WIZ610WI
WIZ610WI
    WIZNET
    Module
    RF TXRX MODULE WIFI U.FL ANT
WIZ610WI 数据手册
WIZ610WI Quick Installation Guide (Version 1.0) ©2008 WIZnet Co., Inc. All Rights Reserved. ☞ For more information, please visit our website at http://www.wiznet.co.kr WIZ610WI 사용자 매뉴얼 (WIZnet, Inc.) WIZnet’s Online Technical Support If you have any questions about our products, please visit our website and post your questions on the Q&A Board. We will reply your questions as soon as possible CLICK WIZ610WI 사용자 매뉴얼 (WIZnet, Inc.) ii COPYRIGHT NOTICE Copyright 2008 WIZnet, Inc. All Rights Reserved. Technical Support: support@wiznet.co.kr Sales & Distribution: sales@wiznet.co.kr For more information, visit our website at http://www.wiznet.co.kr WIZ610WI Quick Installation Guide (WIZnet, Inc.) 1. Hardware Setting Step 1.Connecting Ethernet Cable Connect WIZ610Wi evaluation board to PC by using the UTP Cable. You can use any types of UTP cable (direct or crossover cable). Step 2.Connecting Serial Cable Connect WIZ610Wi evaluation board to your PC by using the DB9 female serial cable. Step 3.Connecting Wireless LAN Antenna Connect the wireless LAN antenna to the U.FL antenna connector of WIZ610wi. The antenna should have pigtail. 2. Software Setting 2-1. The Configurations WEB Page Step 1.Setting up the IP address of the PC The default IP address and Subnet Mask of WIZ610Wi are 192.168.1.254 and 255.255.255.0 Please configure the IP address of your PC as 192.168.1.XXX and Subnet Mask as 255.255.255.0. Step 2.Connecting Configuration Page Open the web browser on your PC and input the IP address as “192.168.1.254” to connect to the configuration page. Please enter the ID and Password (Default ID: admin/ Password: admin) 2-2. Network Setting To establish a Wi-Fi communication, the devices in the same network must have same values in the parameters of IP address level, SSID, Channel, Encryption. For the detail, refer to below figure. If you setup WIZ610wi as Static IP, you have to know IP address level of Access Point. WIZ610WI Quick Installation Guide (WIZnet, Inc.) Step 1.Wired Network Setting Please set your IP address, Subnet Mask and Gateway of your WIZ610Wi. The default IP address is “192.168.1.254”. Step 2. DHCP Settings Select if you use DHCP function or not, and configure the ‘DHCP Client Range’. When WIZ610Wi is set as DHCP server, it operates as below according to the operation mode.  Access Point Mode : If there is another DHCP server operating at the upper level in the network, it assigns IP address to the client, but does not to WIZ610Wi. If there is not any other DHCP server, WIZ610Wi assigns IP address.  Gateway Mode : In this mode, WIZ610Wi is a bridge for Ethernet to the MII interface. Regardless of DHCP server operating at the upper level, WIZ610Wi assigns IP address to the client.  Client Mode : If WIZ610Wi is set as Client mode, it does not operate as DHCP Client. The application board directly acquires IP address from DHCP server. 2-3. Wireless Setting Step 1. Please configure the operation mode of WIZ610Wi. You can select one of modes (Access Point, Gateway, and Client) Step 2. Please setup the following parameters: SSID / Channel Number/ Data Rate / Security / WIZ610WI Quick Installation Guide (WIZnet, Inc.) Access Control / Advanced / WDS Setting  SSID: SSID should be configured for the wireless communication. The default SSID is “WIZ610Wi”. You can rename your SSID to a name of your choice  Channel: A different channel should be selected when your device experienced interferences from other wireless network. The default channel is set as “1”.  Security : The default security setting is set as “Open System or Shared Key/NONE Encryption”.  Access Control : The default Access Control is “Disable”.  WDS : The default WDS is set as “AP” mode WIZ610WI Quick Installation Guide (WIZnet, Inc.) 2-4. Serial-Wireless Configuration Step 1. Serial Parameter Setting Enable the status of “Serial to Wireless LAN” configuration Input the serial parameters to communicate with the serial device.  Protocol: Select UDP or TCP  Mode : Select a mode (Server, Client, Mixed)  Server IP/Port : At the Client or Mixed mode, you should set the server IP address. WIZ610Wi will try to connect to this server IP address.  Configure Baud rate, Databits, Parity, Stopbits, Flow Control. 2-5. Testing Step 1. Serial to Wireless Gateway Test  Open a terminal program of your choice on your PC (ex: Hyper Terminal). Please set the same baud rate as the WIZ610Wi. WIZ610WI Quick Installation Guide (WIZnet, Inc.) Connect to “WIZ610Wi” in the Wireless Network Setting of your PC  Open another Terminal program and input IP address and Port Number of WIZ610Wi. WIZ610WI Quick Installation Guide (WIZnet, Inc.)  Input any characters in the Hyper Terminal for Serial. (In the example below, “01234567890” is input). The same characters are outputted in the Hyper Terminal for Network. A Serial to Wireless LAN test was performed. Received Data by Network Terminal Program WIZ610WI Quick Installation Guide (WIZnet, Inc.) A serial to Ethernet test can also be performed by using the hyper terminal. In the same way, input any character in the screen of terminal program for network, and check if same character is displayed in the screen for serial (Ethernet to Serial) ※ The above test can also be performed in a program called, “Device Terminal program”, which is easy and simple to use. Device Terminal Program Device Terminal is a program which integrates both serial and network communications into one user interface so that you can test your WIZnet gateway module easily. As shown in above Figure, the upper part of the program allows you to configure your serial setting of WIZ610Wi. By clicking the “Open” button, serial communication is enabled. The lower part of the program allows you to configure the network settings. You can test both TCP Client and TCP Server modes at the same time. If the Server Mode is enabled, Device Terminal will operate as server mode, and the WIZ610Wi module will work as client mode. The PC where the Device Terminal is operating will work as a server, the IP address of the PC should be set as Server IP of the module. If Server mode is not checked, Device Terminal will operate as client mode, and the module as server. For the IP address and port, please input your IP address and port number of WIZ610Wi and click the “Connect” button to start a network communication. WIZ610WI Quick Installation Guide (WIZnet, Inc.) When serial and network terminals are connected, input any character in the Data Input window and click “Send” button. You can check the data is transferred into the another window. WIZ610WI Quick Installation Guide (WIZnet, Inc.)
WIZ610WI 价格&库存
很抱歉,暂时无法提供与“WIZ610WI”相匹配的价格&库存,您可以联系我们找货
