WIZFI630A-EVB
WIZFI630A-EVB
    WIZNET
    MCU RT5350F CHIP
WIZFI630A-EVB 数据手册
WizFi630A Datasheet (Version 1.2) © 2015 WIZnet Co., Ltd. All Rights Reserved. For more information, please visit our website at http://www.wiznet.co.kr © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 Document Revision History Date Revision Changes 2015-09-01 1.0 Release 2015-11-02 1.1 Update the power consumption 2016-01-14 1.2 Clearance of ambiguity of Temperature range © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 2 1. Introduction ............................................................................ 4 1.1. 1.2. 1.3. 1.4. 1.5. 1.5.1. 1.6. 2. Hardware Information .......................................................... 12 2.1. 2.3. 2.4. 3. Absolute Maximum Ratings ....................................................................................................... 16 Operating Conditions ................................................................................................................... 16 DC Electrical Characteristics ....................................................................................................... 16 Power Consumption ...................................................................................... 16 DC characteristics for GPIO pins with 4mA driving capability .................. 16 DC characteristics for GPIO pins with 8mA driving capability .................. 17 AC Electrical Characteristics ....................................................................................................... 17 Power On Sequence ...................................................................................... 17 Reference Schematic ............................................................. 1 4.1. 4.2. 4.3. 4.4. 4.5. 4.6. 5. WizFi630A Pin Map ........................................................................................................................ 12 WizFi630A Pin-Out ......................................................................................................................... 14 Dimensions ........................................................................................................................................ 15 Electrical Characteristics .................................................... 16 3.1. 3.2. 3.3. 3.3.1. 3.3.2. 3.3.3. 3.4. 3.4.1. 4. Features .................................................................................................................................................. 5 Wireless Specifications .................................................................................................................... 6 Hardware Specifications.................................................................................................................. 7 Software Specifications ................................................................................................................... 8 EVB Construction ............................................................................................................................... 9 Contents ........................................................................................................... 9 Block Diagram .................................................................................................................................. 11 Power Part ............................................................................................................................................. 1 Main Connector and Reset Part .................................................................................................. 1 UART Part .............................................................................................................................................. 1 Indicator LED Part .............................................................................................................................. 1 LAN Part ................................................................................................................................................. 1 WAN Part ............................................................................................................................................... 1 Important Notice .................................................................... 1 © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 3 1. Introduction WizFi630A is a gateway module that transforms the RS-232 protocol and TCP/IP protocol into IEEE802.11 b/g/n wireless LAN protocol based on OpenWRT. WizFi630A enables a device with serial interface to connect to LAN or WLAN for remotely control, measuring, and administration. WizFi630A can also work as an IP router because of its internally embedded switch. WizFi630A supports interfaces like Serial (UART), LAN, Wi-Fi(WLAN) to perform functions such as Serial(UART)-To-Wi-Fi, Serial-To-Ethernet and Ethernet-To-Wi-Fi which are supported by scripts and/or commands in OpenWRT. Users can connect to WizFi630A’s internal web server or use serial commands for simple Wi-Fi settings; not only serial devices but 8/16/32 bit micro controllers can also use UART for simple Wi-Fi settings. WizFi630A can significantly reduce the processes for wireless module design, testing, and certification. Therefore, WizFi630A can be the best solution for users who lack wireless network experience. WizFi630A follows the 802.11b/g/n standard and support up to 150Mbps speed in wireless interface. WizFi630A can be provided with an Evaluation board and documents so that anyone can develop a wireless solution. This document provides the information which a hardware designer needs and another document, “WizFi630A Quick Guide”, to make it running is available, too. However, please refer to the website, http://wiki.openwrt.org/doc/start, for more details about functions which OperWRT supports, how to configure and how to update it. © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 4 1.1. Features  Complies with IEEE802.11b/g/n.  Gateway/AP(Bridge)/AP-Client/Client(Station)/Ad-hoc Mode , WDS/Repeater supports  1T1R RF Interface  Physical link rate up to 150Mpbs  Built-in 3 Ethernet Ports  2 Serial Ports supports  Working as Wi-Fi Router  WEP 64/128bit, WPA/WPA2-PSK TKIP, AES  802.1x (Only in AP mode)  802.11e and WMM (Wi-Fi Multimedia)  Router and Firewall function supports © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 5 1.2. Wireless Specifications Type Description Wireless Standard IEEE802.11b/g/n Frequency Range USA: 2.400 ~ 2.483GHz Europe: 2.400 ~ 2.483GHz Japan: 2.400 ~ 2.497GHz China: 2.400 ~ 2.483GHz Operating Channels USA/Canada: 11(1 ~ 11) Major Europe Countries: 13(1 ~ 13) France: 4(10 ~ 13) Japan: 14 for 802.11b(1 ~ 14), 13 for 802.11g(1 ~ 13) Korea/China: 13(1 ~ 13) Available Spectrum 83.5MHz Output Power (Tolerance(+/-1.5dBm)) Receive Sensitivity Data Rates Modulation Type 802.11b: 17dBm@11Mbps 802.11g: 13dBm@54Mbps 802.11n: 13dBm@150Mbps/72Mbps 802.11b: -79dBm@8% PER 802.11g: -65dBm@10% PER 802.11n: -62dBm@10% PER 802.11b: 1,2,5.5,11Mbps 802.11g: 6,9,12,18,24,36,48,54Mbps 802.11n: 29.5,86.5,115,130,144,150Mbps 11g: OFDM(64QAM, 16QAM, QPSK, BPSK) 11b: DSS(CCK, DQPSK, DBPSK) Antenna u.FL (EVB : 1T1R 2dBi) Encryption 64/128Bit WEP, WPA Table 1. Wi-Fi Specifications © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 6 1.3. Hardware Specifications Type Interface Description Serial port : 2 EA LAN port : 3EA USB port : 1 USB Host Port U.FL(wireless) Temperature Humidity Operation: 0℃~+50℃ Storage: -20℃ ~ +70℃ Operation: 10% to 90%, Non-Condensing Storage: 5% to 90%, Non-Condensing Baud Rate : 1200 ~ 921,600bps Stop bits: 1, 2 Serial Parity: None, Odd, Even Flow Control: UART1: XON/XOFF(software), CTS/RTS(hardware), none UART2: XON/XOFF, none Input Power Power Consumption Dimension Weight DC 3.3V / 1A Max : 600mA (3.3V) 33mm X 43mm X 6.3mm 6g Table 2. WizFi630A Module Specifications © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 7 1.4. Software Specifications All functions in the below table are supported by Openwrt software. Type Operation Mode Description Access Point(Bridge), Client(Station), AP-Client Radio Enable/Disable SSID Hidden Multi SSID Wireless Rate Control TX Power Control Beacon Interval DTIM Period Fragment Length Protocol TCP, UDP, ARP, ICMP, DHCP, PPPoE, HTTP WEP 64/128bit Security WPA/WPA2-PSK - with Radius Server or Pre-Shared Key - Unicast Encryption: AES/TKIP MAC Address Filtering / Limiting Port Forwading(UDP and/or TCP) DHCP Client / Server Network WDS(Wireless Distribution System) Support NAT VLAN Administrator ID / PWD Station & AP Association Information Management SSH(Secure Shell) Support Web based Configuration / Serial Command Configuration Upgrade through WEB UI Serial To Wi-Fi 2 Serial Port supports (This can be configured by Ser2Net open tool) Table 3. SW Specifications © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 8 1.5. EVB 1.5.1. Construction Contents Section Qnt. Contents WizFi630A WizFi630A 1ea WizFi630A-EVB WizFi630AEVB 1ea 2dBi WI-FI Antenna (Model : W5I-B0-08) Antenna 1 ea Serial Cable Serial Cable 1 ea LAN Cable 1 ea © Copyright 2015 WIZnet Co., Ltd. All rights reserved. LAN Cable 9 DC 5V/2A Adapter Adapter 1ea Table 4. WizFi630A-EVB Contents © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 10 1.6. Block Diagram Figure 1. WizFi630A Block Diagram © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 11 2. Hardware Information 2.1. WizFi630A Pin Map No T Name 1 GND 2 3.3V 3 GND 4 3.3V Shared Description 5 I/O, IPD CTS_N GPIO9 UART1 CTS-N 6 I/O, IPD RTS_N GPIO7 UART1 RTS-N 7 I/O, IPD RIN GPIO14 UART1 RIN 8 I/O, IPD DTR_N GPIO11 UART1 DTR-N 9 I/O, IPD RxD GPIO10 UART1 RXD 10 I/O, IPD TxD GPIO8 UART1 TXD 11 I/O, IPD DSR_N GPIO13 UART1 DSR-N 12 I/O, IPD DCD_N GPIO12 UART1 DCD-N 13 O WLAN_LED 14 NC 15 NC(VBUS) 16 NC Wireless Init On USB OTG VBUS pin in WizFi630 17 I/O USB_PADP USB OTG data pin Data+ 18 I/O, IPD UART_RX UART2 RxD 19 I/O USB_PADM USB OTG data pin Data- 20 I/O, IPD UART_TX UART2 TxD 21 O TXOP0 10/100 PHY Port #0 TXP 22 I RXIM0 10/100 PHY Port #0 RXN 23 O TXOM0 10/100 PHY Port #0 TXN 24 I RXIP0 10/100 PHY Port #0 RXP 25 I RXIM1 10/100 PHY Port #1 RXN 26 O TXOP1 10/100 PHY Port #1 TXP 27 I RXIP1 10/100 PHY Port #1 RXP 28 O TXOM1 10/100 PHY Port #1 TXN 29 I RXIP2 10/100 PHY Port #2 RXP 30 O TXOM2 10/100 PHY Port #2 TXN 31 I RXIM2 10/100 PHY Port #2 RXN 32 O TXOP2 10/100 PHY Port #2 TXP 33 O LINK0_LED LAN port 0 Link LED 34 O LINK2_LED LAN port 2 Link LED 35 O LINK1_LED 36 I/O, IPD GPIO0 37 I, IPU CPURST_N 38 I/O, IPD EJTAG_TDO LAN port 1 Link LED GPIO0 WPS Button Push GPIO17 Reset Button Push(GPIO17) © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 12 39 I/O, IPD EJTAG_TRST_N GPIO21 40 I/O, IPD EJTAG_TMS GPIO19 General Purpose Input Switch SW1-1 41 I/O, IPD EJTAG_TDI GPIO18 UART1 Tx/Rx LED (This can be configured) 42 I/O, IPD EJTAG_TCK GPIO20 WPS LED(GPIO20) 43 NC 44 NC 45 NC 46 NC UART2 Tx/Rx LED (This can be configured) 47 I/O, IPD I2C_SCLK GPIO2 General Purpose Input Switch SW1-2 48 I/O, IPD I2C_SD GPIO1 RUN LED(GPIO1) 49 GND 50 3.3V 51 GND 52 3.3V Table 1. WizFi630A Pin Map © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 13 2.3. WizFi630A Pin-Out Figure 2 mini PCI connector Top View Figure 3 min PCI connector Bottom View © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 14 2.4. Dimensions Dimensions (mm) Length Width Height 43 33 6.3 Hole Width 24.2 HOLE Height 40 HOLE Φ 2.5 Tolerance +/- 0.2mm © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 15 3. Electrical Characteristics 3.1. Absolute Maximum Ratings Supply Voltage 3.6V Vcc to Vcc Decouple -0.3 to +0.3V GND – 0.3V to Vcc + 0.3V Input, Output or I/O Voltage 3.2. Operating Conditions Operational Ambient Range 0℃ to 50℃ 3.3V ± 10% Supply Voltage 3.3. DC Electrical Characteristics 3.3.1. Power Consumption Supply Voltage Conditions Min Typical Max Wifi off 240 - - Wifi on 280 - 600 Unit 3.3V 3.3.2. mA DC characteristics for GPIO pins with 4mA driving capability Symbol Min VIH Normal Max Unit 2.0 5.5 V VIL -0.3 0.8 V VOH 2.4 V VOL 0.4 V IOH 10.0 19.4 31.1 mA IOL 6.5 10.4 14.4 mA © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 16 3.3.3. DC characteristics for GPIO pins with 8mA driving capability Symbol Min VIH Normal Max Unit 2.0 5.5 V VIL -0.3 0.8 V VOH 2.4 V VOL 0.4 V IOH 14.0 27.2 44.9 mA IOL 9.8 15.7 21.8 mA 3.4. AC Electrical Characteristics 3.4.1. Power On Sequence Figure 4 Power On Sequence Symbol t_IO_PORST_N Description Time between I/O power-on to PORST_N deassertion © Copyright 2015 WIZnet Co., Ltd. All rights reserved. Min 10 Max Unit ms 17 4. Reference Schematic 4.1. Power Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 4.2. Main Connector and Reset Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 4.3. UART Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 4.4. Indicator LED Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 4.5. LAN Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 4.6. WAN Part © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1 5. Important Notice WIZnet reserves the right to make corrections, modifications, enhancements, improvements and other changes to its products and services at any time, and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders, and should verify that such information is current and complete. All products are sold subject to WIZnet’s terms and conditions of sale, supplied at the time of order acknowledgment. Information relating to device applications, and the like, is intended as suggestion only and may be superseded by updates. It is the customer’s responsibility to ensure that their application meets their own specifications. WIZnet makes no representation and gives no warranty relating to advice, support or customer product design. WIZnet assumes no responsibilities or liabilities for the use of any of its products, conveys no license or title under any patent, copyright or mask work rights to these products, and makes no representations or warranties that these products are free from patent, copyright or mask work infringement, unless otherwise specified. WIZnet products are not intended for use in life support systems/appliances or any systems where product malfunction can reasonably be expected to result in personal injury, death, severe property damage or environmental damage. WIZnet customers using or selling WIZnet products for use in such applications do so at their own risk and agree to fully indemnify WIZnet for any damages resulting from such use. All trademarks are the property of their respective owners. © Copyright 2015 WIZnet Co., Ltd. All rights reserved. 1
WIZFI630A-EVB 价格&库存
很抱歉,暂时无法提供与“WIZFI630A-EVB”相匹配的价格&库存,您可以联系我们找货
