LFSPXO083325REEL
LFSPXO083325REEL
    IQD
    SMD3225_6P
    有源晶振 100MHz 2.5V -40℃~+105℃
LFSPXO083325REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO083325Reel Customer Part: Description LVPECL output crystal oscillator using a high frequency fundamental crystal to give very low jitter. Hermetically sealed ceramic package with a seam sealed metal lid. Model IQXO-623 iss:2.00 Model Issue number 2 Frequency Parameters Frequency 100.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 105.00°C ±3ppm max per year @ 25°C Electrical Parameters Supply Voltage Current Draw 2.5V ±5% 50.000mA Output Details Output Compatibility Rise and Fall Time Duty Cycle Output Voltage Levels: Output Low (VOL): 1.095V max Output High (VOH): 1.475V min Outline (mm) LVPECL 0.5ns max 45/55% Output Control Standby Operation: Logic ‘1’ (70% Vs min) to pad 1 enables oscillator output. Logic ‘0’ (30% Vs max) to pad 1 disables oscillator output. No connection to pad 1 enables oscillator output due to internal pull-up resistor. Standby Current: 10µA max Start-up Time: 10ms max Noise Parameters Phase Jitter (12kHz to 20MHz): 300fs rms max Phase Jitter (12kHz to 20MHz): @100MHz: 129fs rms typ @125MHz: 101fs rms typ @156.25MHz: 79fs rms typ Environmental Parameters Storage Temperature Range: –55 to 125°C Shock: 1500G, 0.5ms, 3 times for each surface, total 18 times. Vibration: Freq. range: 20~2000Hz, peak to peak amplitude: 1.52mm, peak acceleration: 20G (196m/s²), 3 direction(X, Y,Z) ,each cycle: 20min, 4 cycles for each direction. Manufacturing Details RoHS Terminations RoHS Reflow Temp Au over Ni 260°C max for 10sec mac Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 10 May 23 12:05 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO083325Reel Customer Part: Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 10 May 23 12:05 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO083325REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO083325REEL”相匹配的价格&库存,您可以联系我们找货
