W7ES016G1TA-J51MC2-004.01
    WINTECINDUSTRIES
    Solid State Drive (SSD) 16GB SATA II FLASH - NAND (SLC) Slim-SATA 5V
W7ES016G1TA-J51MC2-004.01 数据手册
Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE WITHOUT NOTICE. NOTHING IN THIS DOCUMENT SHALL BE CONSTRUED AS GRANTING ANY LICENSE, EXPRESS OR IMPLIED. ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS” BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND.  Please contact your nearest Wintec representative for the latest updates or additional product information. WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 1 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series Revision History Revision Month Year 0.99 1.0 1.1 September October January 2011 2011 2012 WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. History Preliminary Release Added 8GB and 16GB capacities Added 32GB SLC Configuration Revision 1.1 2 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series Table of Contents 1.0 2.0 3.0 4.0 5.0 General Product Specification .........................................................................................................................5 Electrical Specification....................................................................................................................................7 Software Interface ...........................................................................................................................................8 Physical Specifications .................................................................................................................................. 11 Ordering Information .................................................................................................................................. 122 WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 3 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series Wintec Slim SATA Drive WxESxxxG1TA-J51xx Series Features: GENERAL  Density up to 128GB  JMicron 605 controller  SATA-II interface and backwards compatible  High-Performance SLC or MLC NAND Flash memory PERFORMANCE  High Performance 160MB/s Seq. Read (SATA-II)  High Performance 100MB/s Seq. Write (SATA-II)  Random Read: 6K IOPS at 4KB transfer (SATA-II) RELIABILITY  Bad Block Management & Wear Leveling  ECC Engine: Up to 24 bits correctable per 1KB sector  Data Integrity under power-cycling  MTTF: 2,000,000 operating hours Wintec Slim SATA Drive NOTE: See Section 5.0 for Configuration & Ordering Guide COMPATIBILITY  Serial ATA Revision 2.6 Compliant  ATA/ATAPI-7 Compliant  Supports TRIM and S.M.A.R.T commands  RoHS compliant Description: The Wintec Industries WxESxxxG1TA-J51xx series of ROHS Compliant Slim SATA Drives are constructed with NAND-type flash memory devices paired to JMicron 605 SSD controller for virtual-to-physical address mapping and other sophisticated flash management functions. The Wintec Flash Solid State Disk (SSD) provides major advantages over the traditional magnetic hard disk drive (HDD). Faster access time and transfer rate, silent operation and low power consumption, better shock and vibration resistance, and lower total cost of ownership make the Wintec SSDs an attractive choice as the next generation mass storage device. The Wintec J5 series Slim SATA provides high-speed data transfer and reliability utilizing SLC or MLC NAND-flash in storage capacities ranging from 8GB to 128GB, in JEDEC MO-297A form factor. Its robust design enables the SSD to achieve outstanding reliability and performance. The JMF605 controller implements bad block management and dynamic/static wear-leveling techniques to ensure that the NAND flash memory is not worn out prematurely. The controller utilizes 24 bits/1K byte sector BCH ECC algorithms for error correction. The drive supports basic SMART features to monitor the drive status and TRIM command to efficiently maintain the data. The Wintec J5 series Slim SATA drives are ideal for portable and desktop computers, point of sale (POS), handheld device, gaming machine, network equipment, notebook, thin-client and set-top boxes (STB). WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 4 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 1.0 General Product Specification For all the following specifications, values are defined at ambient temperature unless otherwise stated. Table 1: User Capacity Specifications Model Number¹ (typ)2,3 W7ES008G1TA-J51xx-yyy.zz W7ES016G1TA-J51xx-yyy.zz W7ES032G1TA-J51xx-yyy.zz W2ES032G1TA-J51xx-yyy.zz W2ES064G1TA-J51xx-yyy.zz W2ES128G1TA-J51xx-yyy.zz NAND Flash Type SLC SLC SLC MLC MLC MLC Total Capacity 8GB 16GB 32GB 32GB 64GB 128GB User Capacity 8GB 15GB 30GB 30GB 60GB 120GB Over-provison 7% 7% 7% 7% 7% 7% NOTE: 1. See Section 4.0 for Configuration & Ordering Guide 2. 1GB = 1,000,000,000 Bytes 3. Capacity available to end-user is less than “Total Capacity” due to flash controller overhead, and may vary with flash configuration. Table 2: Typical Performance Specifications Parameter Sustained Sequential Read Sustained Sequential Write Sustained IOPS Random Read Typical Performance4 up to 140MB/sec (MLC); 160MB/sec (SLC) up to 60MB/sec (MLC); 100MB/sec (SLC) up to 5000 IOPS (MLC); up to 6000 IOPS (SLC) NOTE: 4. Bandwidth measured on high-performance desktop system. Note that performance may also vary depending on host system, drive capacity, and drive configuration. Measured at QD=32. Table 3: Flash Endurance Parameter Spec up to 100,000 cycles for SLC* up to 10,000 cycles for MLC* 5 Years (Min.) 2,000,000 Hours Program/Erase Cycles Data Retention MTTF * P/E Cycles vary based on the NAND Flash Type/process. Table 4: SSD Data Reliability Parameter Non-Recoverable Errors Raw ECC Correctability Spec < 1 in 1016 Bytes Read Up to 24 bits / 1024 Bytes data Table 5: Environmental Specifications Parameters Temperature Commercial Temp. Humidity (Non-Condensing) Vibration Shock (Operating) Noise WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Operating 0C to 70C 5% to 85% 20 G RMS 1,500 G (Max.) 0 dB Revision 1.1 Non-Operating -55C to 95C 5% to 95% N/A 0 dB 5 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 1.1 Block Diagram Flash Controller 1 & ECC Engine SATA Controller SATA II I/F SATA II PHY BUS CPU Flash Controller 4 & ECC Engine Channel 1 SLC/MLC NAND FLASH Channel 2 SLC/MLC NAND FLASH Channel 3 SLC/MLC NAND FLASH Channel 4 SLC/MLC NAND FLASH Figure 1. Block Diagram 1.2 Architecture The Wintec J5 series SSD utilizes a single flash controller chip with 4 parallel channels of flash memory interface. The flash controller also simultaneously manages the file read and write interface with the host system via a single SATA-II interface.By utilizing 4 parallel channels of SLC or MLC flash memory, Slim SATA SSD can provide both high performance and reliability, while maintaining a minimal unit cost. WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 6 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 2.0 Electrical Specification 2.1 General Table 6: Absolute Maximum Ratings Symbol VCC Parameter VCC With Respect to GND Min -0.5 Max Units 6.0 V Min 4.5 0 5 Max 5.5 70 85 Units V C % Idle Power consumption Typical operating power consumption Maximum operating power consumption Value 0.35 0.7 1.25 Units Watts Watts Watts Table 7: Typical Operating Conditions (VCC=5V  10%) Symbol VCC TA H Parameter VCC With Respect to GND Operating Temperature (Commercial Temp) Humidity Table 8: Power consumption Symbol Pi PT Pmax 2.2 Parameter SATA Pin Assignment and Description The SATA connectors are compliant with standard SATA power specifications. As is standard, power may be supplied to all of the power pins. However, only the 5V power pins are utilized to provide power to the SSD. Therefore, where non-standard power supplies and connections are utilized, the power supply does not need to supply the SSD with power to the 3.3V or 12V power pins. Table 9: SATA connector specification compliant No. Signal Plug Connector pin definition S1 GND S2 A+ S3 A- S4 GND S5 B- S6 B+ S7 GND Ground Differential signal A Ground Differential signal B Ground Key and spacing separate signal and power segments Power P1 V33 3.3V power (Not Used) P2 V33 3.3V power (Not Used) P3 V33 3.3V power, pre-charge (Not Used) P4 GND Ground WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 7 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series P5 GND Ground P6 GND Ground P7 V5 5V power, pre-charge P8 V5 5V power P9 V5 5V power P10 GND Ground P11 DAS/DSS Device Activity Signal P12 GND Ground P13 V12 12V power, pre-charge (Not Used) P14 V12 12V power (Not Used) P15 V12 12V power (Not Used) 3.0 Software Interface 3.1 ATA Command Set All mandatory, and many optional commands and features are supported. The following tables summarize the ATA feature set and commands. Table 11: ATA Command Command Name CHECK POWER MODE DEVICE CONFIGURATION OVERLAY EXECUTE DIAGNOSTICS FLUSH CACHE FLUSH CACHE EXT IDENTIFY DEVICE IDLE IDLE IMMEDIATE NOP INITIALIZE DEVICE PARAMETERS READ BUFFER READ DMA READ DMA EXT READ FPDMA QUEUED READ LOG EXT READ MULTIPLE READ MULTIPLE EXT READ NATIVE MAX ADDRESS READ NATIVE MAX ADDRESS EXT READ SECTOR(S) READ SECTOR(S) EXT WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Code E5h B1h 90h E7h EAh ECh E3h E1h 00h 91h E4h C8h or C9h 25h 60h 2Fh C4h 29h F8h 27h 20h or 21h 24h Revision 1.1 SC O X X X X X O X F O X O O O O O O X X O O SN X X X X X X X X F X X O O O O O O X X O O Parameters Used CY DR X O X O X O X O X O X O X O X O F O X O X O O O O O O O O O O O O O X O X O O O O O 8 HD X X X X X X X X X O X O O O O O O X X O O FT X O X X X X X X O X X X X O O X X X X X X Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series READ VERIFY SECTOR(S) READ VERIFY SECTOR(S) EXT RECALIBRATE SECURITY DISABLE PASSWORD SECURITY ERASE PREPARE SECURITY ERASE UNIT SECURITY FREEZE LOCK SECURITY SET PASSWORD SECURITY UNLOCK SEEK SET FEATURES SET MAX SET MAX ADDRESS EXT SET MULTIPLE MODE SLEEP SMART STANDBY STANDBY IMMEDIATE WRITE BUFFER WRITE DMA WRITE DMA EXT WRITE DMA FUA EXT WRITE FPDMA QUEUED WRITE LOG EXT WRITE MULTIPLE WRITE MULTIPLE EXT WRITE MULTIPLE FUA EXT WRITE SECTOR(S) WRITE SECTOR(S) EXT WRITE VERIFY 40h or 41h 42h 10h F6h F3h F4h F5h F1h F2h 7xh EFh F9h 37h C6h E6h B0h E2h E0h E8h CAh or CBh 35h 3Dh 61h 3Fh C5h 39h CEh 30h or 31h 34h 3Ch O O X X X X X X X X O O O O X X X X X O O O O O O O O O O O O O X X X X X X X X X O O X X X X X X O O O O O O O O O O O O O X X X X X X X O X O O X X O X X X O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O Note: O = Valid, X = Don’t care SC = Sector Count Register SN = Sector Number Register CY = Cylinder Low/High Register DR = Device Select Bit (Device/Head Register Bit 4) HD = Head Select bit (Device/Head Register Bit 3-0) FT = Features Register WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 9 O O X X X X X X X O X O O X X X X X X O O O O O O O O O O O X X X X X X X X X X O O X X X O X X X X X X O X X X X X X O Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 3.2 SMART Command Support The J5 series SSD drive supports basic SMART command Set used to define some vendor-specific data to report spare/bad block numbers in each memory management unit. Table 12: SMART Command Set Value D0h D2h D8h DAh Command Read Data attributes Enable/Disable attribute autosave Enable SMART operation Smart Return Status Value D1h D3h D9h Command Read attribute Threshold Save attribute Values Disable SMART operation 3.2.1 SMART Attribute Sector The following 512 bytes defines the SMART format. Users can obtain the data using the “Read Data” command. Table 13: SMART Attribute Data Structure Byte 0-1 2-13 14-361 362 363 364-365 366 367 368-369 370 371 372 373 374-510 511 Description Data Structure revision number 1st attribute data 2nd-30th Individual attribute data Off-line data collection status Self-test execution status Total time in seconds to complete off-line data collection Reserved Off-line data collection capability SMART capability Error logging capability Self-test failure checkpoint Short self-test routine recommended polling time (in minutes) Extended self-test routine recommended polling time (in minutes) Reserved Data structure checksum 3.2.2 Supported SMART Attributes The following table summarizes the SMART attribute Menu. Table 14: SMART Attribute Menu Summary ID 1 2 3 5 7 8 9 Hex 01h 02h 03h 05h 07h 08h 09h Attribute Name Read Error Rate Throughput Performance Spin up time Reallocated Sector Count Seek Error Rate Seek Time Performance Power-On hours Count 10 0Ah Spin Retry Count WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 10 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 12 168 170 173 175 192 194 197 240 0Ch A8h AAh ADh AFh C0h C2h C5h F0h Device Power Cycle Count SATA PHY Error Count Bad Block Count Erase Count Bad Cluster Table Count Unexpected power Loss Count Temperature Current Pending Sector Count Write Head 4.0 Physical Specifications I G F A D E H C B Figure 2: Physical Dimensions Table 15: Physical Specifications Symbol A B C D E F G H I Min 53.85 2.15 3.85 WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Common Dimensions (mm) Nom 39.00 54.00 49.40 25.00 2.30 0.80 33.39 4.00 Revision 1.1 Max 54.15 2.45 4.00 4.15 11 Wintec Slim SATA Drive WxESxxxG1TA-J51xx (J5) Series 5.0 Ordering Information Table 16: Product Availability List & Naming Model Number WxES008G1TA-J51yyy-zzz.aa WxES016G1TA-J51yyy-zzz.aa WxES032G1TA-J51yyy-zzz.aa WxES064G1TA- J51yyy-zzz.aa WxES128G1TA- J51yyy-zzz.aa (x) Flash Type 7: SLC Flash 2: MLC Flash (yyy) Flash IC Manufacturer, Die Revision, Process P: Samsung M: M-die 3:3x nm I: Intel A: A-die 2:2x nm M: Micron B: B-die T: Toshiba C: C-die (aa) NAND Flash Type SLC/MLC SLC/MLC SLC/MLC SLC/MLC SLC/MLC User Capacity 7.5GB 15GB 30 GB 60 GB 120 GB (zzz) Component Flash Configuration 002: 2-Nand, Single Die Package, 1-CE 02D: 2-Nand, Dual Die Package, 1-CE 2D2: 2-Nand, Dual Die Package, 2-CE 2Q2: 2-Nand, Quad Die Package, 2-CE 004: 4-Nand, Single Die Package, 1-CE 4D2: 2-Nand, Dual Die Package, 2-CE 4Q2: 4-Nand, Quad Die Package, 2-CE Firmware Revision/Options Please contact the factory for the latest firmware revisions and/or custom labeling and programming identification. Contact Us (US & Int’l): Wintec Industries OEM Sales 675 Sycamore Drive Milpitas, CA 95035 Ph: 408-856-0500 Fax: 408-856-0501 oemsales@wintecind.com http://www.wintecind.com/oem About Wintec Industries, Inc.: Wintec Industries, founded in 1988, is headquartered in Milpitas, California. Wintec, an ODM/OEM solution provider, specializes in product designs and manufacturing, including Flash modules (CF, SD, USB, embedded Flash, SSD, etc), DRAM modules (RDIMM, SODIMM, UDIMM), wireless products, modem products (embedded and USB), Advanced Digital Display products (ADD2 DVI, HDMI, digital signage), and so on. With experienced engineering team in Silicon Valley, Wintec provides a wide range of services and solutions for customers. Wintec is ISO9001-2000 certified. Important Notice: Wintec Industries makes no representations or warranties with respect to the contents of this datasheet and specifically disclaims any implied warranties of any product design for any particular purpose. Wintec Industries reserves the rights to revise this publication and to make changes from time to time in the content hereof without obligation of Wintec Industries to notify any person or organization of such revisions or changes. WintecSSD-WxESxxxG1TA-J51xx_v1.1 Jan 2012  Wintec Industries, Inc. Revision 1.1 12
W7ES016G1TA-J51MC2-004.01 价格&库存
很抱歉,暂时无法提供与“W7ES016G1TA-J51MC2-004.01”相匹配的价格&库存,您可以联系我们找货
