowledge signal is asserted by the Compact Flash Card when the card is selected and responding to an I/O read cycle at the address that is on the address bus. This signal is used by the host to control the enable of any input data buffers between the card and the CPU. This signal is a DMA Request that is used for DMA data transfers between host and device. It shall be asserted by the device when it is ready to transfer data to or from the host. For Multiword DMA transfers, the direction of data transfer is controlled by DIOR- and DIOW-.This signal is used in a handshake manner with DMACK- before negating DMAREQ, and reasserting DMAREQ if there is more data to transfer. O 43 DMAREQ shall not be driven when the device is not selected. While a DMA operation is in progress, -CS0 and –CS1 shall be held negated and the width of the transfers shall be 16 bits. DMARQ (True IDE Mode) If there is no hardware support for DMA mode in the host, this output signal is not used and should not be connected at the host .In this case, the BIOS must report that DMA mode is not supported by the host so that the device driver will not attempt DMA mode. A host that does not support DMA mode and implements both PCMCIA and true-IDE modes of operation need not alter the PCMICIA mode connections while in True-IED mode as long as this does not prevent proper operation in any mode. -IORD (PC Card Memory Mode) -IORD (PC Card I/O Mode) This signal is not used in this mode. I 34 -IORD (True IDE Mode) This is an I/O Read strobe generated by the host. This signal gates I/O data onto the bus from the Compact Flash Card when the card is configured to use the I/O interface. In True IDE Mode, this signal has the same function as in PC Card I/O Mode. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 11 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 6: Card Pin Explanation Cont. Signal Name Type Pin # Description -IOWR (PC Card Memory Mode) This signal is not used in this mode. - IOWR (PC Card I/O Mode) The I/O Write strobe pulse is used to clock I/O data on the Card Data bus into the Compact Flash controller registers when the card is configured to use the I/O interface. The clocking will occur on the negative to positive edge of the signal (trailing edge). I 35 - IOWR (True IDE Mode) In True IDE Mode, this signal has the same function as in PC Card I/O Mode. -OE (PC Card Memory Mode) This is an Output Enable strobe generated by the host interface. It is used to read data from the Compact Flash Card in Memory Mode and to read the CIS and configuration registers. -OE (PC Card I/O Mode) I 9 -ATA SEL (True IDE Mode) In PC Card I/O Mode, this signal is used to read the CIS and configuration registers. To enable True IDE Mode this input should be grounded by the host. In Memory Mode this signal is set high when the Compact Flash Card is ready to accept a new data transfer operation and held low when the card is busy. The host memory card socket must provide a pull-up resistor. RDY/-BSY (PC Card Memory Mode) O 37 - IREQ (PC Card I/O Mode) -INTRQ (True IDE Mode) At power up and at Reset, the RDY/-BSY signal is held low (busy) until the Compact Flash Card has completed its power up or reset function. The RDY/-BSY signal is held high (disabled from being busy) whenever the following condition is true: The Compact Flash Card has been powered up with +RESET continuously disconnected or asserted. I/O Operation – After the Compact Flash Card has been configured for I/O operation, this signal is used as – Interrupt Request. This line is strobed low to generate a pulse mode interrupt or held low for a level mode interrupt. In True IDE Mode, this signal is the active high Interrupt Request to the host. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 12 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 6: Card Pin Explanation Cont. Signal Name Type Pin # -REG (PC Card Memory Mode) Attribute Memory Select Description This signal is used during Memory Cycles to distinguish between Common Memory and Register (Attribute) Memory accesses. High for Common Memory, Low for Attribute Memory. The signal must also be active (low) during I/O Cycles when the I/O address is on the Bus. -REG (PC Card I/O Mode) This is a DMA Acknowledge signal that is asserted by the host in response to DMAREQ to initiate DMA transfers. I 44 While DMA operations are not active, the card shall ignore the –DMACK signal, including a floating condition. If DAM operation is not supported by a True-IDE Mode only host, this signal should be driven high or connected to VCC by the host. -DMACK (True IDE Mode) A host that does not support DMA mode and implements both PCMCIA and True-IDE modes of operation need not alter the PCMCIA mode connections while in True-IDE mode as long as this does not prevent proper operation all modes. RESET (PC Card Memory Mode) I 41 RESET (PC Card I/O Mode) This signal is the same as the PC Card Memory Mode signal. In the True IDE Mode this input pin is the active low hardware reset from the host. -RESET (True IDE Mode) VCC (PC Card Memory Mode) VCC (PC Card I/O Mode) When the pin is high, this signal resets the Compact Flash Card. The card is Reset only at power up if this pin is left high or open from power-up. The card is also reset when the Soft Reset bit in the Card Configuration Option Register is set. +5, +3.3V power. - 13, 38 This signal is the same for all modes. VCC (True IDE Mode) This signal is the same for all modes. -VS1, -VS2 (PC Card Memory Mode) Voltage Sense Signals. –VS1 is grounded so that the Compact Flash Card CIS can be read at 3.3 volts and –VS2 is open and reserved by PCMCIA for a secondary voltage. -VS1, -VS2 (PC Card I/O Mode) O 33, 40 -VS1, -VS2 (True IDE Mode) This signal is the same for all modes. This signal is the same for all modes. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 13 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 6: Card Pin Explanation Cont. Signal Name Type Pin # -WAIT (PC Card Memory Mode) -WAIT (PC Card I/O Mode) Description This signal is not asserted for all modes. O 42 This signal is not asserted for all modes. -IORDY (True IDE Mode) This signal is not asserted for all modes. -WE (PC Card Memory Mode) This is a signal driven by the host and used for strobing memory write data to the registers of the Compact Flash Card when the card is configured in the memory interface mode. It is also used for writing the configuration registers. -WE (PC Card I/O Mode) I 36 In PC Card I/O Mode, this signal is used for writing the configuration registers. -WE (True IDE Mode) In True IDE Mode this input signal is not used and should be connected to VCC by the host. -WP (PC Card Memory Mode) Memory Mode – The Compact Flash Card does not have a write protect switch. This signal is held low after the completion of the reset initialization sequence. -IOIS16 (PC Card I/O Mode) I/O Operation – When the Compact Flash Card is configured for I/O Operation, Pin 24 is used for the –I/O Selected is 16 Bit Port (-IOIS16) function. A Low signal indicates that a 16 bit or odd byte only operation can be performed at the addressed port. O 24 -IOCS16 (True IDE Mode) In True IDE Mode this output signal is asserted low when this device is expecting a word data transfer cycle. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 14 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.0 Card Function Explanation 2.1 Attribute Access Specifications When CIS-ROM region or Configuration register region is accessed, read and write operations are executed under the condition of –REG = “L” as follows. That region can be accessed by Byte/Word/Odd-byte modes, which are defined by PC card standard specifications. Table 7: Attribute Read Access Mode Mode Standby mode -REG L L L L Byte access (8-bit) Word access (16-bit) Odd byte access (8-bit) -CE2 H H H L L -CE1 A0 -OE -WE L L L H L H L L L L H H H H -CE1 A0 -OE -WE L L L H L H H H H H L L L L D8 -D15 High-Z High-Z High-Z Invalid Invalid D0 -D7 High-Z Even byte Invalid Even byte High-Z D8 -D15 Don’t care Don’t care Don’t care Don’t care Don’t care D0 -D7 Don’t care Even byte Don’t care Even byte Don’t care Table 8: Attribute Write Access Mode Mode Standby mode Byte access (8-bit) -REG Word access (16-bit) Odd byte access (8-bit) L L L L -CE2 H H H L L Figure 2: Attribute Access Timing Example Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 15 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.2 Task File Register Access Specifications There are two cases of Task File register mapping, one is mapped I/O address area, and the other is mapped Memory address area. Each case of Task File register read and write operations are executed under the condition as follows. That area can be accessed by Byte/Word/Odd Byte modes, which are defined by PC card standard specifications. 2.2.1 I/O Address Map Table 9: Task File Register Read Access Mode (i) Mode Standby mode Byte access (8-bit) Word access (16-bit) Odd byte access (8-bit) -REG -CE2 -CE1 H L H L L H L L L L L L H A0 L H -IORD -IOWR L L L L H H H H -OE -WE H H H H H H H H D8 -D15 High-Z High-Z High-Z Odd byte Odd byte D0 -D7 High-Z Even byte Odd byte Even byte High-Z D8 -D15 Don’t care Don’t care Don’t care Odd byte Odd byte D0 -D7 Don’t care Even byte Odd byte Even byte Don’t care Table 10: Task File Register Write Access Mode (i) Mode Standby mode Byte access (8-bit) Word access (16-bit) Odd byte access (8-bit) -REG -CE2 -CE1 H L H L L H L L L L L L H A0 L H -IORD -IOWR H H H H L L L L -OE -WE H H H H H H H H Figure 3: Task File Register Access Timing Example (i) 2.2.2 Memory Address Map Table 11: Task File Register Read Access Mode (ii) Mode Standby mode Byte access (8-bit) Word access (16-bit) Odd byte access (8-bit) -REG -CE2 -CE1 H H H L H H L H L L H L H A0 L H -IORD -IOWR L L L L H H H H -OE -WE H H H H H H H H D8 -D15 High-Z High-Z High-Z Odd byte Odd byte D0 -D7 High-Z Even byte Odd byte Even byte High-Z Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 16 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 12: Task File Register Write Access Mode (ii) Mode Standby mode -REG -CE2 -CE1 H H H L H H L H L L H L H Byte access (8-bit) Word access (16-bit) Odd byte access (8-bit) A0 L H -IORD -IOWR H H H H L L L L -OE -WE H H H H H H H H D8 -D15 Don’t care Don’t care Don’t care Odd byte Odd byte D0 -D7 Don’t care Even byte Odd byte Even byte Don’t care Figure 4: Task File Register Access Timing Example (ii) 2.2.3 True IDE Mode The card can be configured in a True IDE Mode of operation. This card is configured in this mode only when the – OE input signal is asserted GND by the host. In this True IDE Mode Attribute Registers are not accessible from the host. Only I/O operation to the task files and data registers are allowed. If this card is configured during power on sequence, data registers are accessed in word (16-bit). The card permits 8-bit accesses if the user issues a Set Feature Command to put the device in 8-bit mode. Table 13: True IDE Mode Read I/O Function Mode Invalid mode Standby mode Data register access Alternate status access Other task file access -CE2 L H H L H -CE1 L H L H L A0 -A2 -IORD -IOWR 0 6H 1-7H L L L H H H A0 -A2 -IORD -IOWR 0 6H 1-7H L L L H H H D8 -D15 High-Z High-Z Odd byte High-Z High-Z D0 -D7 High-Z High-Z Even byte Status out Data D8 -D15 Don’t care Don’t care Odd byte Don’t care Don’t care D0 -D7 Don’t care Don’t care Even byte Control in Data Table 14: True IDE Mode Write I/O Function Mode Invalid mode Standby mode Data register access Alternate status access Other task file access -CE2 L H H L H -CE1 L H L H L Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 17 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Figure 5: True IDE Mode I/O Access Timing Example 2.3 Configuration Register Specification This card supports four configuration registers for the purpose of the configuration and observation of this card. These registers can be used in memory card mode and I/O card mode. In True IDE mode, these registers cannot be used. 2.3.1 Configuration Option register (Address 200H) This register is used for setting the card configuration status and for issuing soft reset to the card. bit 7 SRESET NOTE: 1. bit 6 LevlREQ bit 5 INDEX bit 4 bit 3 bit 2 bit 1 bit 0 Initial value: 00H Table 15: Option Register Function Name R/W Function Setting this bit to “1”, places the card in the reset state (Card Hard Reset). This operation is equal to Hard Reset, except this bit is not cleared. Then this bit set to “0”, places the card in the reset state of Hard Reset (This bit is set to “0” by Hard Reset). Card configuration status is reset and the card internal initialized operation starts when Card hard Reset is executed, so next access to the card should be the same sequence as the power on sequence. SRESET (HOST->) R/W LevlREQ (HOST->) R/W This bit sets to “0” when pulse mode interrupt is selected, and “1” when level mode interrupt is selected. INDEX (HOST->) R/W This bit is used for select operation mode of the card as follows. When Power on, Card Hard Reset and Soft Reset, this data is “000000” for the purpose of Memory card interface recognition. Table 16: INDEX bit assignment 5 0 0 0 4 0 0 0 INDEX Bit 3 2 0 0 0 0 0 0 1 0 0 1 0 0 1 0 Task File register address Mapping mode 0H to FH, 400H to 7FFH xx0H to xxFH 1F0H to 1F7H, 3F6H to 3F7H Memory Mapped Contiguous I/O Mapped Primary I/O Mapped Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 18 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 0 0 0 0 1 1 170H to 177H, 376H to 377H Secondary I/O Mapped 2.3.2 Configuration and Status Register (Address 202H) This register is used for observing the card state. bit 7 CHGED bit 6 SIGCHG bit 5 IOIS8 bit 4 0 bit 3 0 bit 2 PWD bit 1 INTR bit 0 0 NOTE: 1. 1nitial value: 00H Table 17: Configuration and Status Register Function Name R/W CHGED (HOST->) R SIGCHG (HOST->) R/W IOIS8 (HOST->) R/W PWD (HOST->) R/W INTR (HOST->) R Function This bit indicates that CRDY/-BSY bit on Pin Replacement register is set to “1”. When CHGED bit is set to “1”, -STSCHG pin is held “L” at the condition of SIGCHG bit set to “1” and the card configured for the I/O interface. This bit is set or reset by the host for enabling and disabling the status-change signal (-STSCHG pin). When the card is configured I/O card interface and this bit is set to “1”, -STSCHG pin is controlled by CHGED bit. If this bit is set to “0”, -STSCHG pin is kept “H”. The host sets this field to “1” when it can provide I/O cycles only with one 8-bit data bus (D7 to D0). When this bit is set to “1”, the card enters sleep stat (Power Down mode). When this bit is reset to “0”, the card transfers to idle state (active mode). RRDY/-BSY bit on Pin Replacement Register becomes BUSY when this bit is changed. RRDY/BSY will not become Ready until the power state requested has been entered. This card automatically powers down when it is idle, and powers back up when it receives a command. This bit indicates the internal state of the interrupt request. This bit state is available whether I/O card interface has been configured or not. This signal remains true until the condition which caused the interrupt request has been serviced. If interrupts are disabled by the –IEN bit in the Device Control Register, this bit is a zero. 2.3.3 Pin Replacement Register (Address 204H) This register is used for providing the signal state of –IREQ signal when the card configured I/O card interface. bit 7 0 bit 6 0 bit 5 CRDY/-BSY bit 4 0 bit 3 1 bit 2 1 bit 1 RRDY/-BSY bit 0 0 NOTE: 1. Initial value 0CH Table 18: Pin Replacement Register Function Name R/W CRDY/-BSY (HOST->) R/W RRDY/-BSY (HOST->) R/W Function This bit is set to “1” when the RRDY/-BSY bit changes state. This bit may also be written by the host When read, this bit indicates +READY pin states. When written, this bit is used for CRDY/-BSY bit masking Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 19 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.3.4 Socket and Copy Register (Address 206H) This register is used for identification of the card from the other cards. Host can read and write this register. This register should be set by host before Configuration Option register is set. bit 7 0 bit 6 0 bit 5 0 bit 4 DRV# bit 3 0 bit 2 0 bit 1 0 bit 0 0 NOTE: 1. Initial value: 00H Table 19: Socket and Copy Register Function Name R/W DRV# (HOST->) 2.4 Function This field is used for the configuration of the plural cards. When host configures the plural cards, written the card’s copy number in this field. In this way, host can perform the card’s master/slave organization. R/W Task File Register Specification These registers are used for reading and writing the storage data in the card. These registers are mapped five types by the configuration of INDEX in Configuration Option register. The decoded addresses are shown as follows. Table 20: Memory map (INDEX=0) -REG 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 A10 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 A9 -A4 A3 0 0 0 0 0 0 0 1 1 1 1 1 1 A2 0 0 0 0 1 1 1 1 0 0 1 1 1 A1 0 0 0 0 1 1 1 1 0 0 1 1 1 A0 0 1 0 1 0 1 0 1 0 1 1 0 1 0 1 Offset 0H 1H 2H 3H 4H 5H 6H 7H 8H 9H DH EH FH 8H 9H -OE=L Data register Error register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Status register Dup. even data register Dup. odd data register Dup. error register Alt. status register Drive address register Even data register Odd data register -WE=L Data register Feature register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Command register Dup. even data register Dup. odd data register Dup. feature register Device control register Reserved Even data register Odd data register Table 21: Contiguous I/O map (INDEX=1) -REG 0 0 0 0 0 0 0 0 0 0 0 A10 -A4 A3 0 0 0 0 0 0 0 0 1 1 1 A2 0 0 0 0 1 1 1 1 0 0 1 A1 0 0 1 1 0 0 1 1 0 0 0 A0 0 1 0 1 0 1 0 1 0 1 1 Offset 0H 1H 2H 3H 4H 5H 6H 7H 8H 9H DH -IORD=L Data register Error register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Status register Dup. even data register Dup. odd data register Dup. error register -IOWR=L Data register Feature register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Command register Dup. even data register Dup. odd data register Dup. feature register Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 20 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 0 0 1 1 1 1 1 1 0 1 EH FH Alt. status register Drive address register Device control register Reserved Table 22: Primary I/O Map (INDEX=2) -REG 0 0 0 0 0 0 0 0 0 0 A10 A9 -A4 1FH 1FH 1FH 1FH 1FH 1FH 1FH 1FH 3FH 3FH A3 0 0 0 0 0 0 0 0 0 0 A2 0 0 0 0 1 1 1 1 1 1 A1 0 0 1 1 0 0 1 1 1 1 A0 0 1 0 1 0 1 0 1 0 1 -IORD=L Data register Error register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Status register Alt. status register Drive address register -IOWR=L Data register Feature register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Command register Device control register Reserved A0 0 1 0 1 0 1 0 1 0 1 -IORD=L Data register Error register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Status register Alt. status register Drive address register -IOWR=L Data register Feature register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Command register Device control register Reserved Table 23: Secondary I/O Map (INDEX=3) -REG 0 0 0 0 0 0 0 0 0 0 A10 A9 -A4 17H 17H 17H 17H 17H 17H 17H 17H 37H 37H A3 0 0 0 0 0 0 0 0 0 0 A2 0 0 0 0 1 1 1 1 1 1 A1 0 0 1 1 0 0 1 1 1 1 Table 24: True IDE Mode I/O Map -CE2 1 1 1 1 1 1 1 1 0 0 -CE1 0 0 0 0 0 0 0 0 1 1 A2 0 0 0 0 1 1 1 1 1 1 A1 0 0 1 1 0 0 1 1 1 1 A0 0 1 0 1 0 1 0 1 0 1 -IORD=L Data register Error register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Status register Alt. status register Drive address register -IOWR=L Data register Feature register Sector count register Sector number register Cylinder low register Cylinder high register Drive head register Command register Device control register Reserved 2.4.1 Data Register This register is a 16-bit register that has read/write ability, and it is used for transferring 1 sector data between the card and the host. This register can be accessed in word mode and byte mode. This register overlaps the Error and Feature register. bit 15 bit 14 bit 13 bit 12 bit 11 bit 10 bit 9 bit 8 bit 7 D0 to D15 bit 6 bit 5 bit 4 bit 3 bit 2 bit 1 bit 0 Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 21 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.4.2 Error Register This register is a read only register, and is used for analyzing the error content during card accessing. This register is valid when the BSY bit in Status Register and Alternate Status Register are set to “0” (Ready). bit 7 BBK bit 6 UNC bit 5 “0” bit 4 IDNF bit 3 “0” bit 2 ABRT bit 1 ‘0’ bit 0 AMNF Table 25: Error Register Function bit 7 6 4 2 0 Name BBK (Bad BlocK detected) UNC (Data ECC error) IDNF (ID Not Found) ABRT (AboRTed command) AMNF (Address Mark Not Found) Function This bit is set when a Bad Block is detected in requested ID field. This bit is set when Uncorrectable error is occurred at reading the card. The requested sector ID is in error or cannot be found. This bit is set if the command has been aborted because of the card status condition. (Not ready, Write fault, Invalid command, etc.) This bit is set in case of a general error. 2.4.3 Feature Register This register is a write only register, and provides information regarding features of the drive, which the host wishes to utilize. bit 7 bit 6 bit 5 bit 4 bit 3 Feature byte bit 2 bit 1 bit 0 2.4.4 Sector Count Register This register contains the numbers of sectors of data requested to be transferred on a read or write operation between the host and the card. If the value of this register is zero, a count of 256 sectors is specified. In plural sector transfer, if not successfully completed, the register contains the number of sectors, which need to be transferred in order to complete, the request. This register’s initial value is “01H”. bit 7 bit 6 bit 5 bit 4 bit 3 Sector count byte bit 2 bit 1 bit 0 2.4.5 Sector Number Register This register contains the starting sector number, which is started by following sector transfer command. bit 7 bit 6 bit 5 bit 4 bit 3 Sector number byte bit 2 bit 1 bit 0 2.4.6 Cylinder Low Register This register contains the low 8-bit of the starting cylinder address, which is started by following sector transfer command. bit 7 bit 6 bit 5 bit 4 bit 3 Cylinder low byte bit 2 bit 1 bit 0 2.4.7 Cylinder High Register This register contains the high 8-bit of the starting cylinder address, which is started by following sector transfer command. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 22 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB bit 7 bit 6 bit 5 bit 4 bit 3 Cylinder high byte bit 2 bit 1 bit 0 2.4.8 Drive Head Register This register is used for selecting the Drive number and head number for the following command. bit 7 1 NOTE: 1. bit 6 LBA bit 5 1 bit 4 DRV bit 3 Head # bit 2 bit 1 bit 0 DRV: Drive number Table 26: Drive Head Register Function bit 7 Name 1 6 LBA 5 1 4 DRV (DRiVe select) 3 -0 Head number Function This bit is set to “1”. LBA is a flag to select either Cylinder / Head / Sector (CHS) or Logical Block Address (LBA) mode. When LBA = 0, CHS mode is selected. When LBA = 1, LBA mode is selected. In LBA mode, the Logical Block Address is interrupted as follows: LBA07 - LBA00: Sector Number Register D7 - D0. LBA15 - LBA08: Cylinder Low Register D7 - D0. LBA23 - LBA16: Cylinder High Register D7 - D0. LBA27 - LBA24: Drive / Head Register bits HS3 - HS0. This bit is set to “1”. This bit is used for selecting the Master (Card 0) and Slave (Card 1) in Master/Slave organization. The card is set to be Card 0 or 1 by using DRV# of the Socket and Copy register. This bit is used for selecting the Head number for the following command. Bit 3 is MSB. 2.4.9 Status Register This register is read only register, and it indicates the card status of command execution. When this register is read in configured I/O card mode (INDEX = 1, 2, 3) and level interrupt mode, -IREQ is negated. This register should be accessed in byte mode. In word mode, it is recommended that Alternate status register may be used as this register. bit 7 BSY bit 6 DRDY bit 5 DWF bit 4 DSC bit 3 DRQ bit 2 CORR bit 1 IDX bit 0 ERR Table 27: Status Register Function bit Name 7 BSY (BuSY) 6 DRDY (Drive ReaDY) 5 4 DWF (Drive Write Full) DSC (Drive Seek Complete) 3 DRQ (Data ReQuest) 2 CORR (CORRected data) 1 IDX (InDeX) 0 ERR (ERRor) Function This bit is set when the card internal operation is executing. When this bit is set to “1”, other bits in this register are invalid. If this bit and DSC bit are set to “1”, the card is capable of receiving the read or write or seek requests. If this bit is set to “0”, the card prohibits these requests. This bit is set if this card indicates the write fault status. This bit is set when the drive seek complete. This bit is set when the information can be transferred between the host and Data register. This bit is cleared when the card receives the other command. This bit is set when a correctable data error has been occurred and the data has been corrected. This bit is always set to “0”. This bit is set when the previous command has ended in some type of error. The error information is set in the other Status register or Error register. This bit is cleared by the next command. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 23 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.4.10 Alternate Status Register This register is the same as Status register in physically, so the it assignment refers to previous item of Status register. But this register is different from Status register that –IREQ is not negated when data read. 2.4.11 Command Register This register is write only register, and it is used for writing the command at executing the drive operation. The command code written in the command register, after the parameter is written in the Task File during the card is Ready state. Table 28: Command Register Command Command Code Check power mode Execute drive diagnostic Erase sector Format track Identify Drive Idle Idle immediate Initialize drive parameters Read buffer Read multiple Read long sector Read sector Read verify sector Recalibrate Request sense Seek Set features Set multiple mode Set sleep mode Stand by Stand by immediate Translate sector Wear level Write buffer Write long sector Write multiple Write multiple w/o erase Write sector Write sector w/o erase Write verify E5H or 98H 90H C0H 50H ECH E3H or 97H E1H or 95H 91H E4H C4H 22H or 23H 20H or 21H 40H or 41H 1XH 03H 7XH EFH C6H E6H or 99H E2H or 96H E0H or 94H 87H F5H E8H 32H or 33H C5H CDH 30H or 31H 38H 3CH FR N N N N N N N N N N N N N N N N Y N N N N N N N N N N N N N SC N N Y Y N Y N Y N Y N Y Y N N N N Y N N N Y N N N Y Y Y Y Y SN N N Y N N N N N N Y Y Y Y N N Y N N N N N Y N N Y Y Y Y Y Y Used Parameter CY DR HD N Y N N Y N Y Y Y Y Y Y N Y N N Y N N Y N N Y Y N Y N Y Y Y Y Y Y Y Y Y Y Y Y N Y N N Y N Y Y Y N Y N N Y N N Y N N Y N N Y N Y Y Y N Y Y N Y N Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y LBA N N Y Y N N N N N Y Y Y Y N N Y N N N N N Y N N Y Y Y Y Y Y NOTE: FR: Feature register SC: Sector Count register SN: Sector Number register CY: Cylinder register DR: DRV bit of Drive Head register HD: Head Number of Drive Head register LBA: Logical Block Address Mode Supported Y: The register contains a valid parameter for this command N: The register does not contain a valid parameter for this command. 2.4.12 Device Control Register Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 24 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB This register is write only register, and it is used for controlling the card interrupt request and issuing an ATA soft reset to the card. bit7 bit6 bit5 bit4 bit3 1 bit2 SRST bit1 nIEN bit0 0 Table 29: Device Control Register Function bit 7 -4 3 Name 2 SRST (Software ReSeT) 1 nIEN (Interrupt ENable) 0 0 1 Function Don’t care This bit is set to “1”. This bit is set to “1” in order to force the card to perform Task File Reset operation. This does not change the Card Configuration registers as a Hardware Reset does. The card remains in Reset until this bit is reset to “0”. This bit is used for enabling –IREQ. When this bit is set to “0”, –IREQ is enabled. When this bit is set to “1”, –IREQ is disabled. This bit is set to “0”. 2.4.13 Drive Address Register This register is read only register, and it is used for confirming the drive status. This register is provided for compatibility with the AT disk drive interface. It is recommended that this register be not mapped into the host’s I/O space because of potential conflicts on bit7. bit 7 bit 6 nWTG bit 5 nHS3 bit 4 nHS2 bit 3 nHS1 bit 2 nHS0 bit 1 nDS1 bit 0 nDS0 Table 30: Drive Address Register Function bit 7 6 5 -2 1 0 2.5 Name nWTG (WriTing Gate) nHS3 -0(Head Select3 0) nDS1 (Idrive Select1) nDS0 (Idrive Select0) Function This bit is unknown. This bit is unknown. These bits are the negative value of Head Select bits (bit 3 to 0) in Drive/Head register. This bit is unknown. This bit is unknown. ATA Command Specification This table summarizes the ATA command set with the paragraphs. Following shows the support commands and command codes, which are written in, command registers. Table 31: ATA Command Set No. 1 2 3 4 5 6 7 8 Command Check power mode Execute drive diagnostic Erase sector Format track Identify Drive Idle Idle immediate Initialize drive parameters Command Code E5H or 98H 90H C0H 50H ECH E3H or 97H E1H or 95H 91H FR - SC Y Y Y Y SN Y - CY Y Y - DR Y Y Y Y Y Y Y Y HD Y Y Y LBA Y Y - Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 25 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Read buffer Read multiple Read long sector Read sector Read verify sector Recalibrate Request sense Seek Set features Set multiple mode Set sleep mode Stand by Stand by immediate Translate sector Wear level Write buffer Write long sector Write multiple Write multiple w/o erase Write sector Write sector w/o erase Write verify 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 E4H C4H 22H, 23H 20H, 21H 40H, 41H 1XH 03H 7XH EFH C6H E6H or 99H E2H or 96H E0H or 94H 87H F5H E8H 32H or 33H C5H CDH 30H or 31H 38H 3CH Y - Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y NOTE: FR: Feature register SC: Sector Count register (00H to FFH) SN: Sector Number register (01H to 20H) CY: Cylinder register (to) DR: DRV bit of Drive Head register HD: Head No. (0 to 3) of Drive Head register NH: No. of Heads Y: Set up - : Not Set up 2.5.1 1. 2. 3. 4. 5. ATA Command Set Description Check Power Mode (code: E5H or 98H): This command checks the power mode. Execute Drive Diagnostic (code: 90H): This command performs the internal diagnostic tests implemented by the Card. Erase Sector(s) (code: C0H): This command is used to erase data sectors. Format Track (code: 50H): This command writes the desired head and cylinder of the selected drive. But selected sector data is not exchanged. This card accepts a sector buffer of data from the host to follow the command with same protocol as the Write Sector command. Identify Drive (code: ECH): This command enables the host to receive parameter information from the Card. Table 32: Identify Drive Information Word Address Default Value Total Bytes 0 848Ah 2 1 2 3 4 5 6 XXXX 0000h 00XXh 0000h XXXX XXXX 2 2 2 2 2 2 Data Field Type Information General Configuration: 848Ah: Removable Disk (Default) 044Ah: Fixed Disk (Option) Number of cylinders Reserved Number of heads Number of unformatted bytes per track Number of unformatted bytes per sector Number of sectors per track Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 26 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 6. 7. 8. 9. 10. 11. 12. 13. 14. 7 -8 9 10 -19 20 21 22 23 -26 27-46 47 48 XXXX 0000h aaaa 0002h 0002h 0004h aaaa aaaa 0001h 0000h 4 2 20 2 2 2 8 40 2 2 49 0200h 2 50 51 52 53 54 55 56 57-58 59 60 -61 62 0000h 0200h 0000h 0003h XXXXh XXXXh XXXXh XXXXh 010Xh XXXX 0000h 2 2 2 2 2 2 2 4 2 4 2 63 0000h 2 64 65 66 67 68 69-127 128-159 160-255 0003h 0000h 0000h 0078h 0078h XXXXh 0000h 0000h 2 2 2 2 2 130 64 192 Number of sectors per card (Word 7 = MSW, Word 8 = LSW) Reserved Serial Number in ASCII (Right Justified) Buffer type: Dual ported multi-sector Buffer size in 512 byte increments # of ECC bytes passed on Read/Write Long Commands Firmware revision in ASCII. Big Endian Byte Order in Word Model number in ASCII (Left Justified) Big Endian Byte Order in Word Maximum of 1 sector on Read/Write Multiple command Double Word not supported Capabilities: Bit 9: LBA Supported Reserved PIO data transfer cycle timing mode 2 DMA data transfer cycle timing mode (Not Supported) Field validity Current number of cylinders Current number of heads Current sectors per track Current capacity in sectors (LBAs) (Word 57 = LSW, Word 58 = MSW) Multiple Sector Setting is valid Total number of sectors addressable in LBA Mode Reserved Multiword DMA Transfer: 0000h: Not Supported Advanced PIO Modes supported Minimum DMA transfer cycle time per word Recommended DMA transfer cycle time. Minimum PIO transfer cycle time without flow control Minimum PIO transfer cycle time with IORDY flow control Reserved Reserved Vendor Unique Bytes Reserved Idle (code: E3H or 97H): This command causes the PC Card to set BSY, enter the Idle mode, clear BSY and generate an interrupt. If sector count is non-zero, the automatic power down mode is enabled. If the sector count is zero, the automatic power down mode is disabled. Idle Immediate (code: E1H or 95H): This command causes the Card to set BSY, enter the Idle (Read) mode, clear BSY and generate an interrupt. Initialize Drive Parameters (code: 91H): This command enables the host to set the number of sectors per track and the number of heads per cylinder. Read Buffer (code: E4H): This command enables the host to read the current contents of the PC card’s sector buffer. Read Multiple (code: C4H): This command performs similarly to the Read Sectors command. Interrupts are not generated on each sector, but on the transfer of a block, which contains the number of sectors defined by a Set Multiple command. Read Long Sector (code: 22H, 23H): This command performs similarly to the Read Sector(s) command except that it returns 516 bytes of data instead of 512 bytes. Read Sector(s) (code: 20H, 21H): This command reads from 1 to 256 sectors as specified in the Sector Count register. A sector count of 0 requests 256 sectors. The transfer begins at the sector specified in the Sector Number register. Read Verify Sector(s) (code: 40H, 41H): This command is identical to the Read Sectors command, except that DRQ is never set and no data is transferred to the host. Recalibrate (code: 1XH): This command is effectively a NOP command to the Card and is provided for compatibility purposes. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 27 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 15. Request Sense (code: 03H): This command requests an extended error code after command ends with an error. 16. Seek (code: 7XH): This command is effectively a NOP command to the Card although it does perform a range check. 17. Set Features (code: EFH): This command is used by the host to establish or select certain features. Feature 01H 55H 66H 81H BBH CCH Operation Enable 8-bit data transfers. Disable Read Look Ahead. Disable Power on Reset (POR) establishment of defaults at Soft Reset. Disable 8-bit data transfer. 4 bytes of data apply on Read/Write Long commands. Enable Power on Reset (POR) establishment of defaults at Soft Reset. 18. Set Multiple Mode (code: C6H): This command enables the Card to perform Read and Write Multiple operations and establishes the block count for these commands. 19. Set Sleep Mode (code: E6H or 99H): This command causes the Card to set BSY, enter the Sleep mode, clear BSY and generate an interrupt. 20. Stand By (code: E2H or 96H): This command causes the Card to set BSY, enter the Sleep mode (which corresponds to the ATA “Standby” Mode), clear BSY and return the interrupt immediately. 21. Stand By Immediate (code: E0H or 94H): This command causes the Card to set BSY, enter the Sleep mode (which corresponds to the ATA “Standby” Mode), clear BSY and return the interrupt immediately. 22. Translate Sector (code: 87H): This command allows the host a method of determining the exact number of times a user sector has been erased and programmed. 23. Wear level (code: F5H): This command is effectively a NOP command and only implemented for backward compatibility. The Sector Count Register will always be returned with a 00H indicating Wear Level is not needed. 24. Write Buffer (code: E8H): This command enables the host to overwrite contents of the Card’s sector buffer with any data pattern desired. 25. Write Long Sector (code: 32H or 33H): This command is provided for compatibility purposes and is similar to the Write Sector(s) command except that it writes 516 bytes instead of 512 bytes. 26. Write Multiple (code: C5H): This command is similar to the Write Sector command. Interrupts are not presented on each sector, but on the transfer of a block, which contains the number of sectors defined by Set Multiple command. 27. Write Multiple without Erase (code: CDH): This command is similar to the Write Multiple command with the exception that an implied erase before write operation is not performed. 28. Write Sector(s) (code: 30H or 31H): This command writes from 1 to 256 sectors as specified in the Sector Count register. A sector count of zero requests 256 sectors. The transfer begins at the sector specified in the Sector Number register. 29. Write Sector(s) without Erase (code: 38H): This command is similar to the Write Sector(s) command with the exception that an implied erase before write operation is not performed. 30. Write Verify (code: 3CH): This command is similar to the Write Sector(s) command, except each sector is verified immediately after being written. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 28 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 2.5.2 Sector Transfer Protocol Figure 6: Sector Read NOTE: 1 sector read procedure after the card configured I/O interface is shown as follows. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 29 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Figure 7: Sector Write NOTE: 1 sector write procedure after the card configured I/O interface is shown as follows. Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 30 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB 3.0 Electrical Specification 3.1 General Table 33: Absolute Maximum Ratings (VCC=3.3V ± 5% or VCC=5V ± 10%) Symbol VCC VIN / VOUT TA TA TS V* Parameter VCC With Respect to GND All Input/Output Voltages1 Operating Temperature (Standard Temp) Operating Temperature (Industrial Temp) Storage Temperature Voltage on any Pin Except VCC with Respect to GND Min -0.3 -0.3 0 -40 -65 -0.5 Max 5.5 VCC + 0.3 70 85 150 VCC + 0.5 MIN -10 20k 20k MAX 10 50k 50k Units V V °C °C °C V NOTE: 1. VIN / VOUT Min. = -2.0V for Pulse Width 0.20ns Table 34: Input Leakage Control Symbol IL RPU1 RPD1 Parameter Input Leakage Current Pull Up Resistor Pull Down Resistor Type IxZ IxU IxD Conditions Vih = Vcc/Vil = Gnd Vcc = 5.0V Vcc = 5.0V Units µA Ohm Ohm NOTE: The minimum pull-up resistor leakage current meets the PCMCIA specification of 10k ohms but is intentionally higher in the Compact Flash Memory Card to reduce power use. Table 35: Input Characteristics Type Parameter 1 Input Voltage CMOS 2 Input Voltage CMOS 3 Input Voltage CMOS Schmitt Trigger Symbol Vih Vil Vih Vil Vih Vil MIN 2.4 Vcc = 3.3 V TYP MAX MIN 2.4 Vcc = 5.0 V TYP MAX 0.6 1.5 0.8 2.0 0.6 1.8 1.0 0.8 2.8 2.0 Units V V V Table 36: Output Drive Type Type OTx OZx OPx ONx Output Type Totempole Tri-State N-P Channel P-Channel Only N-Channel Only Valid Conditions Ioh & Iol Ioh & Iol Ioh only Iol only Wintec W7CFxxx-H4 and W8CFxxx-H4 Series Datasheet v1 08.doc August 2013  Wintec Industries, Inc. 31 TM INDUSTRIAL GRADE CompactFlash Card W7CFxxxA-H4 Series RoHS 6/6 Compliant 256MB – 32GB Table 37: Output Drive Characteristics Type Parameter Symbol Voh Conditions Ioh = -4 mA Vol Iol = 4 mA Voh Ioh = -8 mA Vol Iol = 8 mA Voh Ioh = -8 mA Vol Iol = 8 mA Ioz Vol = Gnd Voh = Vcc Output Voltage 1 Output Voltage 2 3 Output Voltage X Tri-State Leakage Current MIN Vcc -0.8V TYP MAX GND +0.4V Vcc -0.8V GND +0.4V Vcc -0.8V GND +0.4V 10 -10 Units V V V µA Table 38: Capacitance (Ta = 25°C, f = 1MHz) Parameter Input capacitance Output capacitance Symbol Cin Cout Condition Vin = 0V Vout = 0V Min - Max 10 35 Unit pF pF Table 39: Power-up/Power-down Timing The timing specification was defined to retain data in the Flash Card during power-up or power-down cycles and to permit peripheral cards to perform power-up initialization. Item CE signal level1 CE Setup Time CE Recover Time Vcc Rising Time2 Reset Width NOTE: 1. 2. Symbol Condition Vi (CE) 0V < Vcc < 2.0V 2.0V < Vcc < VIH < VIH < Vcc Tsu (Vcc) Tsu (RESET) Trec (Vcc) tpr tpf Tw (RESET) Th (Hi-z Reset) Ts (Hi-z Reset) 10% → 90% of (Vcc + 5%) 90% of (Vcc – 5%) → 10% Min 0
W7CF001G1XA-H40TF-01D.A6 价格&库存
很抱歉,暂时无法提供与“W7CF001G1XA-H40TF-01D.A6”相匹配的价格&库存,您可以联系我们找货
