WIZWIKI-W7500ECO
WIZWIKI-W7500ECO
    WIZNET
    W7500ECONET (WITH ECO SHIELD ETH
WIZWIKI-W7500ECO 数据手册
products:wizwiki-w7500eco:start [Document Wiki] Page 1 of 6 Document Wiki WIZwiki-W7500ECO WIZwiki Platform WIZnet WIZwiki-W7500ECO is a WIZwiki platform board based on W7500. The IOP4IoT W7500 chip is one-chip solution which integrates an ARM Cortex-M0, 128KB Flash and hardwired TCP/IP core for various embedded application platform especially internet of things. You can develop prototype product more quickly using WIZwiki-W7500ECO and it includes CMSIS-DAP for debuging and ethernet-phy. http://wizwiki.net/wiki/doku.php?id=products:wizwiki-w7500eco:start 5/3/2018 products:wizwiki-w7500eco:start [Document Wiki] Page 2 of 6 Features WIZnet W7500 • • • • • • • • • • • • • ARM Cortex-M0 Core 48MHz, 128KB Flash 16KB RAM 32KB RAM for TCP/IP - Can be extended to system RAM Hardwired TCP/IP Core MII Interface ADC (8) GPIO (53) SWD (Serial Wire Debug) Timer/PWM UART (3) SPI (2) I2C (2) External Ethernet PHY • • • • IC+ IP101GRI Single Port 10/100 MII/RMII/TP/Fiber Fast Ethernet Transceiver Auto MDI/MDIX function Supports MDC and MDIO to communicate with the MAC CMSIS-DAP • • • • LPC11U35FHI33/501, ARM Cortex-M0 Core, NXP Drag-n-drop programming USB Serial Port Easy to use C/C++ SDK Connector • Micro USB • Slim Size RJ45(with transformer) • GPIO Header ETC • • • • • Power source - micro USB or external 5V pin 1 RESET SW. RGB LED for CMSIS-DAP 2 Blue LED for USER 2 2.54mm 1×20 Externel connector WIZwiki-W7500ECO Blockdiagram http://wizwiki.net/wiki/doku.php?id=products:wizwiki-w7500eco:start 5/3/2018 products:wizwiki-w7500eco:start [Document Wiki] Page 3 of 6 WIZwiki-W7500ECO Callout WIZwiki-W7500ECO Detail Pinout http://wizwiki.net/wiki/doku.php?id=products:wizwiki-w7500eco:start 5/3/2018 products:wizwiki-w7500eco:start [Document Wiki] Page 4 of 6 WIZwiki-W7500ECO Simple Pinout Firmware W7500 Library • W7500 Library PAGE Getting Started • • • • • How to start WIZwiki-W7500ECO Board How to install WIZwiki-W7500ECO serial driver How to write the firmware into WIZwiki-W7500ECO How to debug Wizwiki-W7500ECO How to write the firmware into CMSIS-DAP Make New WIZwiki-W7500ECO Projects • • • • How to install KEIL uVision5 How to create KEIL uVision5 new project for W7500 How to use MDK for W7500 Peripherals Examples How to use gcc for W7500 Peripherals Examples Technical Reference http://wizwiki.net/wiki/doku.php?id=products:wizwiki-w7500eco:start 5/3/2018 products:wizwiki-w7500eco:start [Document Wiki] Datasheet • W7500 Documents [http://wizwiki net/wiki/doku php?id=products:w7500:documents] • IP101GRI Datasheet [http://www bdtic com/DataSheet/ICplus/IP101G_DS_R01_20121224 pdf] • LPC11U35FHI33/501 Datasheet [http://www nxp com/documents/data_sheet/LPC11U3X pdf] Schematic • Schematic Version 1.1 • WIZwiki-W7500eco V1.1 Schematic (Altium Designer) • WIZwiki-W7500eco V1.1 Schematic (PDF) Part list • WIZwiki-W7500eco V1.1 BOM (PDF) Dimension • WIZwiki-W7500ECO V1.1 Dimension Page 5 of 6
WIZWIKI-W7500ECO 价格&库存
很抱歉,暂时无法提供与“WIZWIKI-W7500ECO”相匹配的价格&库存,您可以联系我们找货
WIZWIKI-W7500ECO
  • 1+260.864451+33.90000
  • 3+252.168973+32.77000
  • 10+247.8212310+32.20500
