WIZ610WI-EVB
WIZ610WI-EVB
    WIZNET
    EVAL BOARD FOR WIZ610WI
WIZ610WI-EVB 数据手册
Innovative Embedded Networking : Device Server, WiFi, Ethernet WIZ610wi-EVB Feature - Stand-alone typed 802.11b/g wireless LAN module - Ethernet to Wireless Bridging Enable wired network device to have wireless communication interface - Supports Serial Interface for "Serial to Wireless" application - Supports AP/Station/Gateway mode - 54Mbps data rate and Max.20Mbps Effective Data Transmission - Full-Featured Network Protocol Stack - Built-in Web server for configuration via standard web browser Specification Wireless Specifications Wireless Standards IEEE 802.11b 802.11g 2.412GHz ~ 2.462GHz (US & Canada) Frequency Range 2.412GHz ~ 2.472GHz (Europe) 2.412GHz ~ 2.484GHz (Japan) Output Power 16dBm@802.11b(1~11Mbps) 14dBm@802.11g(1~54Mbps) Receive Sensitivity 802.11b -65dBm@11Mbps 802.11g -76dBm@54Mbps Data Rates With Automatic Fallback 54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps, automatically fallback to 5.5Mbps, 2Mbps, 1Mbps 11Mbps, 5.5Mbps, 2Mbps, 1Mbps 12/12/2012 Range Up to 150m/2.5dBi antenna gain Modulation Techniques 11g OFDM (64QAM, 16QAM, QPSK, BPSK) 11b DSSS (CCK, DQPSK, DBPSK) Serial Interface Interface UART CMOS (Asynchronous) 3.3V-level signals, rate is software selectable Serial Line Formats 7 or 8 data bits, 1-2 Stop bits Parity odd, even, none Flow Control XON/XOFF (software), CTS/RTS (hardware), none Network Interface Interface MII, Wireless 802.11b, 802.11g Protocols Supported ARP, UDP, TCP, Telnet, ICMP, DHCP, PPPoE, BOOTP, HTTP, SMTP, TFTP Management HTTP / Telnet Security WEP 64/128bit, WPA/WPA2 PSK/AES/TKIP, 802.1x(Radius) Hardware 32mm X 39 mm X 9mm, Pin Header type Power Consumption Average Consumption under 470mA Environmental Operating range,WLAN -30~70°C Storage range -20~ 77°C 12/12/2012
WIZ610WI-EVB
物料型号:WIZ610wi-EVB
器件简介: - 这是一个独立的802.11b/g无线局域网模块。 - 支持以太网到无线网桥接,使有线网络设备能够拥有无线通信接口。 - 支持串行接口,适用于“串行到无线”应用。 - 支持AP/站/网关模式。 - 数据传输速率可达54Mbps,有效数据传输速率最大为20Mbps。 - 包含完整的网络协议栈。 - 内置Web服务器,可通过标准Web浏览器进行配置。
引脚分配: - 硬件尺寸为32mm x 39mm x 9mm,引脚类型为Pin Header。
参数特性: - 无线标准:IEEE802.11b、802.11g。 - 频率范围:2.412GHz ~2.462GHz(美国和加拿大)、2.412GHz ~2.472GHz(欧洲)、2.412GHz~2.484GHz(日本)。 - 输出功率:802.11b(1~11Mbps)为16dBm,802.11g(1~54Mbps)为14dBm。 - 接收灵敏度:802.11b-65dBm@11Mbps,802.11g-76dBm@54Mbps。 - 数据速率:54Mbps、48Mbps、36Mbps、24Mbps、18Mbps、12Mbps、9Mbps、6Mbps,自动回退到5.5Mbps、2Mbps、1Mbps。 - 范围:最大150米(2.5dBi天线增益)。 - 调制技术:11g OFDM(64QAM、16QAM、QPSK、BPSK)、11b DSSS(CCK、DQPSK、DBPSK)。
功能详解: - 串行接口:UART CMOS(异步),3.3V级信号,速率可软件选择。 - 串行线格式:7或8数据位,1-2停止位。 - 奇偶校验:奇数、偶数、无。 - 流量控制:XON/XOFF(软件)、CTS/RTS(硬件)、无。 - 网络接口:MII、无线802.11b、802.11g。 - 支持的协议:ARP、UDP、TCP、Telnet、ICMP、DHCP、PPPOE、BOOTP、HTTP、SMTP、TFTP。
应用信息: - 该模块适用于需要无线通信接口的有线网络设备,以及需要串行到无线应用的场合。
封装信息: - 硬件尺寸:32mm x 39mm x 9mm。 - 功耗:平均功耗小于470mA。 - 环境:工作范围WLAN为-30~70°C,存储范围为-20~77°C。
WIZ610WI-EVB 价格&库存
很抱歉,暂时无法提供与“WIZ610WI-EVB”相匹配的价格&库存,您可以联系我们找货
