WIZ550SR Datasheet
Overview
This page provides information about the hardware description of WIZ550SR as following:
Hardware Specification
Electrical Characteristics
Schematic
Dimension
The revision history will be updated in this page in case of any changes of hardware specification
or exterior design.
WIZ550SR
Very small size Serial to Ethernet Module.
WIZnet TCP/IP Chip W5500.
STM32F103RCT6.
Not include a transformer and RJ45.
2.00mm Pitch Pin Header Type, 1×11.
Support the MDI(Medium Dependent Interface).
o TXN, TXP, RXN, RXP
Support the UART interface.
o RXD, TXD, RTS, CTS, DSR(Option), DTR(Option)
o Support the RS-232C Interface.
o Will be soppoted the RS-422/485 Interface.
Support the Debug UART.
o DEBUG RXD, DEBUG TXD
Support the PHY Status Output.
o Active LED, Link LED
Support the STATUS output.
o LOW : TCP Connect.
o HIGH : TCP Diconnect.
System Pins.
o RESET : System Reset, Active Low.
o BOOT0 : MCU BOOT mode operation, Active High.
o H/W TRIG : App BOOT mode operation, Active Low.
Support the Indicator LED.
o Power LED(LD3).
o LED 0(LD1) :
o LED 1(LD2) :
Support the Pin Header Hole for Firmware upload.
o 2.54mm Pitch, Not Mount.
Support the Pin Header Hole for SWD.
o 1.27mm Pitch, Not Mount.
Include eeprom for data storage.
Operation Temperature : -40℃ ~ 85℃
Size : 22mm x 24mm x 13mm
WIZ550SR Pin Out
WIZ550SR Pin Description
Ref
No.
Pin
No.
1
Symbol
3.3V
Type
Description
P
+3.3V Input Power
2
3.3V_OUT
P
+3.3V Output Power.
This pin is connected to the TX resistor of MDI signal and Center
TAP of RJ45.
3
TXN
O
MDI Signal. TX Positive.
4
TXP
O
MDI Signal. TX Negative.
5
GND
P
Ground.
6
RXN
I
MDI Signal. RX Negative.
7
RXP
I
MDI Signal. RX Positive.
8
GND
P
Ground.
9
ACT LED
O
PHY Active LED
J1
Ref
No.
Pin
No.
Type
Description
10
LINK LED
O
PHY Link LED
11
GND
P
Ground.
Pin No.
Symbol
Ref No.
J2
Symbol
Type
Description
1
RXD
I
Data UART. Recieve Pin.
2
TXD
O
Data UART. Transmit Pin.
3
RTS
O
Data UART. Request to Send Pin.
4
CTS
I
Data UART. Clear to Send Pin.
5
DEBUG_RX I
Debug UART. Recieve Pin.
6
DEBUG_TX O
Debug UART. Transmit Pin.
7
GND
P
Ground.
8
BOOT0
I
MCU Boot. Active High
9
nRST
I
Reset. Active Low
10
STATUS
O
Status Output.
High : Disconnect.
Low : Connect.
11
nH/W
TRIG
I
App Boot.
Hardware TRIG Input. Active Low
WIZ550SR Block Diagram
WIZ550SR EVB
WIZ550SR Developer Board.
USB to UART chip, FT2232D.
RJ45 with Transformer, RB1-1D5B8K1A.
RESET Tact SW.
BOOT0 Tact SW.
H/W Trig Tact SW.
LED Indicators.
Micro USB.
WIZ550SR EVB Call Out
WIZ550SR EVB Block Diagram
Operating conditions at power-up / power-down
Symbol
Parameter
Conditions Min Max Unit
VDD rise time rate
TVDD
VDD fall time rate
us/V
20 -
DC Characteristics
Symbol
Parameter
VDD Supply voltage
Pins Min Typ Max Unit
3.3V 2.97 3.3 3.6
V
Symbol
Parameter
VIL
High level input voltage
ALL 1.833
3.6
VIH
Low level input voltage
ALL -0.3
1.166 V
VOL Low level output voltage ALL
0.4
VOH High level output voltage ALL 3.0
LOL
Low level input Current
Sink Current
LOH
High level output Current
ALL
Source Current
IDD
Supply Current
3.3V
(Normal operation mode)
V
V
V
ALL
-25
mA
25
mA
TBD
mA
nRST pin Characterisrics
Symbol
Parameter
Conditions Min Typ Max Unit
VIL(nRST) NRST Input low level voltage
-0.5 -
0.8 V
VIH(nRST) NRST Input high level voltage
-2
3.8V V
200 -
Vhys(nRST) NRST Schmitt trigger voltage hysteresis RPU
Weak pull-up equivalent resistor
VF(nRST) NRST Input filtered pulse
VNF(nRST) NRST Input not filtered pulse
30 40 50
300 -
Power Dissipation
Condition
Min Typ Max Unit
100M Link
180 -
mA
10M Link
TBD -
mA
Un-Link (Auto-negotiation mode) -
TBD -
mA
mV
kΩ
100 ns
ns
Condition
Min Typ Max Unit
100M Transmitting
TBD -
mA
10M Transmitting
TBD -
mA
Power Down mode
TBD -
mA
WIZ550SR Ref Schematic : Download
WIZ550SR Schematic
WIZ550SR V1.0 Schematic : Download(Altium)
WIZ550SR V1.0 Schematic : Download(PDF)
WIZ550SR BOM
WIZ550SR V1.0 BOM: Download
WIZ550SR EVB Schematic
WIZ550SR EVB V1.0 Schematic : Download(Altium)
WIZ550SR EVB V1.0 Schematic : Download(PDF)
WIZ550SR EVB BOM
WIZ550SR EVB V1.0 BOM : Download
Dimension
WIZ550SR V1.0 3D PDF : Download
很抱歉,暂时无法提供与“WIZ550SR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+272.24796
- 3+243.70439
- 10+220.98212
- 40+202.78754
- 280+186.70109
- 国内价格 香港价格
- 1+292.776871+38.04710
- 3+262.081823+34.05820
- 10+237.6475110+30.88290
- 40+218.0826840+28.34040
- 280+200.77867280+26.09170
